Cold Air Inductions
View Poll Results: Was the dyno off?, or does GM have something up it's sleeve?
Yes! the dyno was off. 13 36.11%
Maybe those numbers are correct... 23 63.89%
Voters: 36. You may not vote on this poll
Old 02-27-2012, 11:01 AM   #15
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
ALSO: Please bring the comments back to the topic
Thank you much
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 02-29-2012, 08:26 AM   #16
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Thank you much
Adm will have 3 basic packages:
Zl700
Zl800
Zl1000
Our testing shows the new Version 2 Race Intake
On the LSA makes big gains at the above power levels.
We set out to build the most powerful
intake on the market for the 2012 ZL1.
Our test car was at the track this past weekend
Making 800+ hp using the new version 2.Dyno data
is all finished up and production is ramping up as we speak.
ADM PERFORMANCE is offline   Reply With Quote
Old 02-29-2012, 10:06 AM   #17
adamgl
adamgl's Avatar
Drives: '98 Camaro Z28, '06 Z06
Zl700
Zl800
Zl1000
Any pics or info on how much hp the intake alone adds yet?
'10 Camaro 2SS/RS A6 Sold :( ARH, FM Super 44's, K&N CAI, ADM scoop, Diablo Tune, RX catch can.
'98 Camaro Z28 M6 TSP headers, true duals, AIR/EGR/AC/muffler delete, CAI, Subframe con.,
shock tower brace, Stg. 2 T56 rebuild. Monster Clutch Stg. 2, Electric Water Pump, TT2 wheels, 315 NT555's
'06 Z06 2LZ, Cam, P/P/M Heads, FAST Intake/TB, ARH, CAI, HP Clutch/FW, C5 Axles,
Pfadt Coilovers/Poly Bushings, Carbon Fiber: Everything, lol. HID's, 360 Forged Spec 5's/Invo's, Custom Interior. 550 RWHP
http://www.camaro5.com/forums/showthread.php?t=235911
adamgl is offline   Reply With Quote
Old 03-01-2012, 08:02 AM   #18
ADM PERFORMANCE
Lets just say its worth it.
Detailed data will be available on this site
and others very soon
Old 03-12-2012, 09:14 AM   #19
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Question ZL1 in Sheeps Clothing
In last months issue of GM High Tech Performance Magazine, they took a stock 2012 CTS-V Wagon and straped it to the dyno. It put down 524 RWHP and 521 ftlb of torque! The artical said how this was either a factory "freak" or GM made unlisted unchanges to the LSA. Or do you think their dyno was wrong? What do you guys think? here are some links I found about the subject.
The Catallic Forums.
http://www.cadillacforums.com/forums.../t-252805.html
GMHTP site.
http://blogs.gmhightechperformance.c...aph/index.html
They don't have the article posted on the sit yet, but most likley will after the next issue is released.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 03-12-2012, 09:17 AM   #20
IROCanSS
Drives: 89 IROC 350
you can't go by dyno results. They can make them whatever they want.
The only good thing about a dyno is getting an approximation of power and its a good way to show gains with mods, as long as youre on the same dyno with the same conditions.
Old 03-12-2012, 09:41 AM   #21
actireman
Drives: 2011 denali hd2500
Absolutly correct. I own www.warroomdyno.com and we have a Mustang MD250 eddy current dyno. Our dyno doesn't put out near the numbers that an inertia dyno does. We don't care because we use our dyno for tuning. But we will have customers get 50 RWHP when they go to a Dyno jet.
actireman is offline   Reply With Quote
Old 03-12-2012, 09:51 AM   #22
jdsgn
Drives: 87 GN, 05 GTO
The point isn't really whether the dyno is "accurate" It's that the article is stating that the company had dynoed many pre-12 Vs and none had dynoed near that. So they are wondering if GM has made a change to the LSA without adjusting the power ratings. I don't see what they would have to gain by inflating their stock dyno numbers. Most shops would inflate after their mods to make them look better. I guess we will know soon enough whether GM has bumped the power or if this was a fluke dyno that was reading incorrectly.
