Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 03-06-2012, 01:31 PM   #1
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Weighed the ole SS today......
Well, I have a 1ss 2010 l99 car. Only weight reductions are removed front and rear crash bumpers, removed engine cover and installed catless longtubes. With a 1/4 tank or fuel, and me in the car it weighed 3900 lbs. With seat removal and trunk carpet and compressor removed that should put me around 3800 w me in it in track form. Last time out was tune only and full weight. Looking to run some 12.3-4' s this time out!
GM Performance Parts Sales, Installation, and Calibrations
rhino-79@hotmail.com
Kooks, EFILive, Edelbrock, Powerbond, Comp, Mast, LPE, Circle D and many more!
2010 SS L99 Cam, Bolt-ons, 3.91s, CircleD 1E 10.87 @ 124 THE Fastest NA L99
Rhino79 is offline   Reply With Quote
Old 03-06-2012, 09:55 PM   #2
mstanford.us
Mark Stanford
Drives: Black 2010 SS LS3
On race days I remove the front passenger seat, rear seat, rear seatbelt bar, and put in a 15lb Braille battery to replace the 44lb stocker. My American racing Torque Thrust wheels 20X8.5 up front and 20X10s in back lose another 35lb or so with stock Perellis in front and Either Nitto NT-05R p315 or MT ET Street IIs p305 in back vs the stock GM SS wheels.
How do you get the crash bumbers off? Did you take any photos of that process?
12.5@115 was my best like this last year. This year Im doing full BMR suspension bushings & sway bars, and a Jannetty Racing posi pumpkin upgrade to 3.91 LPE gears. Last year my best 60' time was 2.01. This year I'm hoping to vastly improve my 60'. As you can see, my trap speed indicates a sucky launch, but lots of HP.
Mark Stanford
2010 1SS M6 456rwhp, 418 torque
www.Midwestracing.net
CAI Inc, Kooks 1 7/8" 3"catted + mufflers, Livernois stage 2B cam (230/240, .591"/.608" int/exh), Custom Dyno Tune, Libertyville Chevrolet (IL) by Kevin Paddock, Nitto NT05R P315/35R20 on 20X10 American Racing Torque thrust rims, BMR trailing & toe rods. Centerforce DF clutch.
mstanford.us is offline   Reply With Quote
Old 03-06-2012, 10:07 PM   #3
mstanford.us
Mark Stanford
Originally Posted by So Cal Camaro View Post
Torque Thrusts lighter than stock by 35lbs, cast wheels, I'm not sure about that...
I'm a little foggy about the exact weight savings, but I did weight the mounted stock wheels & tires VS the mounted stock fronts & DRs on the new back wheels. Perhaps is was only about a 25lb weight savings, but I do recall being quite suprised at the loss of lb.
The stock wheels are also cast and have LOTS of material. I was warned by some fellow racers about hubbing the Chinese AR wheels if I got much past my current rwhp.
Mark Stanford
Old 03-06-2012, 10:10 PM   #4
mstanford.us
Mark Stanford
Rhino79, did you weigh the crash bumbers you removed so I can have an idea about the effort/weight trade off in doing the same thing?
Mark Stanford
Old 03-07-2012, 04:07 AM   #5
Rhino79
Rhino79's Avatar
About 50lbs. Just have to remove the front and rear fascia to access them. Took me an hr and a half to do it all.
Old 03-07-2012, 11:40 PM   #6
Bo White
Drives: 2009 Pontiac G8 GXP
My GXP with a 1/4 tank and me in it weighs 4140(Im 180ish).
Old 03-07-2012, 11:56 PM   #7
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
My car weighed in at 4,320 lbs with me in it and about 1/2 tank, I'm about 220 lbs.
SUX2BU is offline   Reply With Quote
Old 03-08-2012, 09:09 AM   #8
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
With a full tank of gas my 2010 SS/RS MT weighs 3,680. With a 1/4 tank of gas and me in it the weight is about 3,795.
If you're interested in weight reduction on a Camaro I've documented everything I've done in my project thread.
http://www.camaro5.com/forums/showthread.php?t=45165
I don't do drags; my car is setup for road course racing but I'm guessing with the mods I have I'd be somewhere in the 11's in the 1/4 mile. My car is N/A but has a cam.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is online now   Reply With Quote
Old 03-08-2012, 10:24 AM   #9
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Our Camaro weighs in at just about 4000lbs with half a tank as scaled at the Spectre341 Hill climb. We were definitely one of the heavier of the cars there!
Old 03-08-2012, 02:56 PM   #10
Doc
Doc's Avatar
Your car is fully race-ready with rollbar, fire extinguisher and everything isn't it? With all of that in it, 4,000 lbs isn't all that bad for a 5th gen.
1SS/RS LS3 M6 IBM
Old 03-08-2012, 03:03 PM   #11
Rhino79
Rhino79's Avatar
I wish I had the cash for some RTS wheels, I think that'd be worth a couple tenths alone. Is like to get it around 3700 with me in it. Some wheels and track setup would be right at that. I just don't want to give up the insulation or any creature comforts......
Old 03-08-2012, 06:53 PM   #12
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
I'd say a lot more than that. I gained about .783 seconds and 3.876 mph in the 1/4 going from stock to 18s with drag radials with just bolt ons.
