Solo Performance
Old 02-26-2012, 05:39 PM   #1
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
Advice on installing a skip shift eliminator on my own?
Hey guys,
Did I quick a search and didn't find anything, although my question is odd.
So I've got a skip shift eliminator waiting for me back at home. I'm wondering if it's possible to install the eliminator without a lift? All I've got access to are jackstands and a low profile jack. I'm hoping it'll just be cramped but I can still do it.
Also, any advice and tips would be great!
Thanks,
Chip
hightower is offline   Reply With Quote
Old 02-26-2012, 05:49 PM   #2
jpizzle007
jpizzle007's Avatar
Drives: '10 LS3, '11 328i, '78 El Camino
you can definitely install it without a lift. Just jack up the rear or front and you will be fine. I used my race ramps and that was more than enough.
Nothing to it, I used a small straight screwdriver to get the plug undone and then its just plug and go (tuck it back up).
Custom stainless steel catch-can, Halltech Yellow Jacket CAI, T-304 MBRP 3" CB, Solo HiFlow Cats, TSW Interlagos Matte Black, Nitto Invos 275/315, SkipShift Eliminator, MGW ShortThrow Shifter, Flux Capacitor - fully tweeked
jpizzle007 is offline   Reply With Quote
Old 02-26-2012, 05:53 PM   #3
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
I think you can do it. Jack it up in the air to give you a little more room. Oh, and read this first:
http://www.camaro5.com/forums/showthread.php?t=205520
1968 Camaro convertible, LS1 & T56, Texas Speed 228R cam, 3.73 posi, 17" Torque Thrusts
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust SOLD! Now in a 2016 Challenger Scat Pack Shaker, M6
ckaram is offline   Reply With Quote
Old 02-26-2012, 06:14 PM   #4
Nessal
Drives: Exige, Miata, Ghia
Yup it's easy. Just make sure to install it correctly. It's the plug closer to the front of the car that is a little bit harder to get to because its near the top of the transmission.
Nessal is offline   Reply With Quote
Old 02-26-2012, 06:15 PM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
+1 You just need enough room to get under there. It will take longer to get the jack stands in place than to actually plug in in.
Old 03-09-2012, 03:03 PM   #6
Cincy10SSRS
Cincy10SSRS's Avatar
Drives: 2010 2SS RS M6
With the GM GFX on this car I can't drive up (forward) on my ramps anymore (that I used to be able to use on the V6 I had previously) but I was wondering if I could back up onto them and have room enough to install the SKE I got recently from APEX? I'm not at home right now so I can't measure the height of the ramps but they're a standard size and I'm curious if they would raise the transmission area up enough to slide under there and have doable access?
Cincy10SSRS is offline   Reply With Quote
Old 03-10-2012, 09:02 AM   #7
jpizzle007
jpizzle007's Avatar
you need race ramps bro. I have ground effects and they work great. Not sure if you have the rhino ramps or whatever, but if you have the money to spare they are a good investment.
Old 03-10-2012, 05:12 PM   #8
hightower
LS3 Black Widow
hightower's Avatar
I have the same ramps you do and they BARELY clear. I know if I had GFX they wouldn't work.
It was scary changing my oil with those ramps, haha. I'm going with jack stands next time around.
Speaking of, where does everyone recommend I put my jack stands and jack the car up from?
I wish I had the spare cash right now. :(
Old 03-10-2012, 05:31 PM   #9
Synner
Drives: not stock
Just buy a 1x10 or 2x10 from Lowes and set it in front of the ramp. Instant extra clearance.
Old 03-10-2012, 11:08 PM   #10
hightower
LS3 Black Widow
hightower's Avatar
Well see my problem is with the front bumper AND with the rear of the wheel well. Once I get up to the top of the ramp and go over the little lip (so the car settles on the ramp), the rockers almost smack the lip as the wheels roll past it.
Not sure if that's what the problem the other guy was having with GFX.
Old 03-10-2012, 11:48 PM   #11
Synner
Drives: not stock
Then do it for both front and rear wheels. By raising the rear slightly on the wood you reduce the severity of the angle so it should give you more clearance up front at the rear of the wheel well. Problem solved. My consultant fee can be paid in beer.
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 07:27 PM
V6 Skip Shift? B.A.Brunswick V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 10-08-2010 10:42 AM
$26.95 Skip Shift FREE w/ purchase of Hurst Billet/Plus 2 Shifter Apex Paul Transmission / Driveline 9 04-23-2010 07:08 PM
St. Louis, MO Tune Special - Turn off Skip Shift or AFM! DSteck V8 Bolt-Ons & Tunes 3 04-19-2010 03:20 PM
Performance Numbers - Skip Shift fireresq157 5th Gen Camaro SS LS LT General Discussions 16 03-23-2009 12:59 PM
