SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 02-28-2012, 09:58 AM   #1
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Jack minimum height requirement
At what height after you start cranking the jack up on the front side do the wheels come off the ground? I'm looking into buying a jack and I've seen lots of ranges from 13" to 29". How much do I really need if I want to take my wheels off?
Also, what kind of cheap economical tool allows you to put the correct torque on the lugs for the wheels?
Old 02-28-2012, 10:14 AM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You'll need a low profile jack to get properly under the car. I use this one from Harbor Fright, it works great:
http://www.harborfreight.com/25-ton-heavy-duty-floor-jack-with-rapid-pump-68049.html
You'll be off the ground enough in 3 pumps.
You'll need a torque to torque the lugs. HF sells them rather cheap but the are also cheaply made. If you’re just going to do light to medium duty work I use this one from Auto Zone ($22) and it's worked just fine. Have used it several times to torque my lugs to 140lbs with no issues.
http://www.autozone.com/autozone/accessories/Duralast-3-8-in-drive-torque-wrench/_/N-25fw;jsessionid=0C8C05C35C678F318EF926BBCE3F471A.d iyprod5-b2c15?itemIdentifier=914017_0_0_
FSP tuned: 377/389
Old 02-28-2012, 01:59 PM   #3
ihaveacamaro
I like teeth.
Drives: #198
Thanks for the info. Do I need a low profile? I've heard others talk about using normal ones... I'm trying to save money where I can, but I'm getting 3 ton Jack stands though so safety still comes first!
Old 02-28-2012, 02:57 PM   #4
nyrfan
Let's go Rangers!
nyrfan's Avatar
If you don't get low profile, then you difinatly have to drive up on some wood to boost the car a bit for a regular jack.
FSP tuned: 377/389
Old 02-28-2012, 03:28 PM   #5
Bill F
Bill F's Avatar
Drives: 2011 CGM 2LT/RS 2005 Silverado Z71
I bought a regular floor jack (as opposed to low profile) because I can use it on all of my vehicles. I just drive the Camaro up on 2x8's to get the proper clearance. And I think the lift range on my jack is in the 19-20" range. More than enough to get the Camaro and my wife's car up off of the ground.
TEAM LLT
VMaxx TB, MRT v1, Roto Fab CAI, Custom Painted Bowties, DT Headers(On order!)
Bill F is offline   Reply With Quote
Old 02-29-2012, 11:47 AM   #6
ihaveacamaro
I like teeth.
Drives: #198
Did you make the 2x8's yourself or cut them yourself? Mind taking a pic?
A good cost effective floor jack JWoj3540 Garage / Tools Discussions 15 02-24-2012 12:26 AM
best floor jack and stands for the money S-eatin-grin 5th Gen Camaro SS LS LT General Discussions 22 11-15-2011 12:18 PM
Just thought I'd share TAG UR IT Off-topic Discussions 33 05-12-2011 03:04 PM
where do you jack up the car if you have a flat or oil change /also wheel lock photos camarossrs2150 5th Gen Camaro SS LS LT General Discussions 30 11-10-2009 11:45 AM
If the El Camaro makes it to production.... Silverado General Automotive + Other Cars Discussion 8 02-21-2008 10:17 AM
