B&M Racing
Old 08-28-2012, 09:14 AM   #85
Turbo99
Turbo99's Avatar
Drives: 08' F250 Diesel & 10' Camaro 2SS
Originally Posted by TrekGTO View Post
We have 1 year warranty on parts. I have a special in house $200 installation out the door. Phil’s Automotive in Murphy NC does installs, I can give you his info. Any AC technician willing to take bumper cover off should be qualified to do the install.
Are you going to The Late Model Muscle Car event at Bradenton October?
I doubt it, I will still be gone for work, unless I can get home that weekend, if it is early Oct. it is possible.
Contact me for questions: coopwfo@gmail.com I cant send/receive PMs.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph
TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets
Turbo99 is offline   Reply With Quote
Old 08-28-2012, 11:58 AM   #86
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
Not sure I wanna put ~1,000 round-trip miles on my car to have this installed. LOL I'll have to do some research around here and see if someone is willing to do it for a decent price. Tear :(
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 08-29-2012, 12:02 PM   #87
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Who's your nearest installer to Shreveport Lousiana?
BoostedX2 is online now   Reply With Quote
Old 09-03-2012, 12:07 PM   #88
TrekGTO
TrekGTO's Avatar
Drives: 05 GTO / JETTA TDI
My Whipple guy just sent this pic to my phone; he took Bumper Cover off and insulated the cold hoses behind Bumper. Water was dumping off bumper when he was staging. He is changing his pulley to 12lb now with his new found low IATs. I will update #s after its tuned.
ACTIVE INTERCHILLER.COM Fl INTERCHILLER
Original SUPER CHILLER Since 2009
Original XTREME CHILLER Since 2013
FACEBOOK 727 656 1422
Email Orders and Inquires
TrekGTO is offline   Reply With Quote
Old 09-04-2012, 09:04 PM   #89
Turbo99
Turbo99's Avatar
Dave can you post a picture of the lines that he insulated and with what did he insulate them with. I had thought of doing the same thing even to the rubber water lines in the engine bay.
Old 09-04-2012, 09:06 PM   #90
Turbo99
Turbo99's Avatar
I also got my A/C clutch replaced and saw a 8-12* drop in my IATs from before when we first put the chiller on. I for the first time on a 88* day saw 48* degree IAT. I have never seen my IATs in the 40's before and also a 40* difference from ambient to actual IAT*.
Old 09-04-2012, 09:09 PM   #91
Turbo99
Turbo99's Avatar
I know we want it as cold as possible but water dripping off the bumper will get dangerous and prolly told to turn off A/C at that point. We need to figure a way to make this not happen.
Old 09-07-2012, 05:51 AM   #92
TrekGTO
TrekGTO's Avatar
Your car has the cold lines under hood; the Whipple has pump and a cold hose behind Bumper Cover. Natural air flow dissipates the condensation on your car but there is not enough air flow behind Bumper Cover so water accumulates. Don’t look for problems, I would insulate hoses if I had a solution that looked good but so far it like Frankenstein.
You would be better off with the Competition Wiring Update. Your car being the first, I would replace complete wiring with the new. It’s much improved, simplified and quality. That includes OEM sealed relay under hood. Send me a check for $25 shipping handling and I will send you a complete wiring kit $150 value. Or come by and I will install it free. I’m much stoked about the new revision of this update; it works exactly the way I want. IMHO insulating under hood lines would be insignificant. It has to help but….
Old 09-07-2012, 07:11 PM   #93
Turbo99
Turbo99's Avatar
I will come see you when I get a chance, Prolly be November though. I did have condinsation on my lines under the hood at the track but it was very little. The coolest thing was to grab the lines with the engine running and HOT and the lines were cold to the touch!!
Old 09-09-2012, 07:39 AM   #94
TrekGTO
TrekGTO's Avatar
Thanks, OK I will be looking for you. Here is a under hood portion of the Competition Wiring as shipped.
Only connections under hood are + post, green compressor wire and 6mm existing ground. We use OEM sealed Relay under hood, Weather Pack Connector to Freon Solenoid and late model small Fuse Holder, all terminals are heat shrink.
The loose wires at the long end go through an existing grommet in fire wall with final connections made inside cabin to competition relay, switched power and LED. Only connections inside cabin to car are ground and switched power from Fuse Box. This makes for a very clean install.
Old 09-09-2012, 12:35 PM   #95
Turbo99
Turbo99's Avatar
Good job Dave! Thats looks so much better than the original. Keep up the improvments and the business will grow.
Old 09-09-2012, 01:18 PM   #96
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
do u think these kits have any longevity with the motor?
Whipped416 is offline   Reply With Quote
Old 09-09-2012, 01:23 PM   #97
Turbo99
Turbo99's Avatar
Not sure what you mean.
I think they will help your engine live a longer happier life, just to the sheer fact how it will eliminate possible detonation, as long as you don't get silly agressive with the tune.
If that was what you were asking.
Old 09-10-2012, 03:00 PM   #98
RX SS RACERX
RX SS RACERX's Avatar
Drives: 2010 2SS/RS RJT
My car threw/toasted the AC belt on the dyno. Builder indicated the stretch to fit belt will not stay on at the strip. Honestly,I'm getting tired of removing it when I go to the track and reinstalling for cruising. Opinion/recommendations. I am considering your chiller as a winter mod. (Sounds kinda backwards-lol) Do you have a PDF etc. that we can access or can be PM'd so I can evaluate if I can handle the install? Thanks
9.75 @ 139mph, 1.41 60ft, 2010SS, JRE Built!
RX SS RACERX is offline   Reply With Quote
Whiteside Customs Super Street 1 Package - Install Thread Whiteside Customs Suspension / Brakes / Chassis 5 12-12-2011 09:40 PM
Drag Racing..."Real Street Cars" Steve Dallas Dragstrip and Launch Techniques Discussion 40 09-04-2011 12:02 PM
Portable Dynamometer added to Houston Super Chevy Show Midway, Sept. 11-12 Houston Raceway USA - Texas 6 09-02-2010 12:26 AM
LG g6x3 or Super Charger Cam!!! Your Thoughts Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 01-24-2010 02:45 PM
Shelby Super Snake KILLER74Z28 General Automotive + Other Cars Discussion 18 07-23-2007 08:12 PM
