HeadlightArmor
Old 03-06-2012, 09:42 AM   #1
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
JRE SCT CUSTOM TUNE INSTRUCTIONS V4 3/6/12
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you Purchase an SCT X3 Hand Held Tuner from me you get ONE, 93 OR, ONE, 91 Octane Tune For Free 2010/11/12 Camaros Only, for your simple bolt on mods, CAI and Cat Backs, exclusions apply for Headers, cams, superchargers and nitrous and other vehicles.
Additional Tunes with minor changes are available AT THE TIME OF PURCHASE For 50.00 Each, i.e. Second tune for 91 Octane.
Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file. Here is how, Sit in the car, Close the Door, Turn off all accessories and Unplug any devices from the Power Ports, i.e. cell phones, radar detectors, navigation etc. plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, Turn the Key on, But do NOT Start, Wait for the Dinging to stop and hit select.
Your tuner came with a disc with Free Software called SCT Device Updater software, if not you can go to www.sctflash.com and down load for FREE, install this in your home or laptop computer Before you connect the device to your computer.
Then After you install and OPEN SCT Device updater software, you can connect your X3 to your computer, Drivers should install automatically, then Get Stock File, Click Browse, Find your Desktop and Click Save.
Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, List of Performance Modifications and Preferred Octane 93 or 91.
PLEASE RE READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION, EVERYONE SEEMS TO FORGET OCTANE REQUIREMENT.
Then I will send you back a custom tune file for your mods.
When you receive a response, Save the file to your desktop, it will be, YOUR NAME JRE TUNE.cef
Again open SCT Device Updater, Then, connect your X3 tuner, select Load Custom Tune File, Browse to your tune file Select it, then select a position 1, then name it anything you like, i.e. JRE TUNE, click on program, you will see the progress bar at the bottom go green, then exit when finished.
Connect to your car, Select Program Vehicle, scroll left to Custom Tunes, Select JRE tune and follow the on screen prompts.
I have developed Dyno Proven tunes for all of the Product I sell, So Unless I instruct you to do so Datalogging will NOT be necessary.
If I instruct you to Datalog your car, The best way I found is to use a laptop on the seat, First, Start the Car, Then Open the LiveLink Software Then connect the X3 to your laptop, Then connect the X3 to the OBDII Port of the car, Then Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below.
Even thought they may not be named exactly as I listed them, I want you to select the following, but Try Not to select anything Not listed or doubles of any of the items listed.
You may have to test several PIDs to see which ones work best or work at all on your car.
Once you find a list that works well Save Configuration file for future use.
Engine RPM - RPM
MAP-Intkman abs prss
FUEL PRESSURE
ECT engine coolant temp – ecteng clt tmp
TPS throttle position or pedal position – acc pdl pos 1s
IAT intake air temp or Air intake temp – intk Airtmp
MAF Mass Air flow Hz – Maffre 125
TIMING spark cylinder 1 – ign Tim Adv4#1cyl
KNOCK RETARD – knk ret
Vehicle speed Kph–?
Long Term Fuel Trim bank 1 – ltf tri b1
Long Term Fuel Trim bank 2 – ltf tri b2
Pleas ONLY Select the PIDs Listed, Extra PIDs Slow Down Datalogging and give me useless information.
Names can vary from computer to computer but you get the Idea.
Once you have your PIDs configured and working, While NOT logging you can go to File/save LiveLink Configuration, for future Logging.
Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM Paddle shift works best on Automatic trans cars.
Then repeat at about 1/2 throttle to 5500 RPM Speeding is not recommended or necessary 1st and 2nd gear are fine if you do not have the room.
Stop, and Save Datalog As to your desktop.
Email me the log files along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications, and any Comments you might think are helpful.
PLEASE RE READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION.
Please Do Not Assume I will know who you are By your Screen Name, or what kind of car you drive, or what your mods are, I deal with 50-100 people a Day so I must have all of your info right in front of me in ONE email so I can Properly Write your Tune.
Your Cooperation in reading, understanding and following these directions will make this a Very Pleasant Experience for both of us.
Thank you for Choosing JRE, Ted.
If you have other questions about SCT X3 or this program feel free to email me or call tedj@jannettyracing.com 203-753-7223
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
JANNETTYRACING is online now   Reply With Quote
Old 03-06-2012, 10:10 AM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
So a tune for headers aren't included in the first tune?
Old 03-06-2012, 11:31 AM   #3
JANNETTYRACING
See my website for details.
Thank You.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-14-2012, 08:51 PM   #4
JANNETTYRACING
Bump
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-21-2012, 06:55 PM   #5
LonghornLove
My Grille so Icey
LonghornLove's Avatar
Drives: Black 2SS/RS
I have the sct tuner and I was going to do some datalogging for Ted. Are you suppose to download the software online or is it suppose to be installed when you install the device updater? It is nowhere to be found on my computer if that is the case.
NVM I watched Nicks video and found the answer.
Now do I need to send the custom tune with the data logging?
LonghornLove is offline   Reply With Quote
Old 03-21-2012, 08:52 PM   #6
JANNETTYRACING
No Sir,
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-28-2012, 04:18 PM   #7
apeko
apeko's Avatar
Drives: 2011 2-SS/RS SGM
If I my car and try to shift through all 6 gears at 4500 rpm i would be going well over 100 mph. Not that i would not want to go that speed its hard to find a strech of road to do it.
Or am i doing something wrong?
Thanks
2011: 2SS/RS Camaro Synergy Metallic
apeko is offline   Reply With Quote
Old 03-28-2012, 04:25 PM   #8
JANNETTYRACING
Thanks
I only need 3 gears, Please don't do any thing Dangerous.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-28-2012, 04:32 PM   #9
apeko
apeko's Avatar
no danger....lol i just needed that clarfied.
Old 03-30-2012, 06:47 PM   #10
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
I'm seeing "Device Connection Failed" when I try to downloadload the stock file onto my computer, help?
Synyster is offline   Reply With Quote
Old 03-30-2012, 08:48 PM   #11
Synyster
Synyster's Avatar
Never mind, got it
Old 04-08-2012, 01:26 PM   #12
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
a bump for jannetty racing
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 04-08-2012, 01:52 PM   #13
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
+1 bump... awesome guy, ted is!!
nebchevy is offline   Reply With Quote
Old 04-09-2012, 09:23 AM   #14
JANNETTYRACING
Thanks Guys.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3448 01-15-2018 12:30 AM
Jannetty L99 A6 Tune First Impressions OBSSEST Tuning / Diagnostics -- engine and transmission 107 01-07-2013 09:10 AM
OBX LTs HF cats / Borla Atak VID...JRE tune 1sweet11SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 01-13-2012 11:13 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
