Caryle Racing
Old 02-20-2012, 09:27 PM   #1
C17A
C17A's Avatar
Drives: 2010 Camaro SS
Post Pfadt rear suspension notes.
The attempt this weekend was to replace the rear trailing arms, rear tie rods and subframe bushings with Pfadt upgrades.
After removing; the exhaust, disconnecting the drive shaft, dropping the entire rear end out and removing the rubber subframe bushings (which is not easy), I had to throw in the towel on the bushings that connects the rear trailing arms to the spindle. I spent the better part of a day trying to remove them with a re-created pfadt tool, which was mostly successful until the bolts would sheer.
If someone hopes to do this on their own I would recommend getting a real bushing press c-clamp and removing the entire spindle seperate from the main suspension body and axles the mechanic I spoke with at West Coast Corvettes said that their tool is basically a one shot use maybe two if you're lucky.
West Coast Customes is also listed on Pfadt's website as a authorized dealer so take this info as you wish.
Good luck to all the other DIY'rs.
C17A is offline   Reply With Quote
Old 02-21-2012, 04:09 PM   #2
Zman12
Zman12's Avatar
Drives: 2010 Camaro 2SS
I also just did these upgrades this weekend. All you need is to borrow a 2 prong puller from AutoZone. The tool cost me $0. I had them out in about 5 mins a side.
Whipple,custom cam,CAI,Kooks,Pedders and PFADT 626RWHP 549TQ ..
Zman12 is offline   Reply With Quote
pfadt, rear trailing arms, subframe bushings
New Pfadt 2012+ Adjustable Front and Rear Sway Bars Package PfadtRacing Suspension / Brakes / Chassis 55 08-15-2012 12:20 AM
Pfadt Race Engineering Rear Trailing Arms At Apex Motorsports!!! Apex Motorsports Suspension / Chassis / Brakes 174 08-09-2012 06:43 AM
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 11:53 AM
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 10:29 AM
Amazing result for Torq and Pfadt at the 2010 LS Fest! Full report inside with pics! Erik@Torq Suspension / Brakes / Chassis 12 09-22-2010 08:19 AM
