HeadlightArmor
Old 03-06-2012, 09:00 PM   #1
gjarzabek009
gjarzabek009's Avatar
Drives: 1LT
Fuse pull for the v6
So past couple days my car felt abnormally sluggish. I decided to try the fuse pull on the v6 (im tuned to run 93). I pulled the fuses and waited about 40 minutes and put them back in. Then my car ran the way it was supposed to. Any idea why I had to do this? I might have put 87 in but I am not 100% sure.
-21" GM wheels -3.73 gears -Injen PowerFlow CAI
-OBX LT headers -Doug Thorley Catback exhaust
-Magnaflow High Flow cats -Trifecta Tune
-VMAX Ported TB
-Maces 25mm Insulator
-Ported Intake manifolds (soon)
gjarzabek009 is offline   Reply With Quote
Old 03-06-2012, 09:04 PM   #2
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
interesting, becasue the fuse pull is a V8 thing and not a V6 thing and should not be required.
Old 03-07-2012, 12:18 AM   #3
KMPrenger
KMPrenger's Avatar
Agree...very strange. Hard to say what it was really.
Old 03-07-2012, 06:58 AM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
agreed... the V8 has separate fuel tables and the fuse pull was to clear out stuck low octane fuel tables... the V6 works very differently and doesn't have separate fuel tables...
That being said... not sure what actually was going on with OP' car...
scrming is offline   Reply With Quote
Old 03-07-2012, 07:01 AM   #5
turboguy327
Banned
Drives: 2011 Chevy Camaro
I have done the same exact thing but I unhooked the battery. It was running super super rich (black smoke and soot covered the back of the car) and a battery unhook fixed it. I'm on stock tune though.
turboguy327 is offline   Reply With Quote
Old 03-07-2012, 08:35 AM   #6
TooCool5
TooCool5's Avatar
Not a V8 thing, all cars benefit from a fuse pull.
Just did mine yesterday went from 15 MPG city to 17 (cold weather).
For some reason this LLT V6 gets bogged down after a long winter and doesn't re-adjust properly. Maybe someone from GM could explain?
Standard protocol when installing an intake or making any component change
is to unhook the neg battery cable. Its written in all the manuals, allows the proper synchronization / learning of the new part.
In colder climates they change from winter formula fuel to less volatile summer blend.
I don't know why the LLT will not re-learn the summer fuel but this time of year I have to do a fuse pull to get my mileage back.
Going on a trip today and I'll post my mileage numbers later.
Old 03-07-2012, 10:39 AM   #7
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
yeah, not buying it. i did the fuse pull a long time ago, and didn't notice any changes. 2mpg difference? not enough to say it was changed due to fuse pull. lots of other factors could have caused that.
Old 03-07-2012, 11:02 AM   #8
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
The only thing done by unhooking your battery was a fuel trim reset. You car relearned the STFTs and LTFTs. So while the fuse pull helps the V8 I don't see why let our screwy ECM relearn the fuel trims.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 03-07-2012, 11:13 AM   #9
scrming
scrming's Avatar
agreed... I think the main reason the companies want you to unhook the battery is so you do short anything out...
Old 03-07-2012, 03:35 PM   #10
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
Im gusessing "power of suggestion"... liley feels better becuase you expected it to feel better.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 03-08-2012, 10:10 AM   #11
TooCool5
TooCool5's Avatar
I just did this yesterday on my first long drive to the Beach after the fuse pull.
Rt 81 is a 45 - 50 MPH rural road.
You guys want to be hard headed then don't do it!
Old 03-08-2012, 10:26 AM   #12
bmorecam
When you fuse pull you are resetting the ecm, which mean you are resetting your fuel trim, throttle sensor, KR, etc..etc..
Resetting the ecm will always make your car feel alive at first but it ill come back to feeling "normal" after about 100 miles when almost all sensor finish learning with fuel trims taking the longest. I personally wouldn't do any wot runs for the first 30 miles anytime after resetting the ecm, but I'm sure there are peoples that will disagree
Old 03-08-2012, 11:56 AM   #13
formare
The Milano
formare's Avatar
For conversations sake - which fuses did you pull?
Old 03-08-2012, 04:31 PM   #14
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Can't speak for the OP, but I've always done #5 and 20.
ChadG is offline   Reply With Quote
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2790 08-22-2017 01:28 AM
Fuse Pull on LS3 Still Necessary? TheHorse13 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 07-20-2011 09:41 PM
fuse pull help pwrmanpaul66 Camaro DIY & HOW-TO instructions & discussions 3 07-14-2011 08:48 PM
LLT have a fuse pull mod? jagan323 5th Gen Camaro SS LS LT General Discussions 10 06-08-2010 01:22 AM
Fuse pull? Rage 5th Gen Camaro SS LS LT General Discussions 22 06-06-2010 02:08 AM
