Caryle Racing
Old 02-24-2012, 09:46 AM   #1
GFORCE1320
Drives: 05 GTO
BullF-16's 9" IRS Install
BullF-16 Called us up awhile back to get one of our fabricated 9" IRS kits, after talking with him for a bit he decided to have it installed at SNL Performance in Fort Worth. SNL is also the home of Monster Clutch Company.
Since SNL is one of our largest dealers I decided I would come down for the install to answer any questions and to snap a few photo's.
Jim (BullF-16) chose the Strange 35 spline S-Trac pumpkin along with our big 35 spline inner stubs.
This way he gets a Lifetime warranty for the entire rear since the Strange S-Trac comes with a lifetime warranty plus all the Gforce parts are covered by our Lifetime warranty as well.
Our 9" kits also come with 300m axles, billet outer stubs and all the brackets and hardware to bolt right in.
Our 9" kit for the Camaro was designed to be bolted into the IRS Camaro, it's much more then a stock housing, it's a fully fabricated housing using all laser cut and cnc machined parts plus it's fully tig welded in our jig.
The face plates are 3/8" thick and the covers are 3/16" thick. We designed our housing for use in 2000+hp applications but it works great in a stock Camaro as well since it bolts right in with many pumpkin options available.
Just one look by customers and they see why our fabricated 9" is the bad boy on the market!
For Jim's 9" kit, we used a new driveshaft that we have been working with Dynotech Driveshafts to develop for the new Camaro.
It is an aluminum shaft with no cv joint on the front. This greatly reduces the weight on the nose of the shaft. This eliminates vibrations and gives the car a nice firm feel.
It uses an aluminum splined slip assembly in the front, it's not anything like the old steel slip shafts from the old days.
Dynotech has been making and selling shafts like this to the GT500 Mustang guys for a while now and they just love them.
The shafts are spun on Dynotechs high speed ballancer and tested before leaving Dynotech.
The great thing about the new shaft is it dropped a little over 9 lbs over the stock shaft. The stock shaft weighed in at about 24 lbs, the new Dynotech shaft weighs in at just 15 lbs.
We will be offering these new driveshafts for OEM replacement shafts in the very near future at a great price.
The install photo's speak for themselves, it took about 5 hours for the removal of the stock parts and install of the 9" kit. Jim also had a clutch installed so we were there all day.
Jim is a very happy customer to say the least
Here is Jim's 9" laid out before we packed it up for the trip to SNL (Monster Clutch Co.)
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****14.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****15.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/DS****18.jpg[/IMG]
Here we are at SNL Performance in Fortworth
First off we got everything unpacked and laid out for assembly.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****40.jpg[/IMG]
Step 1 is installing the studs in the housing and putting the pumpkin in.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****43.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****41.jpg[/IMG]
Dont forget to put a bead of silicone around the pumpkin, our housings are precision machined so no gasket is needed.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****45.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****47.jpg[/IMG]
Next step before tightening down the studs is installing the inner stubs to make sure the pumpkin is lined up with the bearing bores.
Again, a little bit of silicone around the bearings to seal the stubs in.
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****49.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****57.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****85.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****88.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****90.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****91.jpg[/IMG]
[IMG]http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/BullF-16%209%20Inch%20IRS%20Install/DS****96.jpg[/IMG]
Next up was installing the new Dynotech driveshaft
All done except for putting cat back on
We didnt have to cut anything on the Stainless works cat back, just had to loosen some clamps and twist some pipes here and there to get everything to clear.
GFORCE1320 is offline   Reply With Quote
Old 02-24-2012, 09:47 AM   #2
GFORCE1320
Drives: 05 GTO
All the photo's can be seen at www.photobucket.com/bullf-16
Old 02-24-2012, 11:18 AM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Excellent write-up Chris! I am one happy customer. Only 200 miles left on the clutch and rear end break-in then i can let loose and not worry about leaving parts all over the street.
The car drives better than stock and the tranny feels more connected to the motor. Thanks for driving down to oversee everything....Now thats customer service!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-24-2012, 08:49 PM   #4
BullF-16
BullF-16's Avatar
One hundred miles more till all is broken in! Couldnt resist and hammered on it a bit to get this annoying crotch rocket dude away from me. I guess he thought his wheelys were impressing me. I think it ended with me impressing him. Got a big thumbs up from him at the end of it when he caught back up. No speed limits were harmed in the filming of this episode!
also a shameless bump for GForce engineering and Chris for this truly amazing setup!
Old 02-24-2012, 09:00 PM   #5
GFORCE1320
Drives: 05 GTO
Isn't that part of the break in process? LOL
I bet he was surprised !
Old 02-24-2012, 09:38 PM   #6
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
That things looks very solid, and I can't say enough about how awesome that was to help you install the product. Cheers to EForce.
I bet you can't wait to slam the pedal into the ground.
calbert1999 is offline   Reply With Quote
Old 02-24-2012, 10:07 PM   #7
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Very nice setup! I really do like the way the new driveshaft is made. The slip joint is nothing like you imagine, it is super tight.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 02-24-2012, 10:19 PM   #8
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Great install and nice lifetime warranty...
Good stuff Jim.
Old 02-25-2012, 12:34 AM   #9
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
looks good , but take it easy on them new gears..def better set up then the old style m6 dshaft
mikepage0007 is offline   Reply With Quote
Old 02-25-2012, 10:16 AM   #10
BullF-16
BullF-16's Avatar
Finished the break in last night. I took the car out this morning on the back roads and did some high speed testing. Only got to 140, did not want to push anything. Smooth a glass, not a single noise or vibration felt. Could have easily pushed past 150 but haven't changed the diff fluid yet.
Old 02-25-2012, 10:27 AM   #11
GFORCE1320
Drives: 05 GTO
Excellent!!
And to think some tried to say that shaft isnt for high speed.. that is down right silly
That new driveshaft is the most innovative product I've seen in a long time, right behind our fabricated 9"
Old 02-25-2012, 12:21 PM   #12
Steve@SNL/Monster Clutch
Drives: 2014 SS
Always a pleasure working on your car Jim, and nice seeing you Chris, it's been a while.
Glad to hear your enjoying it, this was by far the easiest install on one of these we've done. Very simple bolt in, no cutting, welding, or cussing necessary!
Steve@SNL/Monster Clutch is offline   Reply With Quote
Old 02-25-2012, 12:30 PM   #13
BullF-16
BullF-16's Avatar
Hey Steve, welcome to Camaro5! Awesome install from you guys BTW! You guys always impress
I'm gonna post a thread in the Texas section to give you guys some credit.
Old 02-25-2012, 12:51 PM   #14
GFORCE1320
Drives: 05 GTO
It was good seeing you and your crew again too. I need to get down more often, I love the DFW area.
And agreed, our Camaro 9" kit is one of the best designed products we've come out with yet!
Gforce Engineering Fabricated 9" IRS GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 210 02-25-2012 10:20 AM
*Sale* Driveshaft Shop 9" IRS, Axles, Driveshafts.. Sales @ ECS Transmission / Driveline 18 02-09-2012 03:34 PM
Anyone with a 9" IRS Conversion? Irreverent V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 25 05-28-2011 09:20 AM
Come check out our 9" IRS kit at CamaroFest GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 04-18-2011 03:39 PM
Introducing the Gforce Engineering fabricated 9" IRS kit GFORCE1320 Transmission / Driveline 1 03-04-2011 11:25 AM
