RDP Motorsport
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-04-2012, 06:06 PM   #1
lgowens2
lgowens2's Avatar
Drives: 2012 Camaro 45th Aniversary 2SS L99
2012 SS L99 dying after shift
My wife took the car to put gas in it ( Shell 93 ). After that she ra. A few errands and all of a sudden the car starts dying after shifting gears. Idle sounds good, it runs good once it gets going. It doesn't even do it every time. I put some high octane fuel in it to boost the octane numbers to make sure it wasnt bad fuel, but it would run bad all the time, right? This almost sounds like something is shutting the car off like a safety thing. Any ideas? Car has run the best it ever has, no changes in a month. Just came up from no where.
2012 45th Anniversary, 2SS, L99, 6L80E
-Mods: Flowmaster Axle Back Hushpower Exhaust, JBA Catted Hi-Flow Mid Pipes, Fastlane Pipeline Intake
-Soon: L99 to LS3 Conversion, Cam, FAST 102mm Intake Manifold, Hi-Stall Converter, JBA Coated Shorty Headers, Custom Tuning by Jannetty
2012 Silverado LTZ, Z71, 6.2, 6L80E Trans
-Mods: 4300k HID Low's and Fog's. Nu Image Stainless Gauges, Vararam Tri Power Intake, Diablosport 93 octane tune
-Soon: Corsa Cat Back, Kooks Headers w/ Hi-Flow Y-Pipe
lgowens2 is offline   Reply With Quote
Old 03-04-2012, 06:07 PM   #2
Blue10CamaroSS
L99 V8 400 HP 6.2L
Blue10CamaroSS's Avatar
Drives: 2010 Chevy Camaro 2SS/RS
it still could be bad gas, not so much for octane but could have water in it
Blue10CamaroSS is online now   Reply With Quote
Old 03-04-2012, 06:11 PM   #3
lgowens2
lgowens2's Avatar
I come from diesel trucks and have dealt with water in fuel many times on the road. It's a fairly simple fix on diesels, dain water from filter, prime and keep truckin. Not sure what I would do in this case short of draining the tank.
Old 03-04-2012, 06:26 PM   #4
white 2SS/RS
Drives: ADM Built 2011 2SS/RS A6
So you're driving, the car shifts gears, and dies? No lights on the dash?
ADM Scoop, CAI Intake, VRPW, GT11 cam, 1 7/8" Stainless Works, 3" Magnaflow, Yank SS3600, 3.45 gear
1.63 60' / 7.39@93.2 / 11.61@115.0
white 2SS/RS is offline   Reply With Quote
Old 03-04-2012, 06:38 PM   #5
lgowens2
lgowens2's Avatar
I should've explained better. When I go to shift out of reverse to drive the car dies at that point. No lights or anything.
Old 03-05-2012, 08:51 PM   #6
OOLIE
OOLIE's Avatar
Drives: 2011 LS
I have used rubbing alcohol 92% in the past to remove water from gas, if you determine that is the case. I think one bottle treats like 8-12 gallons if my memory serves me correct.
OOLIE is offline   Reply With Quote
Old 03-06-2012, 07:46 AM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
alcohol works
dekan513 is offline   Reply With Quote
CAMARO WIKI Tran Wiki 42 05-18-2013 09:32 AM
Need advice on which Axel back to go with on a 2012 SS L99 Auto? ppiamp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 03-07-2012 05:14 PM
Stock SS Parts – AZ Available edneyens Local Marketplace 5 05-16-2011 07:58 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 01:00 PM
Camaro LS / LT / RS / SS specs and options! CamaroScotty 5th Gen Camaro SS LS LT General Discussions 119 09-02-2008 09:46 PM
