Old 03-03-2012, 04:40 PM   #1
JackRabitSlims
Drives: 2010 Camaro 2SS RS LS3
Hurst Shifter Dynomat Locations
Hi,
Going to install shifter soon. Has anyone put the dynomat for the shifter. To be honest those pictures suck that come with the instructions on where to put the dynomat. Can anyone give me a better explanation? Thanks.
JackRabitSlims is offline   Reply With Quote
Old 03-03-2012, 05:30 PM   #2
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
Show me also please.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 03-04-2012, 01:31 AM   #3
Nessal
Drives: Exige, Miata, Ghia
I believe that it calls for dynomat on the area where the cross pin goes through the shifter that is held on by the C clip. Then if that is not enough, you add another strip a little bit above that on the shaft itself.
Nessal is offline   Reply With Quote
Old 03-04-2012, 09:02 AM   #4
douellette
douellette's Avatar
Drives: 06 Mitsubishi Eclipse GT
why would you need dynomat on the shifter?
douellette is offline   Reply With Quote
Old 03-04-2012, 12:00 PM   #5
JackRabitSlims
So put the C-clip on then dynomatt around it? and if still noise another strip higher up?
Old 03-04-2012, 12:01 PM   #6
JackRabitSlims
Supposed to keep the shifter quiter because it is all made of metal where as the stock shift knob attaches by being pushed on and is made of leather and other stuff that absorbs sound.
Old 03-04-2012, 12:29 PM   #7
Nessal
From my understanding, yes. You put the dynomat on after everything is assembled. The rattle supposidely is coming from that connection so the dynomat is supposed to dampen it. Then another piece around the shaft above that if rattling is still there. I would just do both since you're down there already. Also put some teflon tape around the threaded portion of the stick where the shifter ball goes on. Supposed to help some as well.
The rattle drove me crazy. But when i switched to the stock knob it all went away.
Old 03-04-2012, 03:07 PM   #8
JackRabitSlims
Thanks for your help. I spent yesterday just trying to figure out how the hell to get my car up in the air to actually do this job. I don't have a flat driveway and all these other issue. Figured it out, now just waiting for a warm day to do it.
Old 03-04-2012, 09:06 PM   #9
Nessal
Hey, good luck with it! I know that the kit comes with 2 piece of dynomat. I would use one FULL piece on the shaft that connects from the front of the car(not the shifter shaft itself), then a smaller piece where the C clips hold the cross pin in, and then whatever is left over on the shifter shaft itself where it connects to the lower shifter shaft(where the two bolts that holds the billet shifter together).
I know the kit came with 2 neoprene pieces as well but I honestly don't feel those are a good idea because they can slowly cause those two shifter bolts to back out over time.
The directions did say that the shifter has a natural tendency to rattle and is part of the function. it also says that there will still be some noise after the dynomat.
Old 03-04-2012, 09:23 PM   #10
JackRabitSlims
Thanks for the help. Where you are telling me to put that dynomat is confusing as hell to me. So one full square on the part that new shifter conects too that is orginal from the car, than a small piece around the C clips and then another piece where the chromed upper stick meets the lower stick right by the bolts? did you put it around the bolts, below the bolts? Hurst could have done a better job with their pictures and description of where to put the dynomat. Any other advise on how to do this?
Hurst Billet/Plus 2 Shifter $199.95, add an APEX Skip Shift Eliminator for only $10! Apex Motorsports Transmission / Driveline 36 08-08-2012 08:28 PM
GM Factory Hurst Shifter GPC1 Transmission / Driveline 10 06-10-2011 06:44 PM
Pic's of Aftermarket Shift Knob on Stock shifter stalk jammer174 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 12-04-2010 09:49 PM
Dumb question (sorry in advance) Hurst Shifter 2Muchmark 5th Gen Camaro SS LS LT General Discussions 0 04-16-2009 05:52 PM
