LSR Performance
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 02-18-2012, 04:05 PM   #1
ztsmith86
ztsmith86's Avatar
Drives: 2010 Camaro 2SS/RS
Monster Clutch
Has anyone been using a Monster Clutch? TSP recommends them. I'm jsut wondering if anyone has had good luck with these clutches? Thanks
http://www.texas-speed.com/p-1077-mo...3-package.aspx
2010 Camaro 2SS/RS LS3 Inferno Metallic
TSP 1 7/8" Long Tube Headers 304 SS MagnaFlow 2.5 Street Series Catback Exhaust K&N Cold Air Intake Comp Cams Camshaft227/235 .639"/.646"114LSA+2.5 REV 2.165 Hollow Stem Stainless Steel Valves Manley1.59 Stainless Steel Exhaust Valves GM LS7 Hydraulic Lifter Kit Katech CR-5 Timing Chain Manley Hardened Pushrods Comp Cams LSX Rocker Arm Trunion Kit A.I.R. Ported Cylinder Heads Catalytic Converter Delete
ztsmith86 is offline   Reply With Quote
Old 02-18-2012, 04:32 PM   #2
DandD
DandD's Avatar
Drives: 2010 2SS and 2011 LS
I'll let you know soon, I'll be getting my car back early next week and one of the items I had done was the install of a Monster Level 3 clutch kit.
Around here we like baseball, hot dogs, apple pie, and Chevrolet
DandD is offline   Reply With Quote
Old 02-18-2012, 05:26 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red, 1LT/RS SGM
Im not supposed to let the cat out of the bag, but i am supposed to get their new twin disc installed Monday. I just dont know if it will be ready. I have a McLeod RXT as a backup just in case. I have talked to them about the twin disc and i really like what i am hearing. They have been trying to get them out for a couple years now. When it is actually ready it will be special.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, ARH LT s, Procharger D1SC, Squash dual 400LPH/ID1000s, ALKY 4 gal meth, AM AFR/Bst/oilpres/oiltemp gauges,SWretro3" exh, VMaxx TB, RX monsterCC. Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates setup by JusticePete! :Gforce 9" 35spline S-Trac, 300M axles, 3.5"alum DS, MCLeod RXT clutch, 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, next CTS-v calipers/ZL1rotors/carbotech pads
BullF-16 is offline   Reply With Quote
Old 02-18-2012, 05:39 PM   #4
ztsmith86
ztsmith86's Avatar
The monster clutch packages are so much cheaper than the zr1 clutch kit from LPE. is the monster clutch package perform as well? Thanks
Old 02-18-2012, 07:27 PM   #5
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
You can go to the gto site and get plenty of feedback.Keep in mind the GTO weighs less than the Camaro.If we can help you with a great clutch for the Camaro let us know.
Hendrix-Engineering is offline   Reply With Quote
Old 02-18-2012, 07:28 PM   #6
Hendrix-Engineering
The zr1 clutch is a twin,the other is a single,we have singles from $499 but it doesnt compare to a twin.If we can help you out let us know.
Old 02-19-2012, 10:49 AM   #7
Kingsize
Kingsize's Avatar
Drives: as many vehicles as possible.
FWIW I've had a Monster clutch in my GTO now for nearly 2 years and beat the shit out of it on a regular basis.
2006 GTO: 500rwhp Stock bottom end LS2 with Bolt on's
Idle Clip>>> http://www.youtube.com/watch?v=s2rKmw2DDZY
500rwhp Dyno Pull>>> http://www.youtube.com/watch?v=z21MepuHe2g
2007 Corvette 440ci LS7 600RWHP N/A & 812RWHP on nitrous
2000 Firebird Formula 468ci 9.79 N/A, 8's on nitrous
1999 Arctic White FRC w/bolt on's :reddevil
1993 Mustang 347 2 stage nitrous 711RWHP
1992 Camaro 410ci LSX 101mm Turbo
1967 Ford Galaxie 500
www.fquick.com/Kingsize
Kingsize is offline   Reply With Quote
Old 02-19-2012, 09:21 PM   #8
flem
Drives: old
monster clutch level 3
we have it in a 644 rwhp m-6 nickey blown stage -2 same thing we beat this car all the time! not one problem. put it in and beat the shit out of it.
