Cold Air Inductions
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-03-2012, 12:06 PM   #1
BowenSS1
BowenSS1's Avatar
Drives: summit white ss2
ls3 conv. with Maggie and now codes p0354
Had ls3 conv. And Maggie installed drove about 60miles and got cel code P0354!!
Ignition coil 4 is this a pacific coil? What could cause this?if you are looking at the motor wwould this be the second coil on passenger side?I checked the connection to the coil and plug wire they are good.any other ways to check this.any help will be apreciated.
Sent from ghetto phone!!!
BowenSS1 is offline   Reply With Quote
Old 03-03-2012, 07:14 PM   #2
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
I did a google search and found this for ya. and yes on that coil pack. its like this. the first or front coil pack on the driver side is #1, then go to the passenger side thats #2 then back to the driver side thats #3 and so on...
The ignition control circuit is either grounded, shorted or open. Sounds like the #4 cylinder control module has one of these faults. You'll need a Digital Multi-Meter to check the circuit. You'll also need to know what to specifically look for so a trip to the dealer or a question to a knowledgeable mechanic (like FRC TOM) is in order. Good luck with the fix.
Seams Google is full of stuff like this on that #4 coil...
mgoodbar is offline   Reply With Quote
Old 03-03-2012, 07:16 PM   #3
BowenSS1
BowenSS1's Avatar
False alarm wrong code!! Miss heard the code the guy gave me all good now!
Praise god!!
Old 03-03-2012, 07:18 PM   #4
BowenSS1
BowenSS1's Avatar
Thanks for the info that's what I Seen also. I just jumped the gun!