jdsgn is offline   Reply With Quote
Old 03-12-2012, 10:24 AM   #23
htron50
htron50's Avatar
Drives: 2017 ZL1 (Firm Order) Status 1100
From what I see, the Dyno is not "STOCK"... is it Stage 1. So, NEITHER of the VOTE choices are correct. The DYNO is not off, and the numbers ARE correct. Both are true. What is NOT true is that the car is stock. It is NOT based on what I found on the links provided. The 3rd choice should be "THE DYNO IS CORRECT BUT THE CAR IS NOT REALLY STOCK".
"In the April 2012 issue of GM High Tech Performance we are showing an ADM Performance Stage I intallation and dyno test."
The Stage I kit in this configuration consists of a LPE 2.55 upper pulley, LPE solid isolator, ADM ported snout, Halltech Stinger Intake and an ADM HO tune.
Comments? I MIGHT be wrong, but above is the quote taken from the article.
htron50 is offline   Reply With Quote
Old 03-12-2012, 10:29 AM   #24
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Stock pull
SAE correction factor: .98
Rear wheel horsepower: 524.8 at 6125 rpm
Rear wheel torque: 521.2 at 3775 rpm
Run conditions: 72.21 degrees F, 29.50-in HG
Coolant temp 178 start, 180 finish
Boost- 9.44 max, 8.18 average
After Stage 1 kit
SAE correction factor: .99
Rear wheel horsepower: 548.1 at 6175 rpm
Rear wheel torque: 527.0 at 3675 rpm
Run conditions: 73.57 degrees F, 29.49-in HG
Coolant temp 172 start, 172 finish
Boost- 10.01 max, 8.06 average
Gains- Rhwp 23, rwtq, 6
Old 03-12-2012, 10:29 AM   #25
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Read the link in the caddy forum, this is the test BEFORE the stage I
KKreme15 is offline   Reply With Quote
Old 03-12-2012, 10:52 AM   #26
htron50
htron50's Avatar
Ahh!! Damn. Maybe, just maybe, GM is holding the ZL1's for a small "quality control" issue that results in this same type dyno! Can always hope!
Old 03-12-2012, 11:02 AM   #27
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
This CTS-V would be over 600 hp at the flywheel...maybe GM was very conservative with their numbers.
Or maybe GM boosted the power of the Wagon due to the extra weight..
Old 03-12-2012, 02:10 PM   #28
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
Originally Posted by hognutz View Post
by my understanding the magnusson moss is the federal lemon law but lemon law is actually slang. then states may have there own laws on top of it and if they are stricter then they would apply. just like minimum wage and any other program. federal rights/states rights.
there is nothing magical about the process or our court system as it blows. it is what it is. It cost both parties money and because of that a valid claim will usually get settled. In civil court everthing is a rebutable assumtion if you file they have to respond. been on both sides of it.
The MM act has nothing to do with lemon laws or mods done to the car. The act in a nutshell just states that any warranty given by a manufacture has to be honored, as long as the consumer abides by the warranty contract. The manufacture is not allowed to change the warranty, in the middle of the warranty term.
Remember the big thing is, the consumer needs to read and follow the fine print of the contract.
FE3 to ZL1 Zway Bar UpgradeZ and ZL1 ZuZpenZion PackageZ JusticePete Suspension / Chassis / Brakes 111 05-08-2013 11:38 PM
More Camaro ZL1 info!!! MS3DALE Camaro ZL1 Forum - ZL1 Specific Topics 94 06-24-2012 10:44 AM
ZL1 Production -- Will It Be Sufficient? GoldenBear Camaro ZL1 Forum - ZL1 Specific Topics 113 11-12-2011 05:03 PM
ZL1 vs Corvette- Why do people insist this doesnt exist? Impacts on pricing/perf? Arachnyd Camaro ZL1 Forum - ZL1 Specific Topics 60 09-19-2011 05:13 PM
