Rick@Livernois
Old 02-29-2012, 09:29 PM   #1
martinezj454545
Drives: 2011 Camaro LS V6
Headlights Scratched while installing halo.
Okay is there a place i can just by the clear lens of the headlights that's the only part that's getting to me. When i was installing my halos some of the super glue got on the lens and dried before i noticed and now it looks like its just scratched and i cant deal with this failed mod any longer. i don't want to buy the whole new headlights just the lens, is this possible to do anyone?
martinezj454545 is offline   Reply With Quote
Old 02-29-2012, 09:30 PM   #2
camaro2lt
camaro2lt's Avatar
what side lens is it i might get one in about 2 weeks
Old 02-29-2012, 09:55 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
Just open the headlight back up and put some nail polish remover on it. It'll come right off. and to answer your question, no you cannot buy just the lens.
EDIT: you really shouldn't use super glue to seal the headlight back up, you want to use exterior grade silicon.
Click to view my build thread
Old 02-29-2012, 10:13 PM   #4
martinezj454545
glue
its the driver side lens that looks scratched off
Old 02-29-2012, 10:15 PM   #5
martinezj454545
super glue
i put nail polished on it right after i installed it and it still wouldnt come off but do you think goo gone could work? and i did not use super glue to seal it up it was just to make sure the halo rings would not more out of place and i did seal it up with exterior silicon.
Old 02-29-2012, 10:17 PM   #6
The Stig
The Stig's Avatar
Goo Gone would probably work.
Old 02-29-2012, 10:40 PM   #7
My Caroline
My Caroline's Avatar
Drives: Black 2011 Camaro LS
Be careful with acetone. The acetone in nail polish remover will etch the plastic housing. Try 70% isopropyl alcohol. Rubbing alcohol is usually 70% but make sure not to use anything stronger as alcohol is an acid and can melt certain types of plastic.
White Fender Hashes from Big Worm Graphix with Custom White Bowties
GM Factory Remote Start and Factory Key Fob
SS Fascia, Factory RS HIDs, Plasma P13W fog lights
Non-RS to RS and fog light harness by Gen5DIY
LED Interior, Trunk, and Licence Plate lights in white
ZL1 Spoiler with Gen5DIY harness
Factory NPP cat back
Blacked out tail light bezels
Factory 20 inch wheels wrapped in Nitto Motivos
Lowered 1.25inch on Eibach Pro springs
My Caroline is offline   Reply With Quote
Old 02-29-2012, 10:50 PM   #8
martinezj454545
will do thanks
Old 03-01-2012, 08:29 AM   #9
AACstyle
AACstyle's Avatar
Drives: www.CamaroLighting.com
Hate to be the bearer of bad news but Cyanoacrylate adhesives (like super glue) will actually etch into acrylics, even if you are able to remove the actual adhesive the lens will still be in bad shape. We really discourage the use of CA adhesives when doing these installations. I can try to find you a lens, will send you a PM.
www.AACstyle.com
AACstyle is offline   Reply With Quote
Old 03-01-2012, 09:56 AM   #10
The Stig
The Stig's Avatar
Send a PM to 2SSRS. He *might* have a spare lens lying around.
Old 03-03-2012, 09:44 PM   #11
martinezj454545
AAC
[QUOTE=AACstyle]What side are you looking for?[/QUOT
i am looking for the regular oem headlight lens for a camaro 2011 LS, mine where scratched while installing the halos from AAC. Do you have any?
Old 03-03-2012, 10:04 PM   #12
el ess A
formerly "el ess X"
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Alcohol is not an acid. In pure form, it has a pH of 7, as it has no hydronium or hydroxyl ions, which either are needed to change pH. True, there are some concentrations of alcohol that can affect certain plastic finishes by marring the surface, but it's pretty much non-reactive to most plastics.
I was under the impression that the lenses are polycarbonate, which aren't really technically plastic. I could be wrong. But if it is polycarbonate, then alcohol is a perfect cleaner for it.
I agree that the superglue will eat into some lens materials, and regardless if you get it off, the lens is hosed where glue contacted it.
Sorry about your troubles. You may want to look for a used lamp or lens somewhere to get the part you need. Good luck.
2010/2013 Camaro
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 03-03-2012, 10:09 PM   #13
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
^^ what justin said.
BUT!
there is another option but it not for the faint of heart you can try to use an acetone to remove the glue, it will distort the lens. you can wet sand and polish the inside of the lens again its not for the faint at heart but since your lens is damaged its worth a try
use 1000 wet then 1500 wet then 2000 wet sand paper to sand the general area work the around the affected area not just the glue spot. once you have sanded the area smooth use a buff ball with a triple cut compound to polish the area .
yes i have done this, not with ca glue but with scratched lenses using similar products just more professional
camaro4mybday is offline   Reply With Quote
Old 03-04-2012, 02:17 AM   #14
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
You can wetsand and polish it out if you know what you're doing. I've done it about 100 times.
THUMPER20X is offline   Reply With Quote
glue, halo, headlight, lens, scratched
2010 camaro eagle eye halo headlights CyberSS88 Exterior Parts & Accessories 16 07-13-2014 11:23 PM
For Sale RS Halo Headlights Like New. shy68 Exterior Parts & Accessories 19 11-29-2013 05:16 PM
WTB OEM Halo Rings (from RS headlights) 73vette Audio / Visual / Electronics/ Gauges / Nav 1 09-14-2011 11:04 AM
Double Halo headlights anyone? DIGthat2SS Cosmetics and Lighting Modification Discussions 4 10-12-2010 12:06 PM
Can Anyone Tell Me Where to get HID Halo Headlights and Fog Lights. atlang3lo Cosmetics and Lighting Modification Discussions 10 05-12-2010 05:23 PM
