| Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection Anything related to keeping your Camaro clean and in good cosmetic condition. |
Thread Tools |
![]() Drives: 2012 2LT/RS 45th Vert Join Date: Dec 2011
Detail spray in foam gun for rinse and dry?
OK... here's a chance to shoot down a crazy idea. :-)
There are many suggestions to use the Adam's detail spray when drying off the car to avoid water spots. (I do use that method currently.) What would happen if I put the detail spray in a (clean) foam gun instead and use that to do the final rinse of the car before drying? Would that work as well as spraying on the 'normal' way? |
Virologist in the making
Drives: 2010 VR SS/RS LS3 Join Date: Aug 2009
You don't need a lot of detail spray to do it normally. This way your proposing would either waste detail spray or use up the detail spray in the foam so quickly you would just be rinsing the car with plain water in a few seconds.
6000, Delivered to the customer - 12/21/09 ![]() |
#3 | |
I used to be Stieger....
You really don't need a lot of detail spray. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 Avalanche Join Date: Mar 2010
You'd burn a lot of product (which I'm sure would be great for business LOL) but not see a huge benefit from it. You only need to mist each panel, the amount that would pump thru a foamer would be pretty heavy... way more than you'd need. Also keep in mind the foam work (is driven) by the force of the water pulling product thru the head... you'd be diluting the DS so heavily and putting so much more water on the car in the process that you'd likely just end up with more spots.
I like where you're head is at, but the reality is that you'd probably only make matters worse.
Thank y'all for the feedback.
#6 |
OIF Veteran
Use a leafblower then detail spray.
| Tags |
| detail spray, dry, rinse, water spots |
| Thread Tools | |
| detail spray and clay bar | jatt5ab1soorma | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 12 | 01-17-2012 12:38 AM |
| Adam's grit guard question | bigwayne3000 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 27 | 02-27-2011 10:11 PM |
| Whats the proper method for dust removal | Strokedhog | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 35 | 12-01-2010 08:40 PM |
| Detail Spray | Uncle Harvey | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 29 | 11-01-2010 06:23 PM |
| Adam's Detail Spray Leaving Spots | Ironfall96 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 5 | 07-22-2010 07:55 PM |
