Solo Performance
Old 03-06-2012, 07:24 PM   #1
2011 SS
2011 SS's Avatar
Drives: 2011 SS M6, LT's, CAI, SLP LM II's.
Normal oil pressure
are these readings normal at idle
Sent from my SPH-D710 using Tapatalk
2011 SS is offline   Reply With Quote
Old 03-06-2012, 08:21 PM   #2
p3jason
Allergic to stupid.
p3jason's Avatar
Drives: 2015 ZL1 #957 M6 AGM & 1990 Z24
Send a message via Yahoo to p3jason
No problem there.
p3jason is offline   Reply With Quote
Old 03-06-2012, 08:33 PM   #3
nomadicdogg
Drives: '10 2SS/RS Cyber Grey Camaro (sold)
I have since day one and still think my oil pressure is to low in my M6 SS.
I dont like anything below 40, especially in a brand new car.
I dont know if its the synthetic or by design but it bugs me everytime I see how low it is.
but your readings are on par with what Im used to in mine
nomadicdogg is offline   Reply With Quote
Old 03-06-2012, 08:46 PM   #4
HDRDTD
Normal
Old 03-06-2012, 08:49 PM   #5
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Mine reads the same. For some reason I think the L99 has higher oil pressure
bajamoon is offline   Reply With Quote
Old 03-06-2012, 08:51 PM   #6
ChriSS
ChriSS's Avatar
Drives: Camaro 2SS/RS M6 Black and IOM
That's about normal on my 2SS M6 goes higher when u punch it
ChriSS is offline   Reply With Quote
Old 03-06-2012, 08:58 PM   #7
One-Bad-ZL1
So easy to love Camaros
One-Bad-ZL1's Avatar
Drives: 2013 ZL1 VR #3457
Send a message via Yahoo to One-Bad-ZL1
Yup normal at idle.
One-Bad-ZL1 is offline   Reply With Quote
Old 03-06-2012, 09:06 PM   #8
BLU BY U
'69 Camaro's Rule
BLU BY U's Avatar
Drives: 2010 Aqua Blue Camaro SS/RS
That's where mine is at, when idling, and at temperature. But, I swear it use to be at 30 when idling.
BLU BY U is offline   Reply With Quote
Old 03-06-2012, 09:08 PM   #9
2011 SS
2011 SS's Avatar
Me to coulda swore on it!
Old 03-06-2012, 09:09 PM   #10
mhood
Orange Camaros Rule!
mhood's Avatar
Drives: 2010 1SS LS3 RS IOM
Isn't oil pressure higher when the engine is cold?
Mary - Orange Camaros Rule!
mhood is offline   Reply With Quote
Old 03-06-2012, 09:21 PM   #11
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
You're good.
hightower is offline   Reply With Quote
Old 03-06-2012, 10:20 PM   #12
BLU BY U
'69 Camaro's Rule
BLU BY U's Avatar
That's correct, but, I thought mine was at 30 when it was up to temp.
Old 03-06-2012, 10:26 PM   #13
BLU BY U
'69 Camaro's Rule
BLU BY U's Avatar
It's seems like mine was at 30 idling before I did my oil change a week and a half ago.
Old 03-06-2012, 11:07 PM   #14
Coyotekiller
Drives: 2012 AGM 2SS
When I start mine cold, it spikes to about 60psi then gradually warms up and the pressure comes down to about 25psi once the engine is above 200*.
The console gauges are kinda misleading as to actual readings because they only show a few numerical graduations each. Like the voltmeter. Goes from I believe 6 to 12 to 19, all being equal distance apart. The temp gauge is graduated correctly and easily but the others are just odd.
Coyotekiller is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
How to change your oil in V6 trooper182 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 20 12-16-2012 07:08 AM
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 03:55 PM
What kind of oil pump should I install? jeffny09 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 73 06-19-2012 06:06 AM
