JUICEDMOTORSPORTS
Old 02-18-2012, 04:57 PM   #1
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
LPE gear noise???
I just installed a stock diff with LPE 3.70 gears in my car, it is supposed to have around 2500 miles on it. It has what sounds like a gear whine at normal highway speeds. If I get over 70 or so the noise seems to quit, or if I'm under 45 it sounds OK. Is this a normal thing with aftermarket gear sets? If I let off the gas it will quit for a couple seconds and then start again[not as loud though] I have only driven it about 5 miles so far.
I used royal purple 75/90 lube, would 90/140 help this at all. I also wondered if it could possibly be bearing issues? With 2500 miles I wouldn't think so.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 02-19-2012, 07:37 AM   #2
inferno camaro
Anybody running aftermarket gears???
Old 02-19-2012, 08:41 AM   #3
Eric Baker
Drives: Black/Black 2SS/RS 6M
Yes aftermarket gears will be noisier than factory to some extent, especially if you have aftermarket bushings installed. If they are really loud, they may be damaged or installed incorrectly.
Eric Baker is offline   Reply With Quote
Old 02-19-2012, 08:50 AM   #4
IROCanSS
Drives: 89 IROC 350
I had 4.10s, they whined, then broke, but thats not why. Wheel hop got them.
Now I have my 3.45s back in and they whine, same speed you describe. I think it has to do with the wear pattern. You can't install used gears and not have them whine.
Old 02-19-2012, 08:54 AM   #5
inferno camaro
It does have solid bushings in it. I looked at the gears and can't see and wear with the naked eye, but maybe thats not possible. Its not loud just a little annoying.
Old 02-19-2012, 09:04 AM   #6
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
Bad thing is I've done countless gear swaps and fords will accept used gears and not whine. You have typical gear noise that won't change with pinion or backlash movement.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Old 02-19-2012, 09:14 AM   #7
IROCanSS
Drives: 89 IROC 350
Right, but I don't really care. I will be swapping out again some day so I just either speed up or slow down when it really starts to get at me.
Old 02-19-2012, 10:34 AM   #8
inferno camaro
I didn't change the gears, I put in the entire diff that was already setup with these gears? The person I got from did talk about wheel hop issues, so maybe it messed up a bearing or something.
Old 02-19-2012, 10:52 AM   #9
Eric Baker
It's unlikely that a bearing got damaged from wheel hop but the gears weren't affected.
Old 02-19-2012, 05:11 PM   #10
inferno camaro
Can the rear be setup again to fix it or is it to late once they have been run. I have read that some people are adjusting them and it works OK but alot off people say I would need to get new ring and pinion. To those who say they can't be adjusted and fix it does that meen the noise won't go away or will it actually hurt the gear? If it would help the gears last even though the noise doesn't go away I would do it. I was told to get them micropolished and them setup again.
Old 02-20-2012, 07:20 AM   #11
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
LPE 3.70's are made by AAM who makes the entire Camaro diff for GM so they really aren't aftermarket. I have AAM/LPE 3.70's in my car and they are factory quiet.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 02-20-2012, 07:38 AM   #12
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
I recently had AAM 3.91 gears installed in my diff. Here are the breakin instructions my installer gave me:
The break in is VERY specific.
-Drive 30-35 MPH for 20-30 minutes.
-Drive 55-60 MPH for 20-30 minutes.
-Come to a complete stop and let the diff cool (15 minutes minimum)
This is one cycle. Repeat this cycle 4-5 times. If you don't do this EXACTLY, the diff WILL whine. 500 miles will be needed for a full break in.
Maybe this was not done?
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 02-20-2012, 10:36 AM   #13
inferno camaro
Who did the install for you guys? Would be nice to talk to them for advice. I have heard micro polishing may help as it makes a fresh surface. Thinking about doing this, for $50 its worth a try I guess
2012 ls m6 1st gear shift noise??? SoCalThug Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 18 01-18-2013 01:55 AM
Stock differential w/ LPE 3.70 gear Never Satisfied Transmission / Driveline 10 02-17-2012 01:00 PM
Aftermarket Shift Levers Gear Hop Out Or Clash CalEditor@pcmcalibrators V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 09-07-2011 10:41 AM
Gear Lash Noise From TVS2300 FORGELINE Forced Induction - V8 2 05-11-2011 10:21 AM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 11:57 AM
