Solo Performance
Old 02-28-2012, 05:50 PM   #15
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Not bad, but I must say I like my original better.
Very nice for the money though.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 02-28-2012, 06:47 PM   #16
kenkartasasmita
COTW [4/23/12]
kenkartasasmita's Avatar
Drives: Camaro Of The Week.
you again!!! aaahhhh where did u get that thing??? hehe
Originally Posted by Nightfall View Post
C.A.M.A.R.O- Constantly Adding Modifications Addiction Relentless Obsession
2010 Camaro V6 1LT | Kooks Catback Exhaust + MBRP exhaust tips | TF3 Stripes | GM Transformers Emblem and Door Sill | Stillen splitter | GMX rear diffuser | K&N CAI | Pulstar iridium spark plugs. | Gm High Wing Spoiler | BBK LT Headers | BMR 4 Point Strut Bar | BMR 1" Lowering Springs | ZL1 Side Skirt | Black Ice-olator | Trifecta Tune |
My Build Thread
kenkartasasmita is offline   Reply With Quote
Old 02-28-2012, 07:08 PM   #17
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Originally Posted by Lukeko View Post
Ofer - we're you able to install the front splash guards. Also do you either of you think that if you got an extra set of the rear splash guard as depicted in this thread, it could be installed in the rear of the front wheel well to give added protection to the gill area? I'm not sure if the side rocker alone is enough protection?
Thanks.
here you go the front.
Old 02-28-2012, 07:58 PM   #18
Tribute
Tribute's Avatar
Drives: 2012 SLP ZL770 #17 (Hugger Orange)
Only way to install with bumper off?
My Build Journal
Tribute is offline   Reply With Quote
Old 02-28-2012, 08:34 PM   #19
twentytwelvebee
twentytwelvebee's Avatar
Drives: 2012/2ss "transformers edition"
you have to remove the 3 T15 screws in the fender well lliner and the splash guards go behind it. their are also 3 new screws that you have to install. they go through the outside of the wheel liner and into the splash shields. kinda hard to explain but if you get a set you'll see what i mean.
twentytwelvebee is offline   Reply With Quote
Old 02-29-2012, 08:49 AM   #20
Tribute
Tribute's Avatar
Thanks twentytwelvebee. Quick side question. Where did you get your taillight tint from and what percent? Looks good. Did you cut out the front strip area?
My Build Journal
Old 02-29-2012, 09:08 AM   #21
Jekyll-N-Hyde
I put the FU back in FUN
Jekyll-N-Hyde's Avatar
Drives: 1969 SS 396 , 2010 Camaro SS
Very cool
Jekyll-N-Hyde is offline   Reply With Quote
Old 02-29-2012, 10:05 AM   #22
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Been waiting from my ZL1 rear splash guards to arrive at the dealer I ordered them from a couple of weeks ago. Regarding the front splash guards, it appears they will fit on an SS front end and only require 3 holes to be drilled into the SS inner fender well for screws or plastic push type fasteners, is that correct ???
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers & rotors, BMR Trailing & Toe Arms, full rear cradle & diff bushings, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, ZL1 Brembo Brake pads, GTO clutch reservoir, LS9 cam, Comp Cam valve springs, Melling 10296 oil pump, CR 5 timing chain, LS2 damper, CAI Cold Air Induction, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 wheels w/Vredestein 275/40/20 & 315/35/20 tires, '11 Convertible spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat
flht99b is offline   Reply With Quote
Old 02-29-2012, 10:07 AM   #23
2SSRS@Gen5diy
It was faster for me to post was of the car so i was showing only.
Old 02-29-2012, 10:31 AM   #24
MIKnam67
MIC
Drives: 2012 SSRS 6sp man Blk
Is that a L79 Chevy II peeking from under that cover?
MIKnam67 is offline   Reply With Quote
Old 02-29-2012, 11:29 AM   #25
twentytwelvebee
i got them from headlightarmor, smoke tint.
Old 02-29-2012, 11:59 AM   #26
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
So the fronts don't bolt up at the rear of the front wheel wells ? What's the purpose of the fronts ? Doesn't look like these would keep things from flying up and hitting the sides of the car. Plus will these bolt up to a stock nose .
bee sting is offline   Reply With Quote
Old 02-29-2012, 12:02 PM   #27
copper3000
(aka) Troy & Maria
copper3000's Avatar
Drives: 2018 ZL1 Camaro
Will these work on an SS with ground effects?
copper3000 is offline   Reply With Quote
Old 02-29-2012, 12:02 PM   #28
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
why would you need one towards the front(plan on going fast in reverse?).
Shno's House of Z Number 3 Camaro Z/28 Forum - Z/28 Specific Topics 17553 02-12-2018 03:59 PM
CAMARO WIKI Tran Wiki 55 03-28-2017 01:04 PM
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
Ten Classic Chevys to Look for at Woodward Dream Cruise, Including Camaro ZL1 Tran 5th Gen Camaro SS LS LT General Discussions 24 08-19-2011 08:47 AM
JRE 3.73 rear end w/ posi installed.....questions Fiftydriver V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 4 04-17-2011 08:04 PM
