| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
![]() Drives: 2010 camaro ss Join Date: Feb 2012
tsp vvt3 cam gains compared to non vvt cam gains
I don't want to start any arguement on which is better. I was just wondering what rwhp people are getting with tsp vvt3 cam compared to what others are getting with vengeance cams and jre 470 cams. I know their all good and reliable cams I was just wondering cus I may soon cam my camaro shortly.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
I installed the VVT-3 cam a few weeks ago, I have not dynoed my car but can tell you there is a substantial gain in power, I am still waiting to dial in my tune but even as is it runs real strong.
Sounds good keep me posted when you get the dyno tune. Did you port the heads when you got the cam installed.
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
Reliability trumps 20-30 more rwhp imo.
Yea I agree with you about reliability but their all reliable from what I have gathered.
#6 |
Only if the installer and tuner know what they're doing.
It's still pretty new technology and not very many people have developed substantial aftermarket mods into it. |
#7 | |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
Now, VVT3 is pretty aggressive and many have stated they did it without a stall... but they recommended it or you would lose drive ability. The conversion will allow you to go a bit more aggressive and ultimately build a foundation for better results. I would say if you compared two similar cams as far as size and specifications, the VVT will out perform by 10-20. However, the LS3 just seems to give us more freedom, to go bigger as we need to with a much, much greater selection. I know Lethal produced a cam that was pushing near 90-100, just like the VVT.
2011 2SS/RS
Performance: 439 RWHP A6: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, FTI Converter, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. Appearance:Smoked side markers and black bowties. Blk / Blue Carbon Fiber interior trim. Next in order: F14s, 3.70 gears, DSS Axles, End links/Toe rods/trailing arms, Ported heads, S/C. ![]() 1100 7/02 Ordered 3800 8/09 Order produced 4200 8/13 Shipped 6000 8/24 HOME! |
#8 |
![]() Drives: 2011 Dodge 3500 dually Mega Cab Join Date: Jul 2009
I have done a stupid amount of research on the VVT system GM uses, I can not find one case of a cam phaser failing in a modified or stock engine. Please show me proof that VVT is not reliable. I'm sure one has failed $hit breaks I just can't find it. Just because some thing is more complex or has more moving parts does not make it unreliable the cam phaser it self is a very simple part.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
#9 |
#10 | |
#11 |
The installation is quite straight forward and almost the exact same as a non vvt cam. Tunning, for an experienced tuner is also no different than tunning a conventional cam with the exception of the phaser tables but they are supplied with the cam so it's taken out of the equation
#12 |
#13 |
To the OP see my SIG. I have picked up 121 RWHP over stock and FWIW that is thru a converter that is un locked at WOT.
#14 |
#15 | |
#16 | |
And last I checked we use push rod engines which IS old technology .
#17 | |
Also all you have is a cam setup. Throw in FI or spray with VVT and let me know how far you get. There's a reason all high HP guys are running ls3 conversions - its proven. If you want to use your car as a test mule for VVT limits I would be very very interested and would subscribe at once to your post. |
#18 |
Kaler that 121rwhp gain was with the ported heads. Those are nice numbers.
#19 | |
v It bites.
OP, the best advice we can give you is call texas-speed or mast and ask them about their VVT cams. Then call Ted and ask about the conversion ..make your choice from there. I don't think neither is right or wrong, but I did feel after adding FI, the conversion would be a safer bet for me...but the VVT is incredible, Kaler alone almost had me sold on the VVT.. but I was afraid to do the VVT3. I just wanted the freedom to choose more with the conversion. Again, no one is right or wrong.
2011 2SS/RS
#20 | |
You didn't answer why VVT is not reliable again.
#21 |
Yea I've already tried contacting tsp through a message on their website a couple days ago no answer. But that's ok maybe their website acting up or they didn't get it yet. I'm not worried about goin fi I just would like to get around 470rwhp.
#22 | |
Just for the record I absolutely under stand why people are reluctant about using VVT,it has not been proven in thousand of engines over many years.There is a lot of miss information about VVT out there, and frankly I blame it on TSP, Mast,Nu era and all of the companies doing the development. I wish they would take the approach "we have the best VVT cams available" and here is why. They would sell a lot more and we would have more development if they would be an open book with there development and at the same time prove why you should buy one from them.
#23 |
Many eight cyl. engines get way over 1-2 hundred thousand miles, not many 4 cyl do. We do use in many instances pushrod engines which are old technoligy but the efficency is much greater but the comment made was on moving parts and current engines have more moving parts than earlier ones.
#24 | |
Amazing what a simple reliable tech-lacking engine can do, huh? |
#25 | |
There is no doubt that the ls3 conversions have proven very reliable but there has been no evidence that I am aware of that vvt is not. |
| Thread Tools | |
| Unofficial 1/4 Mile 2010+ Camaro Fast List | Merc | Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions | 210 | 06-13-2013 08:42 PM |
| Cam basics | CamaroSpike23 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 59 | 01-27-2013 07:28 PM |
| Another L99 cam question....VVT! | SS-screamer | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 90 | 06-28-2010 06:41 PM |
| VVT cam swap with no AFM... Tips? | cam- | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 02-25-2010 02:42 PM |
| Cam Headers Intake Tune 446 RWHP 430 RWTQ | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 72 | 11-25-2009 03:09 PM |
