autoguy
Old 03-01-2012, 11:15 AM   #1
gorgeous-ss
Drives: 2011 ss/rs
Another header question
I will be installing stainless works headers with no cats. My question is
Would it be ok to drive from my house to the shop that is tuning it? Since more than likly it will throw a cel
Sent from my Eris using Tapatalk
gorgeous-ss is offline   Reply With Quote
Old 03-01-2012, 11:20 AM   #2
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
I will do doing my own header install very soon and had the same question for my shop who is doing my tuning. The said it would be fine. Someone else may want to chime in on that though because I would not take it as fact.
newagemuscle is offline   Reply With Quote
Old 03-01-2012, 12:25 PM   #3
hognutz
hognutz's Avatar
Drives: 2013 ZL1
the CEL is a no issue as the rear 02's are diagnostic only. as for weatehr it is save you just don't want to be lean. deffinatly don't get on it if you are worried at all. damage usually occurs under load.
could always install a wideband 02. then you will know if you are ever running lean.
2013 ZL1
2013 Dart
2004.5 Ram cummins
hognutz is offline   Reply With Quote
Old 03-01-2012, 12:25 PM   #4
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
You might make it, if it's close enough. As long as it's not too far, you might be safe, so long as you take it really easy. That's how it used to be on the older PCMs, but honestly, I haven't kept up with the newer PCM much; I have some catching up to do. I'm sure GM's programmed it to run rich, so as not to over-heat the cats', and I imagine opening up the exhaust is going to lean-out the AFR some, but I don't know if the PCM will command enough fuel, or it will compansate enough, but so long as it's a local shop, I'm pretty sure you'd be fine.
Talk to you shop, though, and make sure. There are also many Sponsors here that you could query. I'd suggest giving them an opportunity for your business if you haven't considered that already
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
Old 03-01-2012, 03:14 PM   #5
Dupontdon24
Dupontdon24's Avatar
Drives: 2010 Black 2SS/RS
I was going to start a new thread but will comment here. I talked to a local exhaust shop today on a price for muffler delete, new exhaust, and headers. He gave good prices and when I asked him about if the car needed tuned after the header install he absolutely not, that these cars reprogram themselves. Now hearing all the talk on here, its confusing when you hear two different things on alot of upgrades. He said hes done many of the new camaros. I'll post this in any thread if it would help, didn't mean to hi jack your thread, but thought this might be of light!SS
Dupontdon24 is offline   Reply With Quote
Old 03-01-2012, 03:24 PM   #6
steveo9043
steveo9043's Avatar
Drives: 2012 45th AE 2SS Coupe
You should have no problem running headers without a tune for a little bit. To say the computer programs itself is not true. There are two tunes in the computer of a SS. One is for high octane one is for low octane. It will not adjust the tune for headers.
If you are going with shortie headers you may not throw a code and you may not need to be tuned. but with long tubes you really should tune soon.
steveo9043 is offline   Reply With Quote
Old 03-01-2012, 03:34 PM   #7
Dupontdon24
so doing the 5-20 fuse pull doesn't do the octane setting. I always run 93, and always will. So the high octane fuel tune would be needed.?
Old 03-01-2012, 03:55 PM   #8
ADM PERFORMANCE
214-228-8782
Drives: 2013 ZL1 #138
You will be fine.
Can 1 person here answer why your putting headers on this car?
ADM needs to teach a class...Hmmmm
BTW- Careful what headers you buy,they may not fit...there are new problem areas the header manufacturers may not know about.We will be working in the future as we did in the beginning of the camaro 5th gen to see to it they get it right.
Andy Mages
Owner/Operator
214-228-8782
admperformance@gmail.com
www.admperformance.com
ADM PERFORMANCE is offline   Reply With Quote
Old 03-01-2012, 05:25 PM   #9
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Originally Posted by ADM PERFORMANCE View Post
You will be fine.
Lower pan? Tranny and or diff' cooling lines? Power steering (or lack there, so-to-speak) clearance? You mentioned different AC routing, too - no? I'm wondering if those shorties from ARH will work... That's the way I think I'm going to end up goin
Old 03-01-2012, 05:28 PM   #10
Dupontdon24
You will be fine.
Uhhh, I wondered the same thing, but alls I could guess is the 20-50 hp you gain plus sound, am I wrong or are most of new owners missing something? I don't understand why people replace a whole perfectly new exhaust system either(minus mufflers). I'am confused as hell now. Thought they were the biggest bang for the buck.
Old 03-01-2012, 09:49 PM   #11
ADM PERFORMANCE
214-228-8782
Headers on a supercharged car WILL NOT NET YOU HP without many more mods.
Headers on a naturally aspirated car completely different story.
I have been there countless times,If you dont believe me call the engineering department at LPE.
or
Call me and I will explain.
Header manufacturers(some very close friends of mine) will advertise just to sell their products...Make them guarantee gains in writing!
Now that we have that out of the way:
Modify(Incrase) the boost=Gain Hp and torque
Gain HP and torque=Need to tune
Need to tune = Voided Warranty(Most cases)
Voided Warranty= Find a great shop that will stand behind their work.
ADM Performance will be there for any service work required to your modified
ZL1.We have countless customers that have failure NON that no longer live with a GM Drivetrain warranty that enjoy their cars more now that GM or myself ever thought possible.
Just Google ADM PERFORMANCE and see for yourself or go here -
http://www.camaro5.com/forums/forumdisplay.php?f=75
2012 is going to be a great year for the new ZL1 and 2013 will only be better,Im looking forward to being there for any questions or comments that need an honest answer.
Hope this helps
Andy Mages
Owner/Operator
214-228-8782
Old 03-01-2012, 10:52 PM   #12
Dupontdon24
I'll be done with this thread after this. I dont remember seeing anything about a supercharged car on this thread. 100's of camaro owners on this site install headers on there camaros without being sc for some reason. We got off the main topic here. Oh, never said I didn't believe ya, the questions being asked and your answers you are giving are not coinsiding with one another. The question was, if headers are installed on a stock LS3, does the engine need tuned?
Old 03-02-2012, 05:33 AM   #13
ADM PERFORMANCE
214-228-8782
Your in the ZL1(Has a supercharger on it) section with ths post.Sorry never saw your putting headers on an LS3 .
Andy Mages
Owner/Operator
214-228-8782
Old 03-02-2012, 05:34 AM   #14
ADM PERFORMANCE
214-228-8782
Are you planning on putting headers on a ZL1?
Andy Mages
Owner/Operator
214-228-8782
Old 03-02-2012, 06:17 AM   #15
gorgeous-ss
Drives: 2011 ss/rs
I'm sorry I didn't see zl1 in the title I'm on my phone and just saw exhaust so I put this in here I actually have a '11 l99
AR Header Sale!!! Ragin Racin V8 Bolt-Ons & Tunes 15 06-27-2011 04:11 PM
Header gasket question rackmaster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 06-10-2011 05:14 PM
Novice Header Question Inferno2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 03-20-2010 11:19 PM
question about LT header codes-- AdamCzap Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 03-08-2010 05:29 PM
Header question brtaus Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 02-26-2010 03:35 PM
