Forced Induction - V6 V6 Supercharger, turbo, nitrous discussions
Old 05-09-2012, 03:52 PM   #276
SIXJAK
Drives: MO's only SC'd LLT.
This mod thingy never ends does it? Looks like I'll be getting this too.
SIXJAK is offline   Reply With Quote
Old 05-09-2012, 06:03 PM   #277
Mach
Mach's Avatar
Drives: White M6 1LT RS
Originally Posted by SC2150 View Post
The pump will work with anyones kit...as long as they can tune for it. Vince is working that out right now. Looks like just what we needed!!
Retails for $250 so affordable as well.
This is the missing link for serious HP!!!
Now FI will show the true potential of the LLT. 500 HP here we come!!
Hopefully Vince can work some magic.. Keep us posted Tracy.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 05-12-2012, 12:13 PM   #278
Make It Rain
Drives: 69 Z28
We just installed the high output fuel pump and are waiting for Vince to tweak for it. It works to well....throwing "high pressure" codes....it is what we hoped it would be but can run it with the extra pressure until vince can tweak it.
Numbers yet?
Make It Rain is offline   Reply With Quote
Old 05-13-2012, 12:03 PM   #279
SC2150
SC2150's Avatar
Drives: 2001 Camaro SS
We put the stock pump back on to go to Pony wars as Vince has not finished the tweaks for the new pump but he is confidant he will have it soon. We made some runs but had near zero traction on the launch even with the wider tires smoke1lt has on. No traction through 1st in boost at all, but pulled good through 2nd & 3rd. 60's were mid to high 2 sec so that cost a few seconds in overall ET. Should be some good videos comming up as there were a ton taking video of the runs. Had the RX Super Chiller finished on his and lots stopped and watched it in action also.
www.RevXtreme.com
941-721-1826
Turbo & Supercharging specialist
VMax porting development from the begining
RX Super Chiller
Old 05-13-2012, 12:29 PM   #280
Make It Rain
Drives: 69 Z28
Do you have 1/4 times?
Old 05-13-2012, 01:20 PM   #281
MINI HLK
MINI HLK's Avatar
Drives: LS A6
Humm now time to search utube. Wonder what I will put in. I guess the next thing is drag slicks. If your going to put 5K or 7K in the car what is another 1200 for some 18X10 rims with slicks . Glad you guys were able to enjoy sun and fun
MINI HLK is offline   Reply With Quote
Old 05-13-2012, 01:32 PM   #282
V6owner
I'm slow, lets race!
V6owner's Avatar
Drives: Rx Supercharged V6 Camaro
I can't wait to see the videos
2010 Camaro LLT *SOLD*
2012 Silverado 6.2L *CURRENT*
V6owner is offline   Reply With Quote
Old 05-13-2012, 05:10 PM   #283
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
Are you going to buy one?
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-13-2012, 05:55 PM   #284
Make It Rain
Drives: 69 Z28
Looking for something once I get some information. I've been reading this forum for a long time, and no one ever posts actual results. I am thinking of doing a couple systems for my sons, and want something that actually works.
Old 05-14-2012, 05:32 AM   #285
OKCwhiteKnight
OKCwhiteKnight's Avatar
Drives: 2010 2LT RS Camaro 2007 HHR Panel
Would the new pump have any bearing/effect on whether or not you need to use premium fuel? Same question if meth is used. I know you would want to use prem. at the track,but curious about daily driving performance.
2LT RS Oracle LED's.Heritage Grille.Eibach Pros
MRT V2.0.Techno LED Tails.K&N.JDP Color Halos 3dCarbon Body Kit. TL1 Hood Vents
OKCwhiteKnight is offline   Reply With Quote
Old 05-14-2012, 06:20 AM   #286
blackTT600
Drives: 2011 2LT M6 SC
The pump has nothing to do with octane of the fuel. The ability to go back and forth is all in the tune. As for the meth, I would think that even with the new fuel pump you would want the meth. It just makes it safer to run at higher power levels. It lowers the intake air temp allowing for more boost and a more aggressive tune. It's not needed right now, you can be FI with out it, but you can only run like 4-6lb's of boost vs with meth I think they are running like 8lb's of boost. And then with the new pump they are going to go to like 13-14lb's of boost I think. Maybe stop at 10 for a while see how the LLT likes it.
blackTT600 is offline   Reply With Quote
Old 05-14-2012, 09:05 AM   #287
smoke1lt
smoke1lt's Avatar
Drives: 2011 1lt/rs/sim
Thanks to Overflow and an awesome pic thread from Pony Wars this weekend http://www.camaro5.com/forums/showthread.php?t=223520 A few pics of my car at Pony Wars
RX-SUPERCHARGED/RX SUPER CHILLER/RX TB/RX PORTED IM/BLACK ICE-OLATER/BBK LT HEADERS/HFC/ARK-DTS CATBACK/EIBACH SPRINGS AND SWAYBARS/ORION SUBS AND AMPS...next mods RX od pulley ,3.91 gears
smoke1lt is offline   Reply With Quote
Old 05-14-2012, 09:12 AM   #288
smoke1lt
smoke1lt's Avatar
This is why i have a set of DR's waiting to go on the car when i get it back.Last year when i took the car to the track when it was NA I had no traction.
