HeadlightArmor
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-05-2012, 04:59 AM   #1
SixGracing
The Reaper
SixGracing's Avatar
Drives: 2010 2SS/RS LS3 A6
DOD/AFM/DOD Delete.. Someone enlighten me.. Please!
It seems to be common place for anyone upgrading or tuning an L99 to disable the AFM and a lot of the time doing a DOD delete which basically converts the L99 to an LS3. My question is why would Chevy put that crap on the Auto's? I mean fuel management, running on 4 cylinders and fuel economy? Isn't that what the Volt and Prius are for? People (at least most people) buying an American Muscle Sports car like the Camaro SS aren't after fuel economy. Not to mention I've seen very little gain using the AFM posted by others. So why have it? If you are going to install LTH's, High flow cats, axle-back, etc, the AFM will drive you bonkers with all of it's sputtering, droning, farting and burping going on under the floor boards. I have SLP LTH's with the High Flow cats and PowerFlo axle back and when the AFM kicks in it makes my car sound like a Corolla with pipes. As soon as I touch the throttle it sputters and finds its way back into a normal sounding V8. It's very annoying. Don't get me wrong, at WOT the car sounds like a raped ape on steroids. It's just when you're cruising that the AFM/DOD will constantly change the tone/sound of your engine.
So my suggestion to anyone who owns or plans on owning an L99, get rid of the AFM and do a DOD Delete. You will be much happier, you car will run much smoother and you won't compromise anything other than your sanity if you don't.
Anyone else have anything to add?
Just my two cents..
SixGracing is offline   Reply With Quote
Old 03-05-2012, 05:41 AM   #2
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
The short answers to your questions are:
GM puts the AFM on them to meet CAFE standards (Corporate Average Fuel Economy) and avoid millions of dollars in federal fines.
A lot of us don't like it but don't disable it because doing so will void the powertrain warranty, or at least COULD void it.
But in the end, you're right, IT SUCKS!!
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
babaron is offline   Reply With Quote
Old 03-05-2012, 06:01 AM   #3
SixGracing
The Reaper
SixGracing's Avatar
Hmm, well if that were the case then why does the Manual not have it?
Old 03-05-2012, 06:03 AM   #4
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
It does. The manual has CAGS. Also known as skip-shift.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 03-05-2012, 07:13 AM   #5
SixGracing
The Reaper
SixGracing's Avatar
Not familiar with CAGS. How does it affect fuel performance and does it cause the same issues the autos see with the grumbling and droning in the exhaust? Just curious..
Old 03-05-2012, 07:15 AM   #6
JoshBobGuptaMarley
Emerald Coast Camaros
JoshBobGuptaMarley's Avatar
Drives: '12 2SS/RS LS3 GBA
It's all about taxes and the government. Enjoy it as it represents freedom and democracy .
Muffler Delete, Cold Air Inductions intake, Technostalgia Sequential LED Tail Lights, Vmax CNC Ported TB, RX Catch Can, AAC LED Interior Lights (Aqua)
JoshBobGuptaMarley is offline   Reply With Quote
Old 03-05-2012, 07:39 AM   #7
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Yep. Just the usual government BS. How do manufacturers like Jeep get around this? Do they even make one vehicle that gets decent mileage? My V6 Jeep is worse than my Camaro:(
Anyway, I think AFM is much worse than CAGS. While CAGS may be annoying, I don't think it causes all the weird sounds (farting) and vibrations, and from what I've read, it can be disabled by a $20 device. Us auto guys are stuck dealing with it, or tuning it out. I got rid of mine, and I'm so glad I did. I upgraded from my V6 for a V8, not a 4-banger. Govt. regs or not, AFM has NO place on cars like this.
Solo Mach XL with J-Pipes · Cold Air Inductions Intake w/JRE Scoop · Jannetty SCT Tune· Roto-Fab Washer Bottle · Defenderworx Bowties · Vmax Ported TB · LPE 3.70 Gears · Dynatech SuperMAXX Headers · Elite Engineering Tunnel Brace · CFD Pistol Grip TapShifter · GM Strut Tower Brace
E.T. is offline   Reply With Quote
Old 03-05-2012, 07:49 AM   #8
The Stig
The Stig's Avatar
Not really. CAGS basically locks you out of 2nd gear, forcing you to shift from 1st to 4th.
