| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
engine knocking and brake fluid
So my two questions are irrelevant but here it goes. First off my engine has a slight knocking sound when idling. Normal or problem? I change my oil three times already from new and have 16000 miles on her. Second the other day when i was driving my brake fluid light came on and turned off in like 3 seconds and then it did it again today. Normal or problem?
![]() Drives: 2010 Chevrolet Camaro 2SS / Silver Join Date: Feb 2011
Make a vid of it bro hmmm,m
![]() Drives: Camaro SS Join Date: Mar 2010
I would take it in under warranty & have it checked.....also to start an audit trail in the event it gets worse & the dealer says nothing is wrong.
They all make noise.....did you check your brake fluid?
No china cheap bolt-on's, buffet, or yubiwaza here.....
I used to be Stieger....
Have you checked your brake fluid levels? Some 2010s had a leak in the cap.
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
how's the oil pressure
Yeah, I'll get around to it...
#6 |
![]() Drives: wife says to many Join Date: Feb 2012
check your brake fluid, check your oil, take it to your dealer and start an accurate log of everything that has happened and what is being done with your car.
#7 |
Drives: 89 IROC 350 Join Date: Mar 2009
I have a 2010 with 30,000 miles and have never even see the brake fluid light...
![]() The knock is not normal. |
#8 |
okay thanks guys. I had the brakes changed today by my friend who said i had no brake pad left so I'm assuming thats why that light came on. And the engine knocking is becoming a problem cause my dealer says it normal but no other camaro I've seen sounds like that. I think I'm just going to go to another dealer. Ill try and put a video i gotta see if you can hear it in the video
| Thread Tools | |
| Have you done a brake upgrade for road course use? | ericedelman | Suspension / Brakes / Chassis | 25 | 08-18-2010 01:19 PM |
