Old 02-29-2012, 04:33 PM   #1
Neil's BlackZL1
Neil's BlackZL1's Avatar
Drives: Black 2012 Camaro ZL1 #740
Talking cold Air
Does anyone know if adding a Cold Air Induction will void any ZL1 warranty?
With $5.00 per gallon gas looming, it would sure be nice to get a extra few Miles per gallon. O.K., The extra HP wouldn't hurt either...
Neil's BlackZL1 is offline   Reply With Quote
Old 02-29-2012, 04:40 PM   #2
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
The only issue with CAI intake is that the filter is a wet oil filter. Now if the oil gets on the MAF sensor it can cause miss readings and send bad data to the computer.
If you do what CAI stats in their instructions, you shouldn't have an issue.
armysig is offline   Reply With Quote
Old 02-29-2012, 04:42 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
No. The only way it voids your warranty is if they find the cause of the problem to be your aftermarket CAI.
Click to view my build thread
Old 02-29-2012, 04:49 PM   #4
CAM....ZL1
CAM....ZL1's Avatar
Drives: 2012 ZL1
my dealer tells me that if you take off the factory intake, and install an after market one ,that is a Mod. and damage will not be covered.
CAM....ZL1 is offline   Reply With Quote
Old 02-29-2012, 05:19 PM   #5
The Stig
The Stig's Avatar
Your dealer is an idiot. They have to prove that your mod is what caused the problem. Check out the Magnuson Moss warranty act.
Old 02-29-2012, 06:20 PM   #6
Neil's BlackZL1
Any brand recommendations?
Old 02-29-2012, 06:59 PM   #7
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
There are many good CAI brands out there. Roto-Fab, Cold Air Inductions, ADM's cai. The bigger problem is no one has one for the ZL1 yet
Version I
Jannetty Racing 550 RWHP Street Brawler Package,
Powered by TVS2300 Maggie
http://www.camaro5.com/forums/showthread.php?t=100385
Version II
416ci stroker/4L80e
701rwhp 750rwtq
build and tuned by
SPI-Performance
69 Rebel is offline   Reply With Quote
Old 02-29-2012, 07:02 PM   #8
The Stig
The Stig's Avatar
No company currently is offering a CAI for the ZL1.
Old 02-29-2012, 07:28 PM   #9
Neil's BlackZL1
Thank you for all the great info!! You guys rock. Can't wait to get off 3000 status and get her built!!
Old 02-29-2012, 09:14 PM   #10
Mr.R
Mr.R's Avatar
Drives: ZL1, Genesis, Grand Cherokee
I would love a CAI. I'd like to see the wording on the warranty for track use. Someone said on the forum that it doesn't apply if you make modifications. When I spoke with my ordering manager, he said a CAI shouldn't affect the warranty - I'll want that in writing...
Mr.R is offline   Reply With Quote
Old 03-01-2012, 07:44 AM   #11
ADM PERFORMANCE
Drives: 2016 CAMARO SS
We have had them finished for over 1 month
Now.
We have built 3 zl1 clones and 2 more in the works
The previous build was here -
http://www.camaro5.com/forums/showthread.php?t=166197
and here
http://www.camaro5.com/forums/showthread.php?t=161495
We knew we were up against to much boost but we wanted adjustability,So we turned to our friends at Lingenfelter for their 2 piece upper pulley system(We used stock balancer off an LSA)The Largest Blower Pulley LPE offers is a 2.55 " which gives 2-3 psi average over a stock CTSV or ZL1 Blower Pulley.Lingenfelter will be making us a stock pulley size in 2 piece config for pump gas tune.
The car has the ADM LS3 Conversion with a GT 11 Cam,Stainless Power Headers,Stock Heads with Dual valve springs,ADM ZL1 Race Intake,Tr6 Plugs
ZL1 Fuel Pump,63lb injectors.
We removed the TVS 2300 MAGGIE for a SMALLER BLOWER (ZL1 TVS 1900)
644 RWHP on 111octane through the stock automatic transmission and 3:45 gears.
All I can say is VERY IMPRESSIVE
We also have Zl1 RACE SCOOPS - http://www.camaro5.com/forums/showthread.php?t=205876
ADM PERFORMANCE is offline   Reply With Quote
Old 03-01-2012, 11:14 AM   #12
tnspd
tnspd's Avatar
Drives: 18 Camaro ZL1 1LE (WILSON)
Now.
does the intake add in additonal HP / torque numbers and does it reduce the or add to the boost at all?
tnspd is offline   Reply With Quote
Old 03-01-2012, 11:31 AM   #13
The Stig
The Stig's Avatar
I can't imagine they have any data on that. I mean wouldn't they need a ZL1 to run tests on
Old 03-01-2012, 12:36 PM   #14
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It very well might. While you may not alterring too much, there's a carbon trap in the OEM intake (if I'm not mistake - I haven't seen a ZL1 airbox yet...) and you are changing parts, so... It will be interesting to see if there are any significant gains from a CAI. We all know that cooler air makes more power, however, GM's also said that ZL1 has a special dual-inlet intake. There are no resonators in the inlet elbow, like CTS-V, to choke and add turbulance, to the air, so it would seem to me that ZL1 might very well be starting off with a great piece already. Depending on the size of the inlets, there may be restrictions there, however, that may only be in the event of making more power than simple bolt-ons.
I'd suggest reading the current issue of GMHTP. A customer of ADM (one of our Sponsors) brought a '12 CTS-V in, completely stock, with somewhere around 860 miles. They performed a baseline dyno (520 RWHP), and added an inlet elbow (a rigid piece that won't suck closed like has been alleged with OEM rubber elbows), and removed the ONE inlet scoop, and enlarged the scoop opening (nearly doubling the total opening area). They re-dyno'd the 'V and picked up more than 20 RWHP with NO tune. ADM went on to complete their Stage I package, and ended up adding a total of another nearly 70 RWHP, but that's a little beyond the scope of your post. Get a look at that article for at least the intake mods'. Understand, though, that ZL1's intake will be less restrictive (like I said - two inlets and no resonance chambers in the elbow), although, it's rated at more power (which requires more air...), it will likely have less restriction that the 'V's. I believe ADM also has a scoop, too, though, that you should have a look into
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 257 03-27-2018 01:52 PM
Cold Air Inductions (CAI, Inc.) | In Stock | FREE CLEANING KIT AND SHIPPING! JDP Motorsports V6 Bolt-Ons & Tunes 32 09-19-2012 09:25 AM
CEL - P1682 PSU SS Tuning / Diagnostics -- engine and transmission 4 09-29-2011 07:27 PM
RAM AIR MYTH OR TRUTH JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 06-18-2010 11:41 PM
AirAid Cold Air Intake anyone? FLYNNZL1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 01-01-2010 09:05 PM
