Flowmaster Exhaust
Old 04-30-2009, 04:44 PM   #1
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
crankshaft changing?
I had a client ask me something odd today, and I need some answer for him, so here it is...
Is it possible to pull out the crankshaft and insert a new stroker crank while the engine is still in the car...It would reuse the stock rods and pistons..
First of all would it work?
Secondly, would the stock rods and pistons be strong enough?
ZZcamaro is offline   Reply With Quote
Old 04-30-2009, 05:01 PM   #2
GeorgeInNePa
Plastic Cuttin' Badass
Drives: '08 G8GT 6.0
Many times, the rod length will need to be different and the wrist pin location in the piston will change.
Also, even if it would work, you would want to upgrade to forged pieces while you're doing all that work.
'08 Black on Black G8GT--> 12.166 @ 113.13, 1.723-60'<-before the gears...
FasterProms Tune, Ported TB/Intake - HSRK - Vararam - SLP 25% UD Pulley - ARH 1 3/4" Longtubes - Pypes Violators - Yank 3200 Converter - PCM4Less Trans Cooler - DashHawk - All Pedders Bushings, Xa Coil-Overs - Spohn Arms - Billet Prototypes Catch Can - Skinnies on GTO rims - ET Streets on F Body Rims - SJM LineLoc - 3.70gears/Harrop TrueTrac
Coming Soon: Ported Heads/Cam/DoD Delete
GeorgeInNePa is offline   Reply With Quote
Old 04-30-2009, 05:26 PM   #3
ZZcamaro
That is kind of what I told him. I just needed somebody to back me up and to make sure I was not crazy!!
Thanks
Old 04-30-2009, 05:42 PM   #4
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
No.....
With the change in stroke there would have to change either the compression distance on the piston or the rod length.
You can't physically remove LS pistons from the bottom either.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 04-30-2009, 07:40 PM   #5
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2015 ZL1 for weekends mostly
NO.
The building of a stroker starts with taking into account:
Deck height-piston compression distance-rod length-1/2the stroke
Then there are wierd things like rod/stroke ratios and base circle changes on cams, rod to block clearance, depending on how radical you get.
Always check the specs first on the entire assembly before even buying parts unless you get a kit but it will be specific for that block.
Also whatch out for the cumbustion chamber size and be sure to recalulate the mechanical compression ratio. It builds up real fast if you are not careful.
I have built a few........
PoleCat2SSRS2010 is offline   Reply With Quote
Old 04-30-2009, 08:14 PM   #6
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Originally Posted by PoleCat2SSRS2010 View Post
NO.
It took a woman to answer a mans question..
Keep up the good work...Maybe she can get a group buy going as well!
ADM PERFORMANCE is offline   Reply With Quote
Old 04-30-2009, 08:25 PM   #7
DanD
DanD's Avatar
Drives: 6 camaros
sure you can do this, if you want to punch the pistons through the heads...lol
2010 IOM RS/SS TVS2300, cam, stall, headers
2002 Z28 427
2002 SSLE Convertible
1968 383 Camaro
1968 327 Camaro Convertible
1967 RS 327
1967 Pro-Tour LS3 in progress
DanD is offline   Reply With Quote
Old 04-30-2009, 08:52 PM   #8
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Please stay on topic...
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 04-30-2009, 09:43 PM   #9
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
Not to mention the crankshaft has to be removed from the bottom of the block. There's a K-member and lots of steering stuff in the way. So no, you can't take the crank out with the engine in the car and no, you can't re-use the rods/pistons, as has already been stated.
UsedTaHaveA68 is offline   Reply With Quote
Changing Rims and Tires Dentyneice Wheels and Tires Talk Sponsored by The Tire Rack 1 04-28-2009 10:25 PM
Changing to a Super T-10 Borg Warner ringb1 1st & 2nd Generation Camaros 2 04-24-2009 10:30 PM
changing order johnntab Camaro Price | Ordering | Tracking | Dealers Discussions 7 04-14-2009 06:04 PM
who is changing your color to Blue. 13F20 Camaro Photos | Spyshots | Video | Media Gallery 1 11-07-2008 07:02 PM
changing the led color of ambient lighting. pinkcamaro10 Cosmetics and Lighting Modification Discussions 18 09-27-2008 02:14 AM