Old 03-09-2012, 10:16 AM   #13
PfadtRacing
Our RingSpec Camaro definitely is not a race car. We had the safety equipment needed for the Spectre, but it's far from a full build. We did Fab up a "Chassis bar" for the interior to allow us to mount harnesses and the fire extinguisher, but those weights are probably offset by the removal in the back seat.
We never really stripped the car, or removed any interior pieces so there is plenty of weight still to be lost. 4000lbs isn't bad for a 5th gen, but compared to a 3300lb ZR1 it's a little porky.
Old 03-09-2012, 10:41 AM   #14
Doc
Doc's Avatar
lol yeah I guess it would be compared to that. I thought you guys had built that car out.
1SS/RS LS3 M6 IBM
Old 03-09-2012, 12:47 PM   #15
JusticePete
Needs Lowering
JusticePete's Avatar
Drives: Pedders USA Camaro Justice
Did someone really call the Camaro ZL1 porky on the Camaro5 website? Allow me to show you porky...
ZR1 MSRP $111,000
ZL1 MSRP $54,995
Ring Times
ZL1 7:41.27
ZR1 Cups 7:19.63
ZR1 OE 7:26.4
  • ZR1 Brakes are good for at least 4 seconds or more
  • 50 HP maybe 1
  • Mero currently has three 3 Fastest Ring times, Link has 1. Is Link as fast as Mero? Hard to say, but he has been in a Vette at the Ring since 2008 and has three of the Fastest Ring Times has to be good for two seconds or more
  • Corvette gets a pass on the GM curb height clearance and wheel arch red zone, so ride height is good for another 3 seconds or more
  • Cup tires are good for 6 seconds or more
Our ZL1 is down 22 seconds to the ZR1 with Cup tires and 14 on production tires. If we even the playing field for the ZL1:
Install Brembo GT-R Brakes
Drop the ZL1 20mm with OEM MRC
Get Mr. Link more seat time in the ZL1 at the Ring
Our ZL1 is right there with the ZR1. Add the Cup tires and we pass the ZL1 on OEM rubber and again are on the tail of the ZR1. No tunes. No driveline modifications. All we added are better brakes and restricted to Corvette only ride height. Mr. Link's seat time is not a mod. The brake upgrade is BIG bucks with a retail of over $20,000. No worries. We have enough cash left over to add a SS nicely equipped 5th Gen Vert to our garage
Old 03-09-2012, 02:43 PM   #16
PfadtRacing
The 5th Gen Camaro is a very capable chassis, very comfortable to drive, very fun and can be very fast in the right hands...but the fact remains that it isn't a feather weight. That's the only point we are trying to get across.
Since we're now on the subject of the ZL1, check out this video of the ZL1 vs. the Boss 302 Laguna Seca. Despite the weight disadvantage the Camaro still comes out on top thanks to superior handling. Overall weight isn't the end all, be all of performance testing and I don't think anyone is trying to argue that... but the fact remains that compared to other performance cars in it's class it's a little heavy.
Now check out the porky ZL1 handing it to the Boss!
Old 03-09-2012, 07:54 PM   #17
Nessal
Drives: 2011 SS/RS
If I can get the SS to 3700lbs dry, I would be happy.
Braille battery
Lightweight wheels
Rear seat delete
Passenger seat delete
Headers and exhaust
I believe our cars are 3850lb wet right? So I can see 3700lb dry with those mods given that gas would be about 75lbs with a full tank and the mods should take care of the other 75lbs.
Is this too optimistic or doable?
Nessal is offline   Reply With Quote
Old 03-09-2012, 08:04 PM   #18
midnighter
midnighter's Avatar
Drives: 2010 Chevrolet Camaro SS 6M
I've dropped 20 lbs off mine by me going on a diet.
Old 03-09-2012, 09:32 PM   #19
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
20k for brakes?!
holy shnikes batman...
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 03-10-2012, 01:22 AM   #20
Doc
Doc's Avatar
Braille battery
Lightweight wheels
Rear seat delete
Headers and exhaust
Yeah that's doable. The stock SS LS3 weighs 3,860 lbs and that's with a full tank and all fluids. A full tank of gas weighs about 115 lbs.
1SS/RS LS3 M6 IBM
Old 03-11-2012, 04:45 PM   #21
toehead93
Drives: 2010 SS, 1993 Z28
I know Doc can shave weight on our Camaros but i didnt know He was working on members too. Way to go Doc!
2SS A6 Black
360 RWHP/382 FTLBS - tune only
Mods on: Dynatech LTs, Vararam Intake, Pedders Xa's, DiabloSport tuned
toehead93 is offline   Reply With Quote
Old 03-17-2012, 02:17 AM   #22
JusticePete
Needs Lowering
Why do you think they call him Doc
Originally Posted by Li0nel1234 View Post
20k for brakes?!
here comes the brake porn
Picked up my Cammed/tuned SS from Speed Inc today Tshepp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 06-26-2012 10:17 AM
Ran into an SS today on the way home… nyrfan 5th Gen Camaro SS LS LT General Discussions 46 08-31-2011 11:04 AM
Picking up my SS today Foxrus14 5th Gen Camaro SS LS LT General Discussions 25 08-16-2011 10:53 PM
Installing My Whipple 2.9L on my 2011 Synergy SS Today! Jason 98 TA Forced Induction - V8 27 07-25-2011 05:34 PM
Spare Kit for SS Arrived Today (Pics) LYCAN Wheels and Tires Talk Sponsored by The Tire Rack 33 04-08-2011 06:32 PM
