Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 03-02-2012, 09:46 AM   #1
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
Replace oil pump or shim during cam install?
This has probably been beat to death somewhere, but after a lot of searches I haven't found a clear answer. I'm getting the cam replaced in my LS3 in a couple of weeks. The shop that's doing it told me there is no need to replace the oil pump. They do quite a few of these, enough that they have the cam and other parts on the shelf, and said they always just shim the spring in the pump that's in there. On the other hand a lot of the shops include a Melling high volume pump with their cam kits.
Is the shimmed GM pump as good as the Melling? I have read that the shims correct the tendency of the GM pumps to fail.
Has anyone had a Melling pump fail? I sure don't want to insist that they replace the pump and then have the new pump fail.
2012 2SS Convertible
CAI Intake, Solo Catback, RX Catch Can, VMAX Ported Throttle Body, LT headers with hi flow cats, BMR Trailing Arms
Comp Cams 227/243 cam, Magnuson supercharger, ZL1 Fuel Pump, ADM Fuel Pump Control Module, JRE Tune
Lee123 is offline   Reply With Quote
Old 03-02-2012, 09:59 AM   #2
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I have to agree with your Shop, If it isn't broke don't fix it.
More oil pressure Creates More heat and more drag on the engine.
High Volume Oil Pump can pump the Pan Dry and leave all the oil up top.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-02-2012, 01:54 PM   #3
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Back in the mid to late 70's I put a built 383 LT-1 in my 73 Corvette. The guy who built the motor did engines for the Corvettes that raced at Laguna Seca. One of the "tricks" he employed was to polish the lifter valley in the block and enlarge the oil return holes so the oil could return to the pan faster. Must have worked, as I never had ANY problems with oil starvation (or any probelms for that matter) even at 7,000 RPM. 2 years later I had the engine checked by a shop that ran top fuel dragsters and they noted my engine has less leak-down than their top fuel motors. My guy must have done something right.
Mods: Pedders Xa's, bushings, braided brake lines, Solution B sway bars, Hawk ceramic pads, Spohn trailing arms, Kooks 1 7/8 LT's, HF cats, Magnaflow 3" cat-back, MBRP rec tips, Cold Air Inductions black CAI, MGW short-throw shifter w/retro shift ball, Showstopper Engine Bling, Forgeline MD3P's 9.5 & 11", Conti DWS 275's & 315's. AAC plasma DRL's.
Proud previous owner of: 1968 327 Camaro, 1972 Camaro SS 350, 1978 Z28, 1979 Z28. 2010 SS is My 5th Camaro
My 5th is offline   Reply With Quote
Old 03-02-2012, 02:19 PM   #4
Lee123
Lee123's Avatar
Drives: 2012 2SS M6
Ted.
Thanks, Ted. I'll leave them alone about the pump and let them do it as they planned.
Old 03-02-2012, 02:35 PM   #5
dekan513
Drives: 2ss/rs
ive know ppl to do that on older engines which is about all i had untill i bought this 5th gen .
dekan513 is offline   Reply With Quote
Old 03-02-2012, 05:54 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
yes my shop said the same thing.
Old 03-02-2012, 11:24 PM   #7
1sikRS
Drives: 2010 silver ice 2ss/rs
so we shouldnt use a new oil pump??? i really dont feel like pulling everything off again to redo what i could have done in the first place. my car is only a every so ofter driver so i dunno what i should do i have the meiling ready to install now im torn lol
1sikRS is offline   Reply With Quote
Old 03-03-2012, 07:07 AM   #8
JANNETTYRACING
Ask your Self this, the pump in the Engine has a Track record of Working Well,
What does the pump Still in the Box offer for a Track Record, it has never been run.
High Volume Oil Pumps Like it or not are a Thing of the Past.
Oil Pump Technology is Way Past that.
My 760 HP 8800 RPM Small Block Runs 55 PSI Oil Pressure and it is a Standard volume $55.00 Oil Pump.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-03-2012, 09:38 AM   #9
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
yea this was one of my decisions when i added my cam..my installer said he thought it wasnt neccesary, but all the oil pump failures that i had read about were on the stock pump. had not read of any aftermarket oil pumps failing, so went with the katech oil pump. problem free here. but i think either way is ok.
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Unofficial 1/4 Mile 2010+ Camaro Fast List Merc Dragstrip, Tracking, Autocrossing, Driving Techniques Discussions 195 05-09-2013 01:45 AM
Everything LS3/L99 Oil Pumps ztsmith86 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 11-26-2012 11:22 PM
RX Oil Separating catchcan System Giveaway!!! SC2150 Sponsor Announcements / Giveaways / Contests 529 12-26-2011 12:41 PM
How to see if oil is in intake manifold? CamaroC-17 5th Gen Camaro SS LS LT General Discussions 53 03-23-2011 05:06 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