flem is offline   Reply With Quote
Old 02-28-2012, 07:43 PM   #9
DandD
DandD's Avatar
Just picked my car up today from Livernois, they did the instal on my Monster level 3 package. I only put 50 miles on the car driving it home, but the clutch feels great! No chatter at all, and only slightly more pedal pressure than the stock clutch. I'll repost after the 500 mile break in period. This clutch will be more than I need at the track this year at 410-420rwhp but it leaves me a lot of "room" for adding HP now.
Dan
Old 02-28-2012, 07:53 PM   #10
ztsmith86
ztsmith86's Avatar
Thanks!
Old 02-28-2012, 08:08 PM   #11
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Hendrix Steet slayer is what i went with.. Cant wait to try it. Should have mine up and running in about a week or so.
Whipped416 is offline   Reply With Quote
Old 02-29-2012, 03:36 PM   #12
IDEALG
"Chevy" rumbles best
IDEALG's Avatar
Drives: 2011 2SS/RS 6 speed
Send a message via AIM to IDEALG
Are you guys changing/upgrading your slave cylinders with these clutch kits? what slave cylinders are you guys using?
IDEALG is offline   Reply With Quote
Old 02-29-2012, 03:46 PM   #13
DandD
DandD's Avatar
I stayed with the stock slave, the guys at Livernois checked it out and found nothing wrong with it. Hopefully I will continue to have trouble free operation, time will tell, but up to this point I've had no issues at all with the the clutch or trans. Everything I had done was to try and keep it that way as I'll be using the car at the track quite a bit this year.
Dan
Old 02-29-2012, 03:53 PM   #14
IDEALG
IDEALG's Avatar
I have the katech twin disc clutch kit which is the ZR1 style and it came with a slave cylinder. just wondering what everyone else is using and how they like it. If i dont hit that clutch pedal to the floor hard at high rpm ill get the second gear grind. but i cant keep throwing money out the window to solve this so everyones input on thier different clutch packages is appreciated.
Old 02-29-2012, 03:55 PM   #15
DandD
DandD's Avatar
Just sent you a PM too
Old 02-29-2012, 04:07 PM   #16
DandD
DandD's Avatar
Are you doing the clutch install yourself or having it done?
Old 02-29-2012, 05:53 PM   #17
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Dan
Did you also go with the chromoly flywheel or not?
No china cheap bolt-on's, drywall, buffet, or yubiwaza here.....平的
Smirnoff is offline   Reply With Quote
Old 02-29-2012, 06:15 PM   #18
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Some clutches work with stock clutch, others will require a slave that will work with that particular clutch.
If your clutch came with a slave included it's most likely because it will not work correctly with the stock clutch.
calbert1999 is offline   Reply With Quote
Old 02-29-2012, 07:34 PM   #19
IDEALG
IDEALG's Avatar
Yeah i installed it myself
Old 02-29-2012, 07:37 PM   #20
IDEALG
IDEALG's Avatar
I know that, mine came with a slave. Just wondering if you guys using other clutches are using the stock slave or did your clutch kit come with its own slave
Old 03-07-2012, 07:36 PM   #21
DandD
DandD's Avatar
Smirnoff, no I did not go with the chromoly flywheel, sorry it took so long to answer.
Updated MONSTER CLUTCH Website! Chris@SPMC V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 16 11-09-2011 01:34 PM
clutch pedal repeatedly stuck, minimal load cab2g Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-26-2011 09:39 AM
Buy a Monster Clutch and Lashway will install for free! Erik@lashway Local Marketplace 1 12-30-2010 06:17 AM
Vendors!!!!! I need a monster clutch, who's got access?? jamnutz V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 11-28-2010 09:05 PM
Anyone using a Monster clutch? HRC V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 11-18-2010 07:39 PM
