LSR Performance
Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions.
Old 04-26-2012, 10:20 PM   #51
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Originally Posted by camaro104 View Post
The dash kit blocks the gages just a little, half of the top two. There was a recall on the dash kit but I think it's all good now, I myself didn't have a problem tho I had the kit exchange and until now ( knock on wood) I still have no issues..... oh, it's not that bad taking the dash kit apart.
Everything is all Alpine.....
Thanks for the info, does your steering wheel controls work OK? I've read a lot of complaints that these controls are hard to get working.
OHIOSS is offline   Reply With Quote
Old 04-26-2012, 11:55 PM   #52
Thyshallsmite
Drives: 2011 Grand sport c6 corvette
i would totally get this kit if not for the fact that pandora app only works with an iphone
Thyshallsmite is offline   Reply With Quote
Old 04-27-2012, 09:34 AM   #53
camaro104
camaro104's Avatar
Drives: 2010 CGM Camaro
Send a message via AIM to camaro104
Yes the steering controls works flawless, its plug and play.....
Pandora works with any phone you just need to plug one on the auxiliary headphone jacks plug to your phone and stream it.
camaro104 is offline   Reply With Quote
Old 04-29-2012, 09:32 PM   #54
montej23
montej23's Avatar
Drives: 2011 VR Camaro
does your heated seats work with the alpine dash kit?
montej23 is offline   Reply With Quote
Old 04-30-2012, 09:31 AM   #55
camaro104
camaro104's Avatar
Oh yes it does..... I'll tell you I don't have not one....well Only one issue, the voice on the nav. Turn by turn does not work and I think it's cause I disconnected the center speaker not sure but when I get around to it I'll repost my findings.....
Old 05-01-2012, 01:06 AM   #56
xqwzit
xqwzit's Avatar
Drives: 2011 SIM 2SS/RS 6M
I'm working on that, I took some pictures of the fin antenna plug and'm looking for an adapter. That's good for the sirius radio but not for the navigation.
The connector is different from you stock to aftermarket for xm? I was able to connect my pioneer right up to my GMC Duramax to use the factory roof xm antenna.
xqwzit is offline   Reply With Quote
Old 05-01-2012, 09:09 AM   #57
Cory1520
Drives: Chevy Camaro 2SS 2010
400 BT required?
Did you have to install the 400BT interface to retain bluetooth? I bought the same kit but an unclear on if I need to purchase it. If you did not use the 400 BT is your steering wheel controls ok with hands free ? Tks Cory
Cory1520 is offline   Reply With Quote
Old 05-01-2012, 09:24 AM   #58
camaro104
camaro104's Avatar
No, if you got the Alpine W910 you don't need the interface, it's with the radio..... The radio has a headphone jack that plugs to the harness that came with the installation kit that plugs right in to the back of the radio for the Steering wheel controls......
Again it's plug and play if you using the Alpine install kit and the Alpine W910 unit.
Old 05-01-2012, 11:01 AM   #59
Cory1520
I bought the 900bt, but it also says it is bluetooth ready. Just wanted to make sure. Thanks! I think the 400bt is for cars w/o bluetooth capability ( I think)
Old 05-04-2012, 07:00 AM   #60
montej23
montej23's Avatar
Weird question maybe but these after market nav systems is their a subscribtion u have to buy and if not how does the data get updated? And is it worth it and is the voice turn by turn come over the system as it typically does factory?ctor
Old 05-04-2012, 07:01 AM   #61
montej23
montej23's Avatar
Oh and does anyone have the HUD system with a aftermarket decks and if so is there any issues?
Old 05-04-2012, 08:00 PM   #62
erftbll81
Drives: 2012 Camaro LT
OP since you have the same stuff i just bought Alpine w910 and alpine Dash kit (KTX-CMO).
A few questions for you,
Do i need any adapaters/cables for the antenna?
Do i need anything extra for SWC? (or does the KTX-CMO do this already)
DO i need a harness? or does the w910/KTX-CMO have that built it?
Is the Aux input that is inside the little drawer or center cabinet or w/e its called, is it still going to work?
I have had my car for a week weeks and i never use the XM radio or Onstar and i dont believe i will, so i dont mind not having those features.
Thanks.
erftbll81 is offline   Reply With Quote
Old 05-04-2012, 10:32 PM   #63
camaro104
camaro104's Avatar
Good question, there is no subscription to the navigation tho i was told there is a charge if there is an update for it. not sure if that's true.
the turn by turn voice come on just like the factory system does, volume on the radio lowers when turn by turn voice comes on.....
