SDTW Custom Wheels & Tires
Old 03-06-2012, 08:52 AM   #1
blackknight0512
blackknight0512's Avatar
Drives: 2012 Camaro L/S
Lfx manifold
So I was talking to the guys at cherry bomb and apparently on the lfx engine, along with not being able to do headers, our cats are part of the manifold. To me this means no high flow cat which I thought was the answer to freeing up some llt's exhaust. Doesn't this basically render any cat back systems useless?? Might as well just get 2 mufflers and call it a day...
blackknight0512 is offline   Reply With Quote
Old 03-06-2012, 09:11 AM   #2
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
Can't a saw take care of the cats?
mhog is offline   Reply With Quote
Old 03-06-2012, 09:28 AM   #3
malave7567
malave7567's Avatar
Drives: 2015 Camaro 1SS
the cats are not part of the manifold.... you see a single big pipe going down from each side of the engine, and then 2 cats on each pipe, as with all other v6 camaros. eliminating these two cats and going with 1 high-flo cat on each side is still possible (though it would more than likely throw CELs at you unless you get those tuned out)
malave7567 is offline   Reply With Quote
Old 03-06-2012, 10:11 AM   #4
KMPrenger
KMPrenger's Avatar
Malave is right, but I do have another question...
Malave...is there a flange on the downpipe before the cats that can be unbolted so that the cats can be removed? Surely there is.
As for the OP....this causes no problems with installing a catback whatsoever.
Old 03-06-2012, 10:22 AM   #5
malave7567
malave7567's Avatar
honestly I'm not sure. I think they might not be since there is no exhaust manifold you would have to unbolt and service, you could just unbolt the whole pipe. But I'm not sure about that. I would have to get under the car again and double check.
I was considering just cutting the 2 cats out on each side and having my local exhaust shop weld a 2.5" high-flo cat on each side, but I want to save up enough to be able to get a tune because I hate CELs (don't we all)
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 05:34 AM
Just installed the RX Ported Intake manifold and Mace Insulator Jmiller Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 17 02-12-2012 09:33 PM
MACE's Intake Insulator/High Flow's Ported Intake Manifold bmorecam Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 432 12-08-2011 09:26 AM
Any LFX V6's out yet? (Updated with LFX pics) Milk 1027 5th Gen Camaro SS LS LT General Discussions 144 10-17-2011 10:11 AM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
