Cold Air Inductions
Old 03-03-2012, 04:09 PM   #1
etmx183
etmx183's Avatar
Drives: 2012 Camaro 2LT RS
Question 2012 LFX triple threat ny-trex installation question
I have the kit 110028 but no where does it tell you which direction to point the single spray nozzle? Should it go toward the intake or the throttle body?
It also never states which way to install the spacer for the nozzle, with the hole for the nozzle up toward the hood or down toward the ground. I just want to make sure what seems obvious to me may not be what is correct.
Thanks for any help.
etmx183 is offline   Reply With Quote
Old 03-03-2012, 04:14 PM   #2
cjt037
boost+v6=me=:)
cjt037's Avatar
Drives: Turbo'd 6er
Installing that your self seems really risky
http://www.camaro5.com/forums/showthread.php?t=185528
435.7 RWHP 405 RWTQ
JUST A LITTLE V6... Try me
cjt037 is offline   Reply With Quote
Old 03-03-2012, 05:22 PM   #3
JustFresh
JustFresh's Avatar
Drives: 2011 1LT RS M6 Black
+1 you do not seem to know what you are doing and that could mean catastrophic failure of your engine if you pool up fuel and nitrous in your intake system and you could get hurt....
Please call a local shop and have them install this and tune it for you so that you are safe
JustFresh is offline   Reply With Quote
Old 03-03-2012, 07:07 PM   #4
etmx183
etmx183's Avatar
I appreciate the concerns and thank you for them. I have done many systems in my 50 years. The problem here is that one page shows injecting the spray nozzle along with the flow of air and later it states the nozzle face toward the throttle body. In this case of the 2012 V6 Camaro this is impossible to do both. The air flow toward the intake is one direction the flow toward the throttle body is the other direction. The throttle body mounts to the front of the intake the spacer with nozzle goes between the throttle body and intake. I am just trying to get clarification. This is the first system from Ny-trex I am installing and want to make sure what their way is. All other systems I have installed always spray with the air flow path. I will post photos of the throttle body in my album to view. Thanks again for your concerns.
Old 03-06-2012, 10:24 AM   #5
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
the nozzle comes up from the bottom, and sprays into the path of airflow.
h2oplay is offline   Reply With Quote
Old 03-06-2012, 11:09 AM   #6
Abstrak
Abstrak's Avatar
Drives: 2012 AGM Camaro LS / Team LFX
I love your ride ET it was cool hanging out wit you guys this past weekend good luck with the installation. I remember you showing us how you just started to install the system.
Abstrak is offline   Reply With Quote
Old 03-06-2012, 02:14 PM   #7
etmx183
etmx183's Avatar
Thanks H2oplay. I was sure that was how it should go, but never afraid to ask questions. I spoke to the folks at DEI also. Nww to get the Trifecta tune for the spray and cut it loose.
Old 03-07-2012, 06:50 AM   #8
h2oplay
Winners find a way
h2oplay's Avatar
no problem et, I sent my datalog from a 100shot dyno run, Vince said it looks good with the canned trifecta tune, no changes where needed for me.
I'm really pleased with the triple threat system so far, the install was simple and clean. I'll try it out next month, test and tune at the track every saturday in april.
Old 03-11-2012, 08:21 PM   #9
etmx183
etmx183's Avatar
H2O,
Good luck with the test & tune. I am hoping to add some videos from my track runs to my Youtube. Do a search on Youtube for ETMX193 , yes 193 not 183 like on here. Some runs with my bike and other crazy crap. My Go-pro camera worked good on my bike and going to do some vids from the Camaro soon.
Old 03-12-2012, 07:55 AM   #10
h2oplay
Winners find a way
h2oplay's Avatar
checked out your vids, that bike is sick! nice run....
Old 03-12-2012, 10:45 PM   #11
etmx183
etmx183's Avatar
Thanks,
Not bad for a 4 cyl import.I just had to have something to do when I finally reached 50 Y/O.
2012 camaro, lfx, nitrous, ny-trex
MGW Shifter Installed "Pics" 2012 LFX V6 Hellfighter Camaro V6 LFX Engine, Exhaust, and Bolt-Ons 30 01-14-2014 01:24 PM
Vinyl Rally Stripe Installation Question... Dforce0990 USA - Texas 36 05-01-2010 07:14 PM
Corsa installation question...... 2010SSRS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 02-15-2010 04:27 PM
2012 MY Question lafountain 5th Gen Camaro SS LS LT General Discussions 6 08-16-2009 08:42 AM
