Old 02-17-2012, 10:27 PM   #1
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Cool Tire Pressure - What should it be..really?
I searched but have not found the answer to this question....
The Pirelli P-Zero's sidewall states a max pressure of 50 PSI, the car's tag says 36 PSI, it appears the TPMS goes off at under 32 PSI...I was always taught not to follow the tag cuz you never know if the tires have been changed from manufacture's specs...so I've always adheared to the sidewall. Is everyone else doing so? Not looking to wear these out in 15K.
It would seem GM set the low pressure warning for these tires too low, if that is the case. Cold, they should hold about 45 PSI and will warm up close to max. Logical right? Can we set the TPMS to alert for higher pressures, say 40PSI closer to the tires actually rating?
OK, let's hear it. Thanks.
One-Bad-ZL1 is offline   Reply With Quote
Old 02-17-2012, 10:31 PM   #2
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
I go with the 36 cold off my own tire gauge...the dash reading has never matched yet!
90503 is offline   Reply With Quote
Old 02-17-2012, 10:34 PM   #3
bradshaw
bradshaw's Avatar
Drives: 2010 LS3 2SS M6
36 is correct, always follow the cars recommendation for proper handling.
bradshaw is offline   Reply With Quote
Old 02-17-2012, 10:35 PM   #4
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Are you sure the side walls say 50psi? Before garaging my camaro I thought it said Max 44psi.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 02-17-2012, 10:39 PM   #5
90503
90503's Avatar
I always thought the "max psi" was only needed if you were at the very top of the vehicle's loaded gvw....not really applicable to passenger cars...
Old 02-17-2012, 10:39 PM   #6
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
I keep mine at 35-36 cold. I have to put air in once a month or so.
bajamoon is offline   Reply With Quote
Old 02-17-2012, 10:42 PM   #7
The_cartoonist_88
Turbine Cowboy
The_cartoonist_88's Avatar
Drives: 2010 Yellow 2LT Camaro
I keep mine at 36. Always go with the vehicle recommendations
2010 YELLOW 2LT
The_cartoonist_88 is offline   Reply With Quote
Old 02-17-2012, 10:42 PM   #8
lewylew
lewylew's Avatar
Drives: 2010 ZL550& 2016 Charger Hellcat
I keep mine between 36-39 psi. When I went on SRT driving experience they kept the tires on the SRT vehicle, on roadcourse at 50 psi. Thought that was a little high, but the cars handled really good.
lewylew is offline   Reply With Quote
Old 02-17-2012, 10:48 PM   #9
Parag
Drives: 2010 camaro 2SS LS3
the max psi is for setting the bead. for stock size always go with the body tag. but if you put 22's on, you want to adjust accordingly
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ
Parag is offline   Reply With Quote
Old 02-17-2012, 10:53 PM   #10
mulletman
Drives: 2017 Camaro SS
50 PSI is not the recommended tire pressure. 36 PSI cold is what you should be running.
mulletman is offline   Reply With Quote
Old 02-17-2012, 11:07 PM   #11
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
These...
Life is too short to drive cars that suck.
My build Thread
In or around Savannah GA on the first Sunday of the month? Come meet with us here around 11 am!
mmarx82 is offline   Reply With Quote
Old 02-17-2012, 11:14 PM   #12
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
OK, hear this, then. Your logic is not correct. Please DO NOT run your tires near the sidewall max pressure rating. Running 45 or 50 PSI cold pressure can increase your hot pressure way too high and can even be hazardous at worst. Even if your tire doesn't blow on you, running 50 PSI cold pressure will cause the center of the tire tread to bulge out and wear your tires unevenly. Under inflation will do the same to the edges of the tread.
Stick with the door jam recommended setting of 36 PSI. The TPMS low alarm of 32 PSI is probably correct too. A 4 PSI drop in tire pressure from 36 equates to an 11.11% drop which is significant.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 02-18-2012, 10:06 AM   #13
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Remember the difference between cold and hot pressure is about 5 PSI during the summer and more than that during the winter.
During the summer i run between 35-40 PSI cold depending on if I get distracted for a few seconds while putting air in.
During winter I run a little bit less cause the air will expand more when the tires warm up. I run about 30-32 PSI cold during the winter.
Old 02-18-2012, 10:25 AM   #14
suplex
suplex's Avatar
Drives: 2011 Coupe, 1LT, A6, No RS Package.
I had always thought it was 1 PSI for every 10 degrees temperature difference. However, if that's true, what do they consider the "starting" temperature?
Let's say they refer to 70 degrees as the initial temperature, and your car is supposed to be at 35 PSI when it's 70. I would assume that means that if it's 40 degrees out, you should set your tires to 38 PSI, and if it were 100 degrees out, then set the tires to 32 PSI. So if it's hotter out the PSI goes down, and if it's colder out the PSI goes up.
Am I correct according to my above example?
Never Underestimate The Power of Forums
suplex is offline   Reply With Quote
pirelli, pressure, psi, tire pressure, tires
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Tire Pressure Questions nalinc23 Wheels and Tires Talk Sponsored by The Tire Rack 21 09-15-2010 02:18 PM
factory 20in wheels cold tire pressure? mike12345 Wheels and Tires Talk Sponsored by The Tire Rack 7 05-11-2010 01:58 AM
Tire pressure monitor CEL after tire change B.Buster Wheels and Tires Talk Sponsored by The Tire Rack 6 04-01-2010 09:45 PM
Tire Pressure Problems Matster Canada 14 10-03-2009 07:11 AM