Old 05-14-2012, 09:20 AM   #289
Make It Rain
Drives: 69 Z28
Great to see your car running now! What were the 1/4 times?
Thanks
Old 05-14-2012, 09:34 AM   #290
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
I spy what looks to be the 1" thick Black Ice-olator plate.
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Trifecta Tune, Mike Norris Catch Can, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 05-14-2012, 01:27 PM   #291
Dashgalaxy
DashGalaxy
Drives: Inferno Orange 2013 ZL1
Thanks
1/4 times BUMP please.
Dashgalaxy is offline   Reply With Quote
Old 05-14-2012, 02:03 PM   #292
Make It Rain
Drives: 69 Z28
x3
Old 05-14-2012, 02:18 PM   #293
gahammerle
gahammerle's Avatar
It would be nice to see some IPF LLT drag times too.
Gordy
Old 05-14-2012, 03:05 PM   #294
Make It Rain
Drives: 69 Z28
I have seen their 1/4 times on the 2012, and dyno's on everthing else. I can show you where those are.
Could you show me where anything is on this system? I've been watching this build for 6 months. Thought they were close last week on a dyno when they got the new fuel pump?
Old 05-14-2012, 03:08 PM   #295
gahammerle
gahammerle's Avatar
But the LLT & LFX are different animals. Times may be similar but we don't know because they haven't posted LLT times.
Gordy
Old 05-14-2012, 05:39 PM   #296
SC2150
SC2150's Avatar
Best 1/4 mile times are still in the 13's due to traction issues, and only ran 14's at SGMP.....60' was 2.90!!!! Had to let out, ease back in, just went up in smoke. Pulled great 2nd & 3rd so looking at the incrementals we should have been running mid-low 12's but until we put sticky tires on.......and were not dynoing until Vince has the tune written for the new fuel pump.
BlackTT600 is right on concerning the fuel, etc.
www.RevXtreme.com
941-721-1826
RX Super Chiller
Old 05-15-2012, 09:22 AM   #297
Mach
Mach's Avatar
Tracy. Why are the FI V6's having so many traction issues? The top 26 bone stock V8's are better then a 13 second 1/4 mile. Wouldn't they be having the same traction issues?
Next mod: Done!
Old 05-15-2012, 10:26 AM   #298
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 2012 LFX/2011 EcoBoost F-150
They have wider summer only tires and a different rear suspension.
EFR Twin Turbo LFX-GPI Tune-ZL1 fuel pump-10:1 CR forged pistons-3.45 gear-Meth Injection-BMR Trailing Arms, Bushings & Sway Bars-Drag Radials-CircleD 4000 Stall-GPI Fuel Enrichment System
586 RWHP & 606 RWTQ @20 psi on 93 Octane (unlocked converter)
1/8 mile -- 7.158 @ 102.10 (20psi)
Build Thread
GretchenGotGrowl is online now   Reply With Quote
Old 05-15-2012, 11:10 AM   #299
SIXJAK
Plus most V6 autos have open diffs. However that is not the case with Smoke's car as it is equipped with the 6MT. I'm having rear cradle full bushing kit, trailing arms and diff bushings installed tomorrow....finally. Hopefully this will take care of suspension issues during launch. The other equation would obviously be tires. 18" Hoosiers and skinnies I'm leaning towards. (Sorry for the Yoda speak.) I'm wondering if I could get into high 11's with RX SC plus suspension and tires. I think it's doable especially with the new HPFP.
Old 05-15-2012, 11:40 AM   #300
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Still no numbers?
Current Mods:
Vararam | Borla ProXS Custom Axle-Back | Mace 25mm Insulator | MACE Ported Intake Manifold | And a few other things
Click here to visit my Build Thread!
First Gen5 Supercharged Camaro Jose Forced Induction - V8 19 01-09-2012 02:28 PM
The mighty LSA supercharged V8. Mr. Wyndham Camaro ZL1 Forum - ZL1 Specific Topics 137 05-07-2011 10:05 PM
Mika Salo (ex F1 / potential NASCAR driver) w/ 600hp Supercharged Camaro (VIDEO) Tran Camaro Photos | Spyshots | Video | Media Gallery 38 07-21-2010 09:41 PM
Let's say your SUPERCHARGED 'Z28' is dead... radz28 Camaro ZL1 Forum - ZL1 Specific Topics 91 09-08-2008 08:52 PM
GM Cancels Cobalt SS Supercharged Mr. Wyndham General Automotive + Other Cars Discussion 35 07-31-2007 01:00 AM
