R1 Concepts
Old 02-20-2012, 11:57 AM   #1
2012REDSS
Drives: 2012 Camaro SS
Hurst billet shifter install ?
I went to install the shifter today and my car had the Allen recessed bolts and I striped one. Is there anything I can do short of dropping the drive shaft and exhaust to get it out. I can't be the only one who has done this. Help me out.
2012REDSS is offline   Reply With Quote
Old 02-22-2012, 11:46 PM   #2
Nessal
Drives: Exige, Miata, Ghia
Damn, that sucks and I know what you mean. Even though I didn't strip mine I could see how you did it. Did you use an swivel adapter to hold the socket? If you stripped it out bad, maybe you can try to take the boot off from the top of the car and drill the old stripped bolt out? Might be easier to just drop the pipes.
Nessal is offline   Reply With Quote
Old 02-23-2012, 06:11 PM   #3
2012REDSS
I'm going to try a dremel with a flex attachment and see if I can cut a slot for a flat head bit. If that don't work I'm going to cut the flange off of the shifter retainer ring around the bolt and use a small set of vice grips. If that don't won't drop the pipes and shaft and drill. I'll let u know
Old 02-26-2012, 06:20 PM   #4
2012REDSS
Dremel with flex attachment worked and shifter is in.
Hurst Billet/Plus 2 Shifter $199.95, add an APEX Skip Shift Eliminator for only $10! Apex Motorsports Transmission / Driveline 36 08-08-2012 07:28 PM
Another Hurst shifter question f5journal V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 11-12-2010 07:49 PM
2010 Camaro Hurst shifter in stock ready for shipment GmPartsDirect.com Transmission / Driveline 0 05-24-2010 08:23 AM
STATUS OF A POSSIBLE RERUN TO HURST FOR SHORT THROW SHIFTER INSTALL als 011 z28 USA - California 7 12-04-2009 11:48 AM
Dealer Install time for a HURST Shifter? 55Designs V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 10-27-2009 04:13 PM
