Old 03-08-2012, 01:58 PM   #57
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Yes. I knew what you meant. But again, cost goes way up and I get Larry the cable guy working on it.
Plus, what is being accomplished? The tranny brace will still be in the way I think. What I need is to be able to weld in the Y pipe leaving room to go in before the tranny brace.
Right?
Left
Didn't know you were calling yourself Larry the cable guy now.
The tranny brace wont be in the way if you section it just right.
you have a few options.
you still haven't explained why you don't want to cut into the headers.
Here's Borla's headers
and here's a different brand (different car too, but the point is the same)
what is the difference between that length of pipe being one solid piece with the header or being the intake portion of the cutout ypipe?
another thought I had, but I'd have to look close on distances, would be to section the X-pipe part of the exhaust, move it farther back and run the cutouts right of the S pipes.
I piss excellence
and fart awesomeness
Old 03-08-2012, 02:10 PM   #58
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I thought about that too. But I'd prefer to dump right by the headers.
Tell me this.... is there any negetive effects to dump right past the o2 bung? Seems like that would be loud as shit.
Old 03-08-2012, 02:47 PM   #59
CamaroSpike23
Truth Enforcer
as long as you have enough room for the y-pipe to connect to the header, I shouldnt see why not. cus its not truly dumping right there, its still going to be going another 8-12" away before exiting.
I piss excellence
Old 03-08-2012, 02:49 PM   #60
PQ
Booooosted.
PQ's Avatar
But that's right at the tranny brace so I may have to do like you said and move the S pipes back some and put the cutouts right behind the tranny brace.
Old 03-08-2012, 02:52 PM   #61
CamaroSpike23
Truth Enforcer
depends on which way you orient the cutouts (facing in or out) and the clock index (3 o'clock position, 2 o'clock position, etc). also, remember with the 3 bolt flange ones, you can orient the motor independently of the cutout itself. so if you need to make some room, you can have the motor angled up over the exhaust pipe and still have the cutout dumping outward properly.
I piss excellence
Old 03-08-2012, 02:54 PM   #62
PQ
Booooosted.
PQ's Avatar
They wont face out at all. The bottom of the car wont' allow it.
Old 03-08-2012, 03:06 PM   #63
CamaroSpike23
Truth Enforcer
make room with the mario hammer
I piss excellence
Old 03-08-2012, 03:10 PM   #64
PQ
Booooosted.
PQ's Avatar
The other problem I have is that my headers scrape the ground on those areas when my car high centers. So a flange from the Y pipe and motors will have to angle up. So I need to be able to fit a couple turn downs on there too.
Old 03-08-2012, 03:14 PM   #65
CamaroSpike23
Truth Enforcer
the turndowns should not extend (Vertically) past the outer edges of the flange.
Basically, if you were to take the turndown and look directly down the center of the mounting flange, you should not see any part of it stick past the outside of the flange.
I piss excellence
Old 03-08-2012, 03:15 PM   #66
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
pssst... you do realize that you have coilovers, right?... you can raise your car up a little...
(I know, I know... not desirable, but it is an option... you would, of course, have to have the car realigned if you did change the height.)
Old 03-08-2012, 03:25 PM   #67
PQ
Booooosted.
PQ's Avatar
NO, I get that, but the Y pipe has a flange on the end of it. So if I put it on the pope coming off the header then I have to rotate the part with the flange upward so the flange on the Y pipe doesn't scrape. This will mean the exhaust is dumping at a slight upward angle. So Id need to put a turndown on the dumps.
If I have to raise the car, I ditch the cutout idea.
Another reason the noweeds are desirable. The motors an the noweeds are higher than the pipe. So the whole thing is flush or raised.
Old 03-08-2012, 03:58 PM   #68
CamaroSpike23
Truth Enforcer
STOP!
hammer time!
I piss excellence
Old 03-08-2012, 04:00 PM   #69
PQ
Booooosted.
PQ's Avatar
Old 03-08-2012, 04:06 PM   #70
WadeWilson
How U Doin?
WadeWilson's Avatar
Drives: 2014 CTS-V Coupe
I never knew that choosing and buying cutouts was so difficult.
QTP Electric Exhaust Cutouts Pictures and Videos!!! Quick Time Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 51 08-08-2015 10:09 PM
New low profile electric exhaust cutouts for your Camaro @ PFYC.com Redshift V8 Bolt-Ons & Tunes 8 08-14-2014 05:19 PM
Headers w/ exhaust cutouts OHIOSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 4 01-22-2012 02:13 AM
QTP Electric Exhaust Cutouts Installed on L99 with Borla! thespymaster Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 04-03-2010 07:03 PM
exhaust cutouts Vs. Diverters ZeeTwentyFour General Automotive + Other Cars Discussion 2 07-10-2009 09:23 PM
