| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
John
Drives: 2010 2LT/RS Summit White Join Date: Dec 2009
P0300 AND P0301 CODES
Heres the run down. 2010 V6..... Prior to installing BBK Longtubes and hi-flow cats, the car had no issues, no check engine light....after installing the headers, the CEL came on, which I assumed was from the o2 sensors....Installed trifecta tune, but now I have a P0300 (engine misfire) and P0301 cylinder 1 misfire code
When I clear the codes, the light goes away. I can drive the car around all day, the light stays off. But as soon as I let the car cool down and sit for a while, the next time it cold starts the light comes on. I have heard of people having this issue on the V6 engines and that the dealer can reflash the ECM....but wont that take off the trifecta tune? I feel like it can only be one or the other (reflash the computer to get rid of the misfire code, but then the CEL will be on for the o2 sensors) HELP!!!
#2 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
You have a Problem with your Number 1 Plug or connections.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
John
checked the plug, it looked good...switch the plug from cylinder 1 to cylinder 3 and still got the cylinder 1 misfire. All connections looked good, thinking it could be a possible injector issue.....
I do notice when the car sits and i do a cold start, it feels like the car is missing when the idle is way up, and then once the idle goes down to normal it feels fine...but thats when the light comes on
![]() Drives: 2009 Pontiac G8 Join Date: Feb 2011
Change out the #1 plug you broke it
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
if it is coming on after the car heat cycles, then you should be looking at the connections for #1. Start at the coil pack and work your way down to the plug. Since you moved the plug and the misfire stayed in #1 you definitely have an electrical issue with that cylinder. Most likely at the coil pack.
The problem with these issues is that they can look good, but not be. Unplug and reconnect all the connections for the problem cylinder as you go.
2011 Camaro 1SS/RS
Hotchkis Chassis Brace, Rotofab Intake, Hurst Short Shifter, BMR Springs / Trailing Arms / Sways, Nitrous Outlet 150 Shot, SubThump Stealth Box, TSP 1 7/8 Headers, VMax TB, JRE Scoop, Rotofab Washer Relocation, JRE Tune |
#6 |
John
Could it be a bad injector also?
#7 |
possible, but highly unlikely. You can test that the same way. Swap the injector to #3 and see if it follows.
2011 Camaro 1SS/RS
#8 |
![]() Drives: 2010 Camaro SS,2008 Hayabusa Join Date: Jun 2010
whats the word on this. Did you get it fixed.
#9 |
John
we are going to be tearing into it tomorrow, was able to get a new injector so we will see if that helps also...will keep you posted
#10 |
John
put in a new injector over the weekend and so far so good. No check engline light after cold start, no rough idling, car feels like it runs smoother. Its only been a day, so ill give it a few more days before i am fully convinced the problem is gone
#11 |
Cool
Fastest camaro in OKC |
| Thread Tools | |
| Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles | steeleshark2 | Tuning / Diagnostics -- engine and transmission | 7 | 03-15-2013 09:03 PM |
| Misfire cylinders multiple codes :/ | MichaelH | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 01-19-2011 04:19 PM |