Old 03-05-2012, 09:25 AM   #9
cmore
cmore's Avatar
Drives: 2011 Victory Red Auto 2SS
Looks like if the auto gets better mileage with it, the std would to. Wonder why GM did not force it on the manual owners?
cmore is offline   Reply With Quote
Old 03-05-2012, 09:29 AM   #10
The Stig
The Stig's Avatar
Only way to disable AFM is to get a tune, and a tune voids your powertrain warranty.
Old 03-05-2012, 09:46 AM   #11
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Send a message via MSN to edog
The afm also saved you from paying the gas guzzler tax like you pay on the challenger. It is afm option. I was getting 26 to 27 mpg before tuning it out, and 22 to 24 mpg after the tune. I have mods that have changed things a well and I am glad I have removed it, but still very happy to not pay gg tax.
Doug Thorley Tri-Y LT/cat back, Ported TB, Halltech CAI, Pedders sways, endlinks, Drop Springs, Tuned by TandTPerformance 371HP/383TQ
edog is offline   Reply With Quote
Old 03-05-2012, 10:19 AM   #12
cmore
cmore's Avatar
Wow, 26-27 mpg. Mine is stock and not driven all that hard but gets about 22mpg any way!
Old 03-05-2012, 10:41 AM   #13
ParisTNDude
ParisTNDude's Avatar
Drives: 2006 Corvette
CAGS is a gas saver...makes you shift sooner out of the gas guzzling first gear. I kept mine active for 3 years with my C5 Vette and it never bothered me. The manuals don't have the AFM because the solid mechanical linkage of the manual drive train would have caused lots of drone at steady speed. The automatic with a hydraulic hook up to the rear gears absorbs some of that, but still is obnoxious. I could never get any better than 26 out of mine before my tune and now 23-24 is tops.
Current ride: 2006 Corvette, LG long tube headers, HF cats, Xpipe, Vararam, Vmax ported throttle body, Z06 bi-mode axle backs, Fast LSXR 102 intake, DynoSpeed tune
Dragtimes link: http://www.dragtimes.com/Chevrolet-C...html?r=1"]2010
ParisTNDude is offline   Reply With Quote
Old 03-05-2012, 07:16 PM   #14
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
i've had my tune for almost 2500 miles and my gas mileage hasn't moved a bit... 18.1mpg average, but I never put it on the highway, its a weekend car and sees the city lights almost always...
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
Old 03-06-2012, 12:01 AM   #15
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
I think they put it on there so I could notice how nice it is to have it GONE!
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 03-07-2012, 07:44 AM   #16
edog
edog's Avatar
What part of the country and driving conditions have a great deal to do with it. I did not realize how much til I started driving around the country with mine. I get better mileage in the south east for some reason.
Old 03-09-2012, 12:22 PM   #17
OBSSEST
Drives: 2010 Camaro 2SS RS, Black
I wish it were this easy to convert my L99 to an LS3. Unfortunately, there are a few more internals that are different.
OBSSEST is offline   Reply With Quote
Old 03-11-2012, 10:26 PM   #18
SixGracing
The Reaper
SixGracing's Avatar
I know the VVT cam, DOD system, valley tray etc are a good start. I believe the L99 has different piston compression ratios? From what I've heard though, and I could be wrong, is the L99 is an LS3 with those added items mentioned above. Get rid of them and essentially gain and LS3.. Correct me if I'm wrong.
muffler delete with xpipe and no resonators, first imprseeions caper Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-05-2011 04:41 PM
SLP muffler delete kit? P/N: 30222 SS Power Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 10-13-2010 05:25 AM
ATAK compared to Muffler delete, decel. popping? defragme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 07-24-2010 10:01 AM
Muffler delete ch3apsh0t Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-21-2010 02:18 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 02:09 PM