Old 05-04-2012, 10:33 PM   #64
camaro104
camaro104's Avatar
Don't have HUD so cant help here.....
Old 05-04-2012, 10:50 PM   #65
camaro104
camaro104's Avatar
Thanks.
OK, for the radio antenna you don't need an adapter but if you want to use the XM antenna you do, I myself have not gotten around to looking for one yet but you can get one.....
The steering wheel control doesn't need any extra harness, the two (radio and installation kit) have all the plugs for it to work, plug and play.....
The USB and audio ports inside the center console does not work, the radio comes with its own USB, aux, iPod harness which you could run into the center console if you like, I have mine coming out the side of my glove box, easy to get to.....
hope I covered everything.....
Old 05-05-2012, 03:32 PM   #66
FAT-SS
FAT-SS's Avatar
Drives: 2010 Camaro SS
camaro104,
I am installing my Perfect FIT kit (with the INA-W910) in my Camaro today and I hit a roadblock. Where do I connect the yellow/blue wire and the yellow/black wire from the harness that came with the kit. The install instructions that came with the kit lists where they go but not specific enough for me to figure out. Please help.
FAT-SS is offline   Reply With Quote
Old 05-05-2012, 05:23 PM   #67
erftbll81
Thank you
Old 05-05-2012, 05:29 PM   #68
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Thanks.
I can answer 2 of you questions. If you got to monoprice.com this usb cables will work. You take off the cover and and unplug the usb cable . it has the same plug as the mono cable. Here is the web site site
http://www.monoprice.com/products/pr...seq=1&format=2
If you can solder and have a ohm meter you get the aux port to work. You will need a 6 ft rca cable and some heat shrink tubing. Take the camaro aux and put insert one end of the RCA cable now take you ohm meter check each end of the connector and rca plug and find which has 0 ohms. Make a diagram of which tip matches the connector. Now cut one end of the rca and strip the wires. Now solder the wire to the pin matching your diagram and heat shrink your tubing. That what I did to mine and it works perfectly. To bad I did not keep my diagram.
Caddy
Caddy
Caddyroger is offline   Reply With Quote
Old 05-05-2012, 09:25 PM   #69
camaro104
camaro104's Avatar
Originally Posted by FAT-SS View Post
camaro104,
The yellow and blue wire goes connected the the ebrake wire, remove the passenger side of the console panel, on the bottom of the ebrake handle there's one wire, tap the yellow/blue wire to it.
The yellow/black wire is tricky, I tryed to tap to the stop light switch and failed so i went out and purchase the PAC-TR7, tap the y/black wire to it plus + & - power. It let's you turn on the video with out having to press the brake and pulling the ebrake. Those two wires need to be hooked up for all the radio features to work.
Old 05-05-2012, 09:28 PM   #70
camaro104
camaro104's Avatar
Wow i was thinkin of doing something like that but really have the time, thanx for the heads up I'm going to try it.....
Old 05-06-2012, 03:22 PM   #71
FAT-SS
FAT-SS's Avatar
Got it. Thank you very much for your help. Now I just have to figure out how to get the HU into that tiny space with all those wires, connectors, etc.
Old 05-06-2012, 04:04 PM   #72
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
There is no subscription required for navigation on the Alpine, or really any of the major brand receivers at this point. You do have to pay for the updates though, and they are typically done through the USB port or SD card slot depending on manufacturer.
CrutchfieldBrooke is offline   Reply With Quote
Old 05-07-2012, 07:35 PM   #73
CreeperRS
CreeperRS's Avatar
Drives: 2010 Camaro 2SS, 2002 V6 3800 RS
Thanks for the info, was working on the same thing. I didn't even think of using RCA cable. Doh! I was looking for the wrong part. Thanks a lot!
CreeperRS is offline   Reply With Quote
Old 05-12-2012, 12:55 PM   #74
erftbll81
I just finished installing this kit and everything works perfect except AM radio, i get absolutely nothing. Any ideas?
Old 05-12-2012, 10:27 PM   #75
camaro104
camaro104's Avatar
I notest there was two radio antenna lead wires coming out the harness, one was plug to the oem radio the other was just hanging there, maybe you plug the antenna lead to the other or wrong one. Both antenna lead (plug) looks the same.....
Alpine W910 Head Unit Hack pyr0b0y Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 14 02-03-2012 10:27 AM
SS Custom Install (Alpine, Hybrid Audio, Mosconi, Focal) AVS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 12 07-13-2011 09:50 PM
Any Alpine INA W900 reviews? SS Drifter Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 3 05-08-2010 09:05 AM
