BORLA
Old 03-15-2012, 07:09 PM   #15
dmwhiteman
dmwhiteman's Avatar
Drives: 2SS Black w/ Inferno Orange Stripes
LED Emblem
I have been trying to figure out a way to hold my power and ground wires to my speaker box with out it looking tacky. I think I found the way. A LED Black Widow emblem.
I am using 3/8" plexi glass, black plasti-dip. and 1 1/2" of LED strip from Autozone.
Started out with a sheet of plexi
I cut out the black widow emblem using a scroll saw. Here it is next to another emblem like the center console, for size comparison.
The final version will have a plasti-dip emblem in the center so only a small amount of plexi will be seen. A trough will be milled underneath with 3 LED lights tucked up in. Not sure how the wiring will work yet.
Here is a better mock up
Basement paint shop! Lots and Lots of plasti-dip.
Sorry for the LONG LONG LONG delay. The plasti dip didnt work and I was pretty busy last week. I finally got around to repainting the emblem. Used Gloss Black Acrylic paint. 3 coats to cover up the LED lights.
And a general overview of the trunk
dmwhiteman is offline   Reply With Quote
Old 03-15-2012, 08:56 PM   #16
Maro99
Maro99's Avatar
Drives: Heel toe express..
That was a good Idea with the wires.. It would have looked bad with just the wires being exposed. Instead you put it on display with the emblem and lighting and it looks really good. Great idea, im liking the trunk setup..
Camaro SOLD :(
Maro99 is offline   Reply With Quote
Old 03-16-2012, 05:40 AM   #17
dmwhiteman
dmwhiteman's Avatar
Thanks! I really wanted a way to show off all my hardware without it being sloppy. I'm very happy with how it turned out.
Old 03-28-2012, 07:03 AM   #18
dmwhiteman
dmwhiteman's Avatar
Received my 3D carbon kit early this week. Called the guy who is going to be painting and installing it for me. He is backed up at the moment and wont be able to get to it for a couple weeks.
Old 03-28-2012, 07:18 AM   #19
pierre777
HT5 COTW 9/3/2012
pierre777's Avatar
Drives: Cyber Bullet
looking good
Old 04-12-2012, 04:44 PM   #20
dmwhiteman
dmwhiteman's Avatar
Just got my JDP halo kit in the mail. In the process of putting it in!! Check it out!
Old 04-16-2012, 09:07 AM   #21
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
Great build man! Very nice
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 04-16-2012, 10:24 AM   #22
Dznts
Anabolic Connoisseur
Dznts's Avatar
car looks great man!
Old 04-16-2012, 12:20 PM   #23
dmwhiteman
dmwhiteman's Avatar
Originally Posted by pierre777 View Post
looking good
Thanks guys! I really appreciate it!
Old 05-15-2012, 11:40 PM   #24
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
Love the black widow theme.
HP Turbine is offline   Reply With Quote
Old 06-02-2012, 03:31 PM   #25
dmwhiteman
dmwhiteman's Avatar
Thanks! Little by little its coming along
Old 06-02-2012, 03:36 PM   #26
dmwhiteman
dmwhiteman's Avatar
JDP RS Halo Kit
So far I have jacked up the car and pulled out the wheel wells. Will update as the night goes on.
First attempt at taking off the bumper. Need to watch the video once more. 4th times the charm. I found it easier to get to the 10mm bolts by removing the wheel well completely.
Here is the front bumper off with the module hooked up ready to do a test to make sure the lights work.
THEY WORK!!!
Head lights out ready for a small surgery. I found this very simple... the second light. The first light took me about an hour. I have all the recommended tools and it was still tricky. The second light took about 20 min. Putting them back together was a snap. I didn't need to use a magnet for the small screws.
All that is removed is this tiny led.
Another test to make sure I didn't mess anything up putting the lights back together.
The control module is attached to the back of the bumper support right in front of the radiator
Finally had some time to grab a couple quick pictures of the project that was finished a month ago. I have been waiting for my photographer to take some good pictures. She is very busy so these will have to do for now.
All the pictures have the scanner bar ON. Right now both the scanner bar and halos are on one switch.
Red - Used most often
Orange
Green
Blue
Purple
Old 06-08-2012, 02:02 PM   #27
dmwhiteman
dmwhiteman's Avatar
Picked up some spray tint last night. Gonna tint my tail lights and eventually spray my side markers.
Old 06-10-2012, 11:37 AM   #28
dmwhiteman
dmwhiteman's Avatar
Tail light tint
Picked up some spray tint at Wal-Mart.
Stock
First I took the plastic cover off the top of the light housing. Its held in by 3 plastic clips that came out very easily with a flat head screw driver. Then I removed the chrome bezels. These pulled off extremely easily as well. No tooling required. I discovered it gets very dirty behind the bezels. good time to get it all cleaned up!
Getting the lights out was a bit tricky. They are each held in by 3 10mm nuts. I wasnt able to get a wrench in to a couple of the places, but most of them were only hand tight.
Once the nuts are off and you twist the bulb out, the light slides right out.
Time to tint
After tint. I did one thick coat. Friends that have done this say they get better results with one coat than with several light coats
After they dry Ill have pics of them installed.
Here they are installed with no trim. Getting them back in was pretty simple. A couple of the nuts were hard to get back on, but with a little patience its doable. Getting the bulbs to line up was also a bit tricky. I had to take the housing out a couple times to make sure the right size tabs were lining up. They can only go back in one way.
Installed with trim and trunk down. I think they give the car a whole new look. I took it out yesterday and got very positive feedback. Next step is to spray the side markers.
Well I got a Vararam. Thanks 2SSRS , Patrick and Steve. Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 02-16-2010 11:08 AM
2010 2ss\rs SS/LS3 Autos For Sale / Wanted 22 02-15-2010 06:15 PM
2SSRS seat question runich 5th Gen Camaro SS LS LT General Discussions 15 01-22-2010 08:34 PM
Balise has 4 2SSRS Camaros 2010 SSRS USA - New England 8 11-19-2009 07:02 AM
2ssrs available asap in oklahoma 1badss Dealer Camaros for Sale 2 07-29-2009 09:24 PM
