BeckyD @ James Martin Chevy
Old 06-23-2012, 05:51 PM   #43
B.Buster
B.Buster's Avatar
Drives: 2010 AquaBlue 2SS/RS
Dave , That Chiller tank looks killer
B.Buster is offline   Reply With Quote
Old 06-24-2012, 05:28 PM   #44
bumblebeecamaro
Car Lover By Nature
Drives: Mini Cooper S
That new chiller box looks sweet Dave. Where could we mount it on my car? I might be interested in replacing my current HE for this new type.
bumblebeecamaro is offline   Reply With Quote
Old 06-24-2012, 05:29 PM   #45
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
I am guessing it has to go in the trunk.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 06-24-2012, 05:32 PM   #46
bumblebeecamaro
Car Lover By Nature
Hmmmmmm... That would be cool but that would mean running AC lines to and from the trunk. I'd almost want the new lines to be hard lines instead of rubber just for peace of mind.
Old 06-24-2012, 05:53 PM   #47
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
Originally Posted by bumblebeecamaro View Post
That new chiller box looks sweet Dave. Where could we mount it on my car? I might b-e interested in replacing my current HE for this new type.
I agree with you, I could supply lengths of straight bendable lines with AC fittings on each end then switch to hose. I can mail them in shipping tubes.
Rat is using Aeroquip A/C Race Hose. It has a smaller OD and is braded as well as user can put reusable ends on. He is using I think its PEX from Home Depot for water. It looks good check it out!
ACTIVE INTERCHILLER.COM Fl INTERCHILLER
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is offline   Reply With Quote
Old 06-27-2012, 03:24 PM   #48
TrekGTO
TrekGTO's Avatar
I Have these CNC Freon return adapters made blank so I can drill the opening anywhere and weld any shape AC fitting to it. For example on the Camaro if you have big FRCs I can tweak the location of Freon return line special order. Above mentioned Rat TBSS he needs special direction to easily run the AC hose for Chiller Tank so I welded this one to order. That’s all he needs now and will have it working Saturday! Can’t wait to hear his comments on performance.
Old 07-07-2012, 07:01 AM   #49
TrekGTO
TrekGTO's Avatar
We have an offer to include a Super Chiller in a Gm performance Magazine, only problem is I don’t have a custom kit available for car model yet, working on that.
We have first Whipple Camaro Kit Shipping to Canada as well as another Chiller Tank Shipping now. I have simplified custom AN fittings to one part # for Bulkheads and one part # for Super Chillers before machining. I picked up another order of Fittings from welder Friday. All Freon connections including connection to core are O-ring fittings now and working out great. Also restocked all the CNC parts! I have over 10K in Chiller parts in stock now!
The Competition wiring update is going out to all previous customers interested Free, so if I have not contacted you contact me to be included. This simple update with a relay and Diode will keep HEX. Closed even when AC cycles during Competition Mode and will make significant reduction of IAT in Comp mode. Once installed makes no visible change to driver.
We have 2 respected TX shops installing Super Chillers now! I can’t wait for there Dyno reviews.
Here is a quote from one of my early Camaro Super Chiller Customers with an Eforce.
“It was 93* today and my IAT was 61 thanks* ”
Old 07-29-2012, 01:08 PM   #50
TrekGTO
TrekGTO's Avatar
Check out our new ZL1 and V6 Super Chiller Mounting. Mounts farther back but still uses existing mounting holes.
Old 07-31-2012, 03:29 PM   #51
TrekGTO
TrekGTO's Avatar
Special thanks to Sage for bringing us his Whipple Super Charged SS! I think it came out Awesome, we moved the water pump to the other side of Heat Exchanger with a 6061 aluminum bracket, turned pump over and increased water flow. Sage said IATs were lower without the AC even on. This also gets rid of that water line that crosses over behind radiator. Water drops direct from reservoir to pump. I didn’t even have to bleed system at all when filled.
After this change the Whipple Super Chiller Kit is nearly the same as a Maggie Kit. I have one Whipple Kit going to Canada as soon as I get back from Camro5Fest but after that they are available. I will have the Whipple specific parts on display at Indy.
Old 07-31-2012, 05:47 PM   #52
partymn
partymn's Avatar
Drives: 2014 1ss 1LE
I can not even imagine that temp of the air charge if it was in the mid 70s to 60s out side. It would be like blowing ice into the intake. I have got to get one of these for a turbo application.
2014 1SS 1LE, bone stock for now.
partymn is offline   Reply With Quote
Old 07-31-2012, 06:21 PM   #53
Turbo99
Turbo99's Avatar
When it get cooler out ,it doesn't change it much, alittle but not like it does when its hot. It can only get it so cool and thats it.
Old 07-31-2012, 10:19 PM   #54
bumblebeecamaro
Car Lover By Nature
Yeah, this system helps my Maggie car breath a little easier in this brutal summer time weather we have here in central FL.
Old 08-03-2012, 11:29 AM   #55
TrekGTO
TrekGTO's Avatar
Come see us @ Camaro5fest, you cant miss us with the coolest display there!
Elwood the Super Chilled XLR V is only on display Friday but Bobby's Super Chilled Camaro is on display Friday and Saturday except when on the track.
Old 08-04-2012, 07:51 PM   #56
bumblebeecamaro
Car Lover By Nature
Glad to see u made it Dave. I need to make plans with u to have u install your new relay thingy.
Whiteside Customs Super Street 1 Package - Install Thread Whiteside Customs Suspension / Brakes / Chassis 5 12-12-2011 09:40 PM
Drag Racing..."Real Street Cars" Steve Dallas Dragstrip and Launch Techniques Discussion 40 09-04-2011 12:02 PM
Portable Dynamometer added to Houston Super Chevy Show Midway, Sept. 11-12 Houston Raceway USA - Texas 6 09-02-2010 12:26 AM
LG g6x3 or Super Charger Cam!!! Your Thoughts Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-24-2010 02:45 PM
Shelby Super Snake KILLER74Z28 General Automotive + Other Cars Discussion 18 07-23-2007 08:12 PM
