Old 04-29-2009, 10:25 AM   #1
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Drives: 2SS RS, SIM, 6pd, 20"Alum
LS3 Gear 2 difficulty...
Everyone once in awhile my car doesn't want to shift into gear 2.... no idea why. It's probably 1 in 10 shifts...but it's definitely there.... anyone have any ideas?
It's a brand new transmission...so it's not a gear tooth issue....
Embalmer is offline   Reply With Quote
Old 04-29-2009, 10:27 AM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
skip shift?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 04-29-2009, 10:27 AM   #3
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
It has a gear lockout, called skipshift. It helps the mileage. There should be a light on the dash when this happens. It makes you fo from 1st to 4th when you are not accelerating hard. I know it sucks, but it was on the 4th gen also.
ZZcamaro is offline   Reply With Quote
Old 04-29-2009, 10:28 AM   #4
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Yep it is skip shift. Ask some of the guys around here there is something you can buy to have it turned off.
Scott@Bjorn3D is offline   Reply With Quote
Old 04-29-2009, 10:29 AM   #5
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Yup, that's skip shift. It's to help save gas mileage. There should be a little light in the DIC/gauges notifying you. You have to shift directly to 4th gear. The other alternative is to stop driving like a granny (skip shift is only activated if you give it less gas).
This might work for the Camaro....
http://www.corvetteguys.com/slp-skip...liminator.html
UCF w00t is offline   Reply With Quote
Old 04-29-2009, 10:29 AM   #6
dodson914
Drives: 2008 2500 HD; 2008 G8 GT #199
Guess that means you need to be driving it much harder.
dodson914 is offline   Reply With Quote
Old 04-29-2009, 10:29 AM   #7
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
It's the dreaded skip shift we 4th genners had to deal with. The computer will force you to shift from 1st to 4th when you are driving economically. When you take off a bit harder than usual, it will allow you to shift into 2nd. I have a skip shift bypass on my 4th genner. I'm sure they will be available shortly for 5th gens.
Hylton is offline   Reply With Quote
Old 04-29-2009, 10:33 AM   #8
stovt001
stovt001's Avatar
Drives: 2006 Cobalt, 2004 Taurus wagon
So far everyone who's driven one really hasn't encountered skip-shift. So you're the first Camaro5 member to drive the car like a granny. Good job!
"It's kind of fun to do the impossible" - Walt Disney
There's a great big beautiful tomorrow
shining at the end of every day
Just a dream away
stovt001 is offline   Reply With Quote
Old 04-29-2009, 10:34 AM   #9
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Wait, so I have to go from 1st gear to 4th gear??
I thought the skip-shift was so that you HAD to go through all the gears and you couldn't skip shift...
Wtf, I'm having this removed ASAP.
Old 04-29-2009, 10:35 AM   #10
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Hahaha....well I drove it HARD day 1...so I've been babying it since.... trying to get it to the 1500 mile mark before I give her hell.
Also...does anyone know when I should get the first oil change?? I heard 500 miles and 1000...
Old 04-29-2009, 10:37 AM   #11
Embalmer
2G1FT1EWXA9103351
Embalmer's Avatar
Hmm ok, I haven't noticed a light... I'll have to pay attention next time it happens...
Old 04-29-2009, 10:40 AM   #12
avol2
2G1FT1EWXA9104709
avol2's Avatar
Drives: 2010 Camaro 2SS/RS SIM
THAT MADE ME LAUGH!!!
My 2010 2SS/RS SIM, LS3 was ordered on 10/13/08 and delivered on 5/9/09!
Julie
aka aVOL2 (because I ride a VOLusia Too)
avol2 is offline   Reply With Quote
Old 04-29-2009, 10:42 AM   #13
ZZcamaro
If you are modding the car...when you get it tuned, they can turn of the skipshift!!
Old 04-29-2009, 10:44 AM   #14
kdbolt70
kdbolt70's Avatar
Theree's a little arrow pointing from 1 to for that shows up in the DIC. I've seen it a few times. I usually just hold 1st a little longer to get to the point which it allows me to go to second. I haven't been bothered by it too much. I will be removing it as soon as we confirm the workaround works...
On the other hand, have you noticed any squeaks coming from where the A pillar meets the top of the dash? Both pillars are doing it now on bumpy roads. I'm going to see if there's something I can do to fix it.
2SS/RS Victory Red M6 w/ Black Rallys #3305
Muffler Delete, Lloyd "SS" Floormats, K&N Aircharger, Skip Shift Eliminator, Blacked Bowties
kdbolt70 is offline   Reply With Quote
Camaro SS LS3 gear ratios. JEFF2010SSMANUAL V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 23 06-25-2015 10:45 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
ls3 ss now 430hp!!!? gss9909 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 57 11-18-2008 02:56 PM
