Gen5DIY
Old 03-02-2012, 02:43 AM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
I need gears!!!
I have the v6 m6. what should i get? 3.73's or 3.55's??
2010_camaro is offline   Reply With Quote
Old 03-03-2012, 09:04 AM   #2
Jmiller
Jmiller's Avatar
Drives: 2013 Camaro 2SS 1LE
Get the 3.73. It gets you in the power band quicker and it feels like you gained 40 ft. Lbs of torque, with the 3.55 it feels like you gained 27 ft. Lbs of torque.
ADM LSA Supercharger Conversion, ADM air intake ,Stainless power 1 7/8 long tubes w/hi-flow cats, Chunnningham Motorsports stage 2 cam and custom Dyno tune from Starkweather Performance.
624 RWHP, 524 RWTQ
Jmiller is offline   Reply With Quote
Old 03-03-2012, 07:48 PM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
3.73's are the way to go- 3.55 not enuff for the $.
Remember you'll have to get your speedo calibrated for the new gears too.
Old 03-03-2012, 07:57 PM   #4
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
At least 3.73's....but why not 4.11's?
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 03-03-2012, 08:18 PM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I just installed a nine inch diff and went with 3.07 gears due to the power level I'm shooting for and to retain driveability... 3.45's are the stock gearing for the M6... Though you probably knew that...
There is more of a science to selecting the right gears than just picking a number...
Here is some interesting material to help you get started... Hopefully this will lead you in the right direction.
http://camaro5.com/forums/showthread.php?t=95142
Old 03-05-2012, 01:09 AM   #6
2010_camaro
ok if i went with 4.11's how much will that kill the streetable of the car? like what kinda rev's would I be looking at doing 70 in 6th gear
Old 03-05-2012, 01:59 AM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
4.11's might be too much on the V6. I would think 3.73's would be a better balance. Then again I'm not as familiar with the 6 banger.
9/26/09 Took delivery!
Old 03-05-2012, 02:04 AM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
If it helps here are the V6 manuals gear ratios
Aisin Warner AY6 six-speed manual (LS, LT)
Gear ratios (:1):
First: 4.48
Second: 2.58
Third: 1.63
Fourth: 1.19
Fifth: 1.00
Sixth: 0.75
Reverse: 3.67
Final drive ratio: 3.27
Old 03-05-2012, 04:09 AM   #9
Ventmaster
Ventmaster's Avatar
On the V6, any bigger than 3.73 and you won't bother to use 1st gear. You won't need to cause it'll be a "tractor gear" . Great for parades, but not much else.
A 3.91 might be a little fun, IF we had a decent 2nd gear synchro. But we don't.
And at highway speeds you'll be turning more RPM than you'd like, and burning alot more fuel.
Old 03-05-2012, 06:13 PM   #10
POWERFREAK
I.AM.
POWERFREAK's Avatar
Gear ratios (:1):
First: 4.48
Second: 2.58
Third: 1.63
Fourth: 1.19
Fifth: 1.00
Sixth: 0.75
Reverse: 3.67
wow, yes, a bit lower then the TR6060 ratios....OK, I say go 3.73's.
NY5thgen.com
Old 03-05-2012, 10:50 PM   #11
2010_camaro
3.73's it is. but who should I go with? I dont want a loud set of gears. I am putting dynamat all over my car this weekend. I mean all over!!! all the interior is coming out!
Old 03-06-2012, 11:44 AM   #12
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
While I believe the V6 probably won't stress the driveline enough to blow up 3.73 Richmonds for piece of mind I would spend the little bit more and get the LPE 3.73's. They are made by American Axel the OEM gear supplier and built to that standard.
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3453 02-18-2018 02:39 PM
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 12:38 PM
Richmond Gear Camaro gears RichmondGear V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 85 01-19-2015 11:43 AM
Question on my blown Richmond's for the experts Eric Baker V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 28 10-29-2011 10:59 AM
NEW PRODUCT: 2010 Camaro Richmond Gears - 3.73 and 4.10 Ratios tbyrne Transmission / Driveline 9 01-11-2010 11:36 AM
