HURST
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Florida > Local Marketplace
Old 02-21-2012, 08:19 AM   #1
Xplosive Performance
Drives: 240sx SR20DET,240sx w/LS6, 09-ZO6
Send a message via AIM to Xplosive Performance
K&N Oil Filter & Red Line Oil Special
5W30 Motor Oil
  • Most popular oil for modern road cars and light trucks, as specified for most late-model BMW, General Motors, and Nissan vehicles
  • Also suitable for VW/Audi 500.00, 501.01 and 502.00, Ford WSS-M2C946-A
  • Thicker oil film at operating temperature than a petroleum 10W40
  • Recommended for API SM/SL/SJ/SH/SG/CF and ACEA A3/B3/B4, GM dexos1 (GM-LL-A-025, GM6094M and GM4718M)
ABOUT RED LINE MOTOR OIL
  • Fully-synthetic ester formula for passenger cars, light trucks, performance vehicles and marine applications
  • Excellent wear protection and friction reduction across a wide range of operating conditions
  • High detergency allows extended drain intervals and provides increased cleanliness
  • Improved fuel economy and ring seal for more power
  • Superior high temperature stability and oxidation resistance increases lubrication of hot metal compared to other synthetics
  • High natural viscosity index (VI) provides thicker oil film in bearings and cams
  • Less evaporation than other synthetics for improved efficiency and ring seal
  • All products are completely compatible with other conventional and synthetic motor oils
TYPICAL PROPERTIES
API Service ClassSM/SL/SG/CF
Viscosity GradeSAE 5W30
Vis @ 100C, cSt 10.6
Vis @ 40C, cSt 62
Viscosity Index162
CCS Viscosity, Poise, @*C60@-30
Pour Point, C -45
Pour Point, F -49
Flash Point, C 252
Flash Point, F 486
NOACK Evaporation Loss,1hr @ 482F (250C), % 6
HTHS Vis, cP @150C, ASTM D4741 3.8
Originally developed for demanding race applications, K&N's Premium Wrench-Off Oil Filter has become a favorite among consumers for its durability and easy removal. Most of our automotive and marine oil filters come with a 1 nut welded to the top of the canister so they can be easily wrenched-off with a standard tool. To satisfy the demands of racers, our oil filter has many features over and above the requirements of most vehicles. We use thicker canister walls for extra strength and durability which reduces the risk of damage from loose rocks and debris. The drilled hole on the nut provides for safety wire attachment. Our oil filters also use a resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration
(9) quarts of Red Line 5W-30 oil
(1) K&N Premium Wrench Oil Filter
$129.55 delivered Lower US
http://www.xplosiveperformance.com/K...O6_p_2862.html
Xplosive Performance is offline
Old 06-22-2012, 05:05 PM   #2
5W30 Motor Oil
TYPICAL PROPERTIES
Vis @ 40C, cSt 62
Viscosity Index162
Pour Point, C -45
Pour Point, F -49
Flash Point, C 252
Flash Point, F 486
Originally developed for demanding race applications, K&N's Premium Wrench-Off Oil Filter has become a favorite among consumers for its durability and easy removal. Most of our automotive and marine oil filters come with a 1” nut welded to the top of the canister so they can be easily wrenched-off with a standard tool. To satisfy the demands of racers, our oil filter has many features over and above the requirements of most vehicles. We use thicker canister walls for extra strength and durability which reduces the risk of damage from loose rocks and debris. The drilled hole on the nut provides for safety wire attachment. Our oil filters also use a resin impregnated cellulose filter media. This allows for higher flow rates while providing outstanding filtration
Everything LS3/L99 Oil Pumps ztsmith86 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 29 08-29-2015 04:11 PM
My V6 oil change experience convert Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 38 04-08-2014 05:15 PM
Red Line Synthetic Oil ddunerider Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 19 01-03-2014 01:08 PM
