Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas > Local Marketplace
Old 02-27-2012, 12:22 AM   #1
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Snow Performance Stage 2 Boost Controller Meth kit $200
SOLD
I got this with my turbo kit but never got around to installing it. It is a perfect working used kit. I did not get the instructions with it but they are readily available on line. This kit comes with a stainless steel tank (not the small plastic one) This kit retails for $423.
Snow Performance : Stage 2 Boost Cooler?
I'm asking $200 picked up or $225 shipped. Call or text for faster reply 972-814-4550
Stage 2 Boost Cooler™
This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and driveability is the result. It can be used on any forced induction engine: carbureted, fuel injected, turbocharged, positive displacement or centrifugal blowers. The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower engines will work, but it might take more work to dial in the delivery. For higher boost applications (over 25psi), the controller can be upgraded to our VC100 unit. Now with Lifetime Warranty - please see details.
Kit includes:
• UHO (Ultra High Output) Pump
• 3 Quart Reservoir
• Digital Variable Controller
• 2 Nozzles To Cover a Wide Range of Horsepower
• All Required Hardware Needed For Installation
SUX2BU is offline   Reply With Quote
Old 02-27-2012, 08:54 AM   #2
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
So when u putting that turbo in ginger
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 02-27-2012, 10:41 AM   #3
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
The turbo kit has been on The Beast for about 2 1/2 years.
Old 02-27-2012, 08:12 PM   #4
sasquash1984
502 RWHP N/A
Drives: The yeti
Wait where's the time
Old 02-27-2012, 08:15 PM   #5
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
It was recorded over
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 89 02-20-2015 09:43 PM
TVS2300 & 1900 Pulley Info & Size ... 8aStang Forced Induction - V8 17 06-11-2013 12:21 AM
LSR Performance stage I& II kit 2quick Suspension / Chassis / Brakes 3 05-20-2011 03:24 PM
Modern Camaro Performance Parts - www.PartsTaxi.com PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 10-06-2010 05:26 PM
Roush Stage 3 Blackjack Mustang TAG UR IT General Automotive + Other Cars Discussion 16 05-21-2007 08:32 PM
