Wretched Motorsports
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-07-2012, 08:41 PM   #1
tbgSS
tbgSS's Avatar
Drives: 2011 Camaro Convertible 2SS LS3
Tuning for Vararam (inTune)
I'm thinking about buying the Vararan tune intake
I have a Diablo Sport Intune.
If I go Vararam...
What fuel trim levels should I adjust to? All I have been able to find via Google is for the no tune..
...right now just running the Diablo tune and only other mod is Corsa cat back...
tbgSS is online now   Reply With Quote
Old 03-08-2012, 08:39 AM   #2
tbgSS
tbgSS's Avatar
From the instruction manual for Vararam I found this (no reference to the tune model):
Custom tuning - based on a stock car with a no tune model
Cold start, this should be in Parameter
Cruise - also in parameter
Wide open throttle operation (timing) Fuel
600-2000RPM + 4 deg -5%
2000-4000RPM + 4 deg -5%
4500-5000RPM + 4 deg -5%
5100-5500RPM + 4 deg -5%
5600-5800RPM + 3-4 deg -5%
This is a conservative combination and does not include removal of Torque management. If you have a catback etc...
Would I expect similar values for Vararam tune model?
I'm really trying to decide if I need to factor the cost of a custom tune in my budget or if I can just adjust these values myself using the inTune I have...
Old 03-08-2012, 09:05 AM   #3
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
It says on Vararam's site to expect +18% or more.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 03-08-2012, 04:15 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
I would not suggest adding 4 degrees of timing to the factory tune or the Diablo Tune, this is BAD info.
Also Diablo reduces fueling by scaling injectors and this is also Wrong way of Tuning for a Vararam.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-10-2012, 12:09 AM   #5
MikeOD
Drives: 2010 M6 2SS
When my car was stock and I put the tune Vararam on, the fuel trims went well past 20%...the MAF cross sectional area is just a lot larger.
For what it's worth...I corrected the MAF calibration off the wideband, and I left the spark advance in the car 100% stock...it made excellent power, and drove very nicely. I have since tweaked the spark table a little...but it's been adding a degree here, pulling a degree there...smoothing a bump...small stuff...nowhere close to just blindly tossing 4 degrees at a portion of the table.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust.
499 RWHP 463 RWTQ.
MikeOD is offline   Reply With Quote
Old 03-10-2012, 04:06 PM   #6
bmorecam
Same here. Mine went lean pass 20%+ but it seems some cars trims stay perfect and some don't. Mine is one of them that always go lean with any aftermarket intake.
Old 03-12-2012, 08:17 AM   #7
JANNETTYRACING
Trust me it is not the Cars, they are consistent.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 03-12-2012, 08:27 AM   #8
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Wow 4 deg is a lot. It would probably see crazy amounts of kr in the 5000-5500 range. I'd rather see a raped pe table than a raped fuel injector flow rate........
GM Performance Parts Sales, Installation, and Calibrations
rhino-79@hotmail.com
Kooks, EFILive, Edelbrock, Powerbond, Comp, Mast, LPE, Circle D and many more!
2010 SS L99 Cam, Bolt-ons, 3.91s, CircleD 1E 10.87 @ 124 THE Fastest NA L99
Rhino79 is offline   Reply With Quote
Old 03-12-2012, 09:08 AM   #9
bluetorp
bluetorp's Avatar
Drives: 2010 2SS/RS IOM M6
It's a wonderful approach to tuning.
"Let's compensate for this table being incorrect by going to this other table and making it incorrect as well!"
Why do people still think that this is acceptable?
Whipple 2.9L S/C, ARH LT's, Flowmaster AMT, HPTuners
bluetorp is offline   Reply With Quote
Tampa Tuning prices are still the best Tampa Tuning USA - Southeast 9 01-26-2013 04:59 PM
Tampa Tuning Tampa Tuning Local Marketplace 6 02-08-2012 07:03 AM
Tutorial: Can I tune my own vehicle? bluetorp Tuning / Diagnostics -- engine and transmission 11 01-23-2012 07:04 AM
Free Shipping On Diablosport Intune Jeff@HHP V8 Bolt-Ons & Tunes 0 12-07-2011 12:46 PM
Best priced camaro corvette GTO Firebird Trans Am GM Truck tuner Tampa Tuning Tampa Tuning V8 Bolt-Ons & Tunes 1 01-30-2011 05:02 PM
