Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 03-03-2012, 03:53 PM   #1
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
new floor jack
Got question for u smart ones... is a 2ton low profile with a minimum of 2-5/8" gonna be able to fit under camaro with no gfx and 1.4 lowering springs.. thanks guys
nebchevy is offline   Reply With Quote
Old 03-03-2012, 03:56 PM   #2
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
I have a low profile jack and have problems getting under the nose. Mine isn`t even lowered.
Bo Tie 1 is offline   Reply With Quote
Old 03-03-2012, 05:14 PM   #3
nebchevy
nebchevy's Avatar
Thanks bud.... i got a 2ton low pro jack so i can get under to put exhaust and springs on with my new stands... hope it will work.
Old 03-03-2012, 05:20 PM   #4
Bo Tie 1
Bo Tie 1's Avatar
Back side should be no problem. I use ramps to get the front end up in the air.
Old 03-03-2012, 05:21 PM   #5
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
it should work even with the springs. I have one and it is tight, but will fit.
Worst case you'll just need a coule of 2x12 boards to drive the front up on so the jack slides under like we do for lowered vettes
2011 Camaro 1SS/RS
Cammed, Sprayed, and Beaten Daily.
Aries240SS is offline   Reply With Quote
Old 03-03-2012, 05:27 PM   #6
nebchevy
nebchevy's Avatar
Thanks everyone!!! Boards are a perfect idea.. wat kinda ramps you using
Old 03-03-2012, 05:32 PM   #7
Bo Tie 1
Bo Tie 1's Avatar
Picked up a set from here little pricey but nice quality.
http://www.discountramps.com/car-repair-ramps.htm
Old 03-03-2012, 11:40 PM   #8
RX SS RACERX
RX SS RACERX's Avatar
Drives: 2010 2SS/RS RJT
Tryhttp://www.raceramps.com/ raceramps. Also,pricey but alot of different options. Cheapest and works fine are 2x12's though!
9.75 @ 139mph, 1.41 60ft, 2010SS, JRE Built!
RX SS RACERX is offline   Reply With Quote
Old 03-14-2012, 03:41 PM   #9
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
I have the Tirerack low profile jack and it works great, but I still want a set of ramps to go with it.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 10-14-2012, 08:43 PM   #10
Hercules
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9
Was just ready to buy a low profile jack. Thought too much into it, 2x12's such a money saver. Great idea! Too much tought sometimes is a bad thing.
Hercules is offline   Reply With Quote
Old 10-19-2012, 11:35 AM   #11
fshog
fshog's Avatar
Drives: 2011 RS/2SS
You might want to go larger than a 2 T jack though.
fshog is offline   Reply With Quote
Old 10-19-2012, 12:17 PM   #12
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
I wouldn't go less than a 3 ton jack.
Also, I usually drive up on four blocks of 2 X 12's cut 12 inches long (one under each wheel) which raises the car 1.5 inches.
Old 10-29-2012, 02:31 AM   #13
gelboy1015
gelboy1015's Avatar
Drives: '10 2SS/RS, MKIII Supras
Arcan XL35 Jack is the one I use. Low profile with a 28" lift height. Goes under my lowered Supra fine and its like 2" off the ground lol.
2010 Camaro 2SS/RS
- LS3, M6. -
Build Thread/Mods List
gelboy1015 is offline   Reply With Quote
