Old 03-05-2012, 08:55 PM   #1
steel insane
steel insane's Avatar
Drives: 2012 2LT Black (Vengeance)
SS stock brakes setup on a V6
Can I simply switch the calipers and rotors?
Mine's a 2LT with 20" Rims...
steel insane is offline   Reply With Quote
Old 03-05-2012, 09:08 PM   #2
jesserayjames
jesserayjames's Avatar
Drives: Drives a 2012 IOM 2SS/RS 6M
You can do that with no problem as long as you have right parts and you must use 20 inch rims......................
CAMARO 2SS/RS 6M
jesserayjames is offline   Reply With Quote
Old 03-05-2012, 09:58 PM   #3
steel insane
Besides the obvious calipers and rotors, what else is needed?
Old 03-05-2012, 10:00 PM   #4
Toasty
Custom User Title :D
Toasty's Avatar
Drives: 2011 Summit White 2LT/RS
The hardware, of course... but you'll also have to trim the dust shield on the rears...
Toasty is offline   Reply With Quote
Old 03-05-2012, 11:45 PM   #5
steel insane
Specifically what hardware?
Can you change the dust shields?
Old 03-05-2012, 11:53 PM   #6
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
Yes you can exchange the dust shields, and you will need the pads, screws and brake lines.
christianmotox is offline   Reply With Quote
Old 03-06-2012, 12:23 AM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You could change them but the amount of work involved to do that would make no sense. Just trim them.
[B]
Old 03-06-2012, 01:15 PM   #8
nak3dsnake
nak3dsnake's Avatar
Drives: 2010 Camaro IBM 2LT/RS M6
Yes, everything bolts right up.
You will need brake lines as well, I'd get a set of stainless steel lines and put them on rather than a stock set. You can just trim the rear dust shields as its a lot of work to change them. I would try to get a takeoff set with everything you need rather than buying stuf individually. Check out SLP's ebay page and the classifieds
Looks: AAC P13W DRLs, Heritage Grille, RS Embroidered Headrests, GM Door Sill Plates, GM Premium Floor Mats, Body Color Engine Cover, LLT Mobile 1 Oil Cap, ZL1 Sport Pedals, 3M Clear Bra.
Performance: Vararam Ram Air Intake, Hurst Short Throw Shifter w/ Hurst Hard Drive Pistol Grip, IDEALG Clutch Master Cylinder, RX Catch can, GTO clutch fluid reservoir, Brembo Brakes, 1LE Track Pack, GMPP Exhaust Upgrade.
nak3dsnake is offline   Reply With Quote
Old 03-06-2012, 02:32 PM   #9
GearHeadPeter
US Navy Vet
GearHeadPeter's Avatar
Drives: 2011 2LT/RS, 65 Mustang GT Fastback
When I did mine I also put in a SS Master Cylinder so the brake pedal feels right as I was told leaving the V6 would make the brakes too sensitive. I got that from Maureen at Rodgers Chevy for about $80 complete.
2011 - 2LT/RS - RY, A6, Gray Interior - Team LLT:
3rd Camaro on this forum to have a Mylink installed. Installation by GEN5DIY, Heritage Grill, Lloyds Premium Ebony Camaro RS floor mats, Empire Billet Camaro Black sill plates, AAC: LED footwell & interior lighting, Rear Courtesy Lights, LED side markers/turn signals, Plasma P13W DRl bulbs, Formula 1 Pinnacle Series tint, Roto-Fab Yellow CAI & Fuse cover, Technostalgia Afterburner LED taillights, EmblemPros custom V6 hydrocoated carbon fiber/RY engine cover, Pfadt Sport sway bars, Ofer's Backup Camera, and full Brembo brake conversion.
GearHeadPeter is offline   Reply With Quote
Old 03-13-2012, 09:31 PM   #10
cengell
Drives: 2LT
Hi I am getting a 2010 SS V8 brakes and will put them on my 2012 V6 and want to get a set of stainless steel lines and I would order them for a 2010 Camero SS and they will fit these Chevy/Brembo calipers right?
I was not going to get a new master brake Cylinder or should I?
Just want to be 100% sure!
Thansk
Christopher
cengell is offline   Reply With Quote
2010 camaro v6 complete v6 brake setup for sale lowpro192000 Suspension / Chassis / Brakes 8 09-29-2011 08:17 PM
I own a SS, but rented the V6 Challanger and V6 Camaro aet08 5th Gen Camaro SS LS LT General Discussions 75 08-16-2011 01:06 AM
V6 diffuser is different than the SS diffuser. SIXJAK 5th Gen Camaro SS LS LT General Discussions 8 07-20-2011 12:13 AM
SS Brakes on V6 Blacc Mamba Suspension / Brakes / Chassis 10 06-25-2011 11:32 PM
ss gas vs v6 gas sasquash1984 5th Gen Camaro SS LS LT General Discussions 28 06-10-2011 12:16 PM
