Old 04-29-2009, 06:33 PM   #1
Travis64
Travis64's Avatar
Drives: 2011 Camaro 1lt rs auto 4-9-11
in the V6 do they say to change the oil every 3k miles or 5k?
most new cars oil change is every 5k miles i hope this one is too
Travis64 is offline   Reply With Quote
Old 04-29-2009, 07:06 PM   #2
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
The computer has a program based on driving cycles, distance, etc. to tell you when to change the oil. More highway trips, and it will extend further. On my 05 cts (3.6L v6), I went over 10,000 miles between changes, based on what the computer told me. This is with mostly highway driving. These engines use synthetic also, which typically gives you some more time between changes, and the computer takes all of this into account (since they recommend synthetic from the factory).
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Old 04-29-2009, 07:11 PM   #3
pfflyer
pfflyer's Avatar
Drives: 10 SS 6M IOM
Change the oil based on what the oil monitor dictates. The V6 should use Mobil 1 as in the CTS and based on your driving you might change it once a year. Don't change it any more than you have to. It's a waste of money.
pfflyer is offline   Reply With Quote
Old 04-29-2009, 07:13 PM   #4
Travis64
Travis64's Avatar
cool thanks
i drive 25k miles a year so i think i might have to change it more then that.i hope its not a pain in the ass to change the oil in these cars
Old 04-29-2009, 07:13 PM   #5
Chevyrocker
Weekend Rockstar
Chevyrocker's Avatar
Drives: Depends on the day...
OLMS (new acronym for oil life monitor system?) is prettty accurate. It takes into account how many times you start and stop the car, temperatures, average speed, etc. You can go up to 10,000 miles before changing. My wife's Malibu got it's first oil change @ 8,700 miles and it was still at 21%.
Shortcuts can slow you down...
Chevyrocker is offline   Reply With Quote
Old 04-29-2009, 07:14 PM   #6
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
Can you really rely on the oil warning thing? I've only seen it in my truck once. And I usually change it every 8k+ miles (synthetic).
UCF w00t is offline   Reply With Quote
Old 04-29-2009, 07:34 PM   #7
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
I rely on the oil warning thing in my 2002 GMC, except when I'm lazy or busy and go a lot longer than it says. I've got 183,000 miles and it's still going strong.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-15-2009, 05:23 PM   #8
bob2the2nd
Drives: CGM 2LT RS
it better be more than 5k, hell i would venture it will routinely hit 10k without any questions.
between using synthetic and the fact that it has a lot of oil i would imagine this engine would probably have no problem in the 10k+ mile range.
As at least some comparison i drive around a V6 alero (3.4 liter) which uses regular oil only takes 5 or so quarts. i get 6-7k miles out of an oil change pretty easy. Now most of my driving is highway miles but still. the Camaro has a slightly bigger engine with a much bigger oil reservoir. the discussion for this car starts in the 7k mile range and like i said im sure goes into the 10k mile range depending on type of driving.
bob2the2nd is offline   Reply With Quote
Old 05-15-2009, 05:29 PM   #9
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
i change every 5,000 KM. no matter what the sensor says. i think it is best for the car, and if it helps prevent further mechanical problems, then ill do it every 5,000 KM (about 3,000 miles)
btw i only drive like 10,000 KM a year (6,200 miles), so twice a year really doesnt break the bank
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day
bluch is offline   Reply With Quote
Old 05-15-2009, 06:52 PM   #10
DEW
Drives: Hoopdee
7.6 quarts of Mobile 1 just might break the bank for some of us!
DEW is offline   Reply With Quote
Old 05-15-2009, 07:56 PM   #11
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
9 qts of RP is a lil pricey as well. oh wait, thats for my SS
I piss excellence
and fart awesomeness
Old 05-19-2009, 09:29 AM   #12
iwannagofast
Paranormal Hunter
Drives: 1968 Chevy Caprice
I usually change it around 4,000 to 4500 miles and go till the OLMS says 55 to 50 %. I trust it, but to me going below 55% like a failing grade.
1968 Chevy Caprice-300+HP of 396 BBC Glory
2008 Chevy Cobalt Special Edition-Econo Drag Car
iwannagofast is offline   Reply With Quote
Old 06-04-2009, 06:45 PM   #13
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
I followed the computer on my Pontiac G6. It had 6600 miles when it called for the oil change. I changed it and sent a sample to Blackstone Labs in Indiana. They said the oil was still good and I could run it to 7500 miles! I was running Castrol Syntec.
bono83 is offline   Reply With Quote
Old 06-04-2009, 09:45 PM   #14
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Number 3's computer did not request an Oil Change til nearly 10,000 miles. But keep in mind, half of that was highway to California and back.
The computer calculates oil condition based on load, rpm etc. to determine when the oil needs to be changed. It is quite well thought out and tested. The oil change shops will still want you to go 3,000 miles, but your car knows better than them.
HA! You have a car so smart it wants to save you money for gas to do burnouts.
I mean it wants to save you money.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 07:25 PM
Synthetic? shroomjohn Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 09-18-2008 01:31 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 09:02 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
