BeckyD @ James Martin Chevy
Old 03-01-2012, 11:54 AM   #1
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
Clutch Sticking?
So in the morning when it's below 55° or so, the clutch stays about halfway down, until I manually pull it up with the edge of my foot. I don't have any other issues...What's causing this and how do I fix it?
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 03-01-2012, 12:15 PM   #2
cap384465
Drives: 2012 camaro ss/ls3 m10 transmission
never by a v6
my camaro was doing the same thing i go in the morning to start my car,but when my car was started n i depressed the clutch it stay stuck to the floor.after awhile third gear started to grind as well as second poping out i took it to the chevy dealer and there has beena reacall on the slave cylinder becouse of that they are going to replace the clutch and cylinder under warranty
cap384465 is offline   Reply With Quote
Old 03-01-2012, 12:31 PM   #3
Devryn17
Devryn17's Avatar
Uhhh...Why was my topic MOVED from transmission and driveline? I wasn't asking a f'n warranty question. My car has 50K f'n miles for f's sake.
Old 03-02-2012, 08:58 AM   #4
Devryn17
Devryn17's Avatar
See...This is why shit doesn't get answered around here.
Old 03-02-2012, 09:52 AM   #5
The Stig
knows 2 facts about ducks
The Stig's Avatar
It is more than likely due to dirty clutch fluid, in combination with the fluid being cold.
Click to view my build thread
Old 03-02-2012, 09:57 AM   #6
Russell James
Russell James's Avatar
Drives: '69 Z28, '10 NASA TA2, '15 1LE SS
Location: In the garage fixing stuff, track breaking stuff, at work paying for stuff. Or check the bar.
Ask your dealer for a copy of bulletins pertaining to clutch pedal sticking. I remember seeing something on repositioning the master cylinder for a cold pedal stick problem. You loosen it up, pull the pedal a certain way... retightnen the M/C. But, get the exact bulletin procedure.
As previously mentioned, changing the fluid helps if it has ever been overheated. I would do any bulletins first, then the fluid change, then as a last resort start changing parts like the slave cylinder...
Old 03-02-2012, 09:59 AM   #7
The Stig
The Stig's Avatar
moved back to the transmission subforum per your request
Old 03-02-2012, 10:02 AM   #8
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
have you ever changed the fluid?
ligenfelter also offers a clutch return spring you can add
I have a seperate reserve for the clutch and change the fluid at each oil change and haven't experienced this yet.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-02-2012, 10:15 AM   #9
Russell James
#PI0486
That's the bulletin number I was thinking of. Ask your dealer to show that to you. I found the number, but I can't find the bulletin. If anyone else has bulletin access maybe they could post it for you. If I remember it was basically loosening the pedal assembly, pulling the pedal all the way up and retighten while holding all the way up. Just repositions the pedal assembly to M/C better. I remember that was specific to the cold sticking problem.
That's one possibility, others being the fluid or slave cyl condition.
Old 03-02-2012, 10:52 AM   #10
Devryn17
Devryn17's Avatar
Thanks, all. I saw the TSB online, but it doesn't give the fix. Is this a powertrain warranty item? I replaced the brake fluid when I did the front pads. How hard is adding a separate resevoir for the clutch? Is it just the GTO part?
Old 03-02-2012, 11:03 AM   #11
The Stig
The Stig's Avatar
Yes its covered under the powertrain warranty, so no worries. Adding the seperate resivour is pretty easy. Maybe an hour and a half when it's all said and done.
Old 03-02-2012, 11:03 AM   #12
justa25thTA
yes its the GTO reservoir, go here http://www.camaro5.com/forums/showth...20#post3494820
post #405 was my solution
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 05:11 PM
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
deleted post Kubi V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 02-21-2010 06:35 PM
clutch sticking to floor BatmanX Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-21-2009 04:39 PM
Clutch sticking again KATHY63 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 13 09-21-2009 08:50 PM
