Old 02-29-2012, 11:05 AM   #1
caverman
caverman's Avatar
Drives: '69 SS Convertible
What is the break-in procedure for gears?
I'm probably going to get a set of LPE gears pretty soon. I know I need to break them in before really getting on it hard. I've seen/heard of a couple different procedures to do so I wanted to get the steps others have heard or done. Last thing I want to do is break some gears. These things aren't cheap at all.
Also, is it recommended to change the rear end oil after a short time in order to get any metal out?
Build Journal
Old 02-29-2012, 11:08 AM   #2
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Old 02-29-2012, 11:15 AM   #3
Russell James
Russell James's Avatar
All the gears I've ever bought come with break in instructions from the supplier. It's also on the gear companies websites.
Most say something like... several short drives, light accel and decel loads, cooling off time between each drive. You go through some drive cycles like that for xxx miles, then change the gear lube. Any noise after that break in and the pattern needs to be rechecked. No noise, change the fluid and have at it.
What you don't want to do, is take a long drive for the first couple drives or put heavy loads to it on those first few drives. It will be getting quite hot inside the diff on those first few drives. Short easy drive, cool off, repeat.... repeat.... repeat....
Old 02-29-2012, 11:21 AM   #4
toml_pa
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6
This is what my installer gave me. Also said to change oil after 500 miles.
AAM 3.91 Gear Break In Procedure
The break in is VERY specific.
-Drive 30-35 MPH for 20-30 minutes.
-Drive 55-60 MPH for 20-30 minutes.
-Come to a complete stop and let the diff cool (15 minutes minimum)
This is one cycle. Repeat this cycle 4-5 times.
If you don't do this EXACTLY, the diff WILL whine.
500 miles will be needed for a full break in.
toml_pa is offline   Reply With Quote
Old 02-29-2012, 11:44 AM   #5
caverman
caverman's Avatar
Thanks. Those are the gears I'll be getting and this is one of the procedures I've heard as well. It will be a little tuff to do exactly but I guess I need to mark off 1/2 a day to devote to just breaking them in.
Build Journal
Old 02-29-2012, 11:59 AM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
I just had a Gforce 9" conversion installed with 35 Spline S-trac posi unit and new 3.50 gears. The break in recommended driving at normal speeds for up to 50 miles, stopping for 30 minutes then continuing for another 50 miles.
Then repeat till 500 miles is accumulated.
I drove back from FtWorth but did not exactly follow the first part of this. I drove for about 65 miles, stopped for some food for about 12 minutes then continued on home. the rest of the breakin was driving around town at normal speeds for about 10 to 20 miles at a time the parking it for the day.
From my research, the big thing is not to let the lube get too hot. This is alot more critical for the higher rations 4.33 and up. I am at 3.50 and the drive home my RPMs were only at 1700. So i think its ok. I notice no noise or abnormalities. Only a very slight whine when coasting or not under load.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-29-2012, 01:43 PM   #7
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
If these gears are made by the same company as stock, why is break in required on these but not factory gears?
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 02-29-2012, 06:03 PM   #8
Big Daddy Kane
Big Daddy Kane's Avatar
Drives: Red 1SS
Same thing I was thinking.
Kooks LT Headers/catback exhaust, E-force supercharger, JRE fuel line upgrade, JRE differential, 3.91 LPE gears, Roto-fab intake, JRE tune, DSS Carbon Fiber driveshaft, MGW shifter, Hotchkis chassis braces
Big Daddy Kane is offline   Reply With Quote
Old 02-29-2012, 10:57 PM   #9
rick john
Drives: 2010 camaro ss
Good reading and good advise.... My car is in the shop now getting the 3.91's installed I should be picking it up tomorrow, however I have a 50 mile ride home on the freeway, I'm wondering if I should stop halfway and sit for 20 mins??
rick john is offline   Reply With Quote
Old 03-01-2012, 12:10 AM   #10
caverman
caverman's Avatar
My guess is you'll be fine going all the way home. But get it heated up then cooled down a few more times before hammering them. I will probably put at least the 500 miles then new oil before I hammer or race them.
Like someone mentioned, AAM mfg as the same as stock gears. I can tell you that I drove my car hard right off the bat and the gears haven't been any issue at all.
Please post up your initial thoughts once you get them.
Build Journal
Old 03-01-2012, 07:57 AM   #11
allmotor
movin' down the motorway
allmotor's Avatar
Drives: Summiit White 2SS/RS/M6
I'm having 3:91 gears installed next week and JRE is 142 miles away. Considering the AAM break in routine above, should only take me a week to get home...
417 stroker - Florida Speed and Power
allmotor is offline   Reply With Quote
Old 03-01-2012, 09:56 AM   #12
inferno camaro
You guys running 3.91s, are you running any 1/4 mile stuff? lingenfelter says you will top out at115 at 6700 rpm in 4th gear with a6
Old 03-01-2012, 11:21 AM   #13
Merc
In The Circle
Merc's Avatar
Pumpkin has run 12.35 @ 113 up against the rev limiter in 3rd gear with the stock gears. Hoping the LPE/JRE/LPW 3:91 set up will make the difference. My diff builder wants four or five heat and cool cycles before I romp on it.
Old 03-01-2012, 12:55 PM   #14
rick john
Thanks Caver.... I should be getting the call to come pick up my car today or tomorrow. And i will take it easy driving home and do a couple of the heated and cool off runs before I let it rip.
And double fatty, I am an ls3 6 speed w/ cam, c.a.i., Lt's, 3 inch, high flo-cats, dyno tune 6 months ago @ 440whp. But my gear installer is going to re-run the car on his dyno-jet before and after he puts the gears in, so I too am anxious to see what if any diference there will be... Running the 1/4 mile last year i was 12.7 w/ 3rd gear against the limiter @110. So it's gonna be a whole different ball of wax this year, I think.
Break In Period?!?!?! SimC33 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 87 07-07-2012 06:27 PM
Vicious break in: What kind of a difference can it make? AmericanMuscle4.6GT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 05-28-2010 08:13 PM
Who here did the OM Breakin vs Hard Break In? TJ91 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 46 09-28-2009 10:46 AM
The Real Break in Procedure.... DFollis Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 09-17-2009 05:42 PM
Proposed Bill to give New car buyers tax break GothamCamaro General Automotive + Other Cars Discussion 63 01-22-2009 02:48 PM
