JDP Motorsports
Old 02-17-2012, 08:28 PM   #15
Kevinshawnm
Biggz
Drives: 2010 Camaro 2SS L99 Rally Yellow
3sixty.3 is the latest i guess.
Kevinshawnm is offline   Reply With Quote
Old 02-17-2012, 08:29 PM   #16
Kevinshawnm
Biggz
The JL audio 900/5 is a great amp, if your going for the one amp to run everything install.
Old 02-17-2012, 08:31 PM   #17
sameershah23
Drives: Camaro 1LT
Or do you recommend separate amps for sub and speakers?
sameershah23 is offline   Reply With Quote
Old 02-17-2012, 08:32 PM   #18
Kevinshawnm
Biggz
There are some really great instals on the forum, look through some of the older posts.
Old 02-17-2012, 08:34 PM   #19
Kevinshawnm
Biggz
myself i prefer a multi amplifier install.
Old 02-17-2012, 08:40 PM   #20
Kevinshawnm
Biggz
Check out what Zack @ extreme performance is doing, also Team Tca that Austinjames recommended.
Old 02-17-2012, 08:41 PM   #21
sameershah23
Drives: Camaro 1LT
I am no electrical engineer, but will the JL sub W7AE be compatible with the HD900/5?
I have read numerous posts on this, but its something to do with the internal resistance of the battery and the wire running to the amp from the battery( Resistance of the battery)
Old 02-17-2012, 08:46 PM   #22
Kevinshawnm
Biggz
That amplifier wont power that sub. I would do a 2 12w7, and 2 1200/1 sub/amplifier on the low end of things. Only if your goal is to spend the whole 10k. You can upgrade the electrical, multible battery setup.
Old 02-17-2012, 08:49 PM   #23
Kevinshawnm
Biggz
Also the AE is just the anniversary edition of that sub. you can save a ton of $ and just get a regular 12w7.
Old 02-17-2012, 08:49 PM   #24
sameershah23
Drives: Camaro 1LT
Looks like I am back in school. I have to do a ton of research, Gosh, But I guess in the end its going to be worth it.
Old 02-17-2012, 08:51 PM   #25
sameershah23
Drives: Camaro 1LT
pricewise, theres isn't much diff bw the 12W7AE and the regular 12w7
http://www.amazon.com/12W7AE-3-Audio...9529795&sr=1-2
http://www.amazon.com/JL-AUDIO-12W7-...9529877&sr=1-1
Old 02-17-2012, 08:52 PM   #26
Kevinshawnm
Biggz
I believe the power wire in the Camaro is 2ga, I would do 0ga from the battery to your distribution block, then 4ga to your amps.
Old 02-17-2012, 08:54 PM   #27
sameershah23
Drives: Camaro 1LT
I can look after the electrical part, but I am having a tough time deciding on the speakers and the amps
Old 02-17-2012, 08:55 PM   #28
Kevinshawnm
Biggz
also dont forget sound deadening, Most neglect to do this and suffer in the end.
$10k, audio, best system
Where to buy car audio products online? squatin0n18s Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 07-24-2010 02:43 AM
Press release: 2010 Camaro Audio by Visteon and Boston Acoustics Mike C Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 49 07-07-2009 03:11 PM
