Caryle Racing
Old 03-08-2012, 09:42 AM   #1
SLO-POKE
SLO-POKE's Avatar
Drives: 2010 Camaro SS/RS Black
Smile Lowering Springs
If i lower my car 1" how much will it change the ride?
And i go to 1.25" lower how much will it change it?
2010 SS/RS
Corsa Cat Back Exhaust
Injen Cold Ait Intake
All Black Scarallos DriftR Wheels
Front 20X10 275/40ZR20 - Rear 20x11 315/35ZR20
SLO-POKE is offline   Reply With Quote
Old 03-08-2012, 11:29 AM   #2
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Our drop spring packages were designed to lower the car about 1.25 inches. The car will definitely ride a little sportier than stock, but is still absolutely comfortable for daily driving. It feels more like a sports car than as it comes from the factory, but we don't increase the spring rates to the point that it becomes harsh on the street. During our initial impressions of the car 1.25" is about all you really want to lower the car on the stock shocks for best performance with little decrease to the lifespan of the shock. You can check out the photo gallery of Camaro's equipped with our drop springs here:
1.25" Drop Spring Photo Gallery
Old 03-08-2012, 01:35 PM   #3
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
Hopefully a lot of our customers will chime in here and give you some feedback. Most report that ride quality is slightly stiffer but not uncomfortable by any means. Some even report that they don't feel a decrease in ride quality at all. The OE rates are very conservative so you can add a good amount of rate before ride quality begins to suffer.
As for 1" vs. 1.25", at least when looking at our springs (1", 1.4"), the ride quality is equal because the spring rates are equal. The difference is shock travel. The lower you go the less shock travel you have and the easier it is to hit the bump stops. If you have bad roads in your area with lots of potholes, dips, and bumps you will hit the bump stops sooner with the lower spring.
BMR guy is offline   Reply With Quote
Old 03-08-2012, 01:45 PM   #4
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Here's what I did. I used Eibach Pro Kit 1.25" lowered. It was more my budget, and I didn't do nearly enough homework. Ride's not too drastic of a change. You'll definitely feel more bumps and bounces of bad roads. Pfadt, Pedders, BMR are all great systems. I've rode with folks that have em. Also, do something I didn't think about...AirLift's air suspension system. It's comparably priced. The only member I pm'd with loves it. Not trying to push one over the other, but get as much information as you can before deciding. I have 22" and 24" low profile tires. That's also contributing to more bumps. These cars look agressive lowered. My guess is, you'll be happy whichever way you choose.
Project MantaRay...Underway
GunnyG is offline   Reply With Quote
Old 03-08-2012, 02:00 PM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
I have the pedders 1.3"/1.0" drop. To tell you the truth, I didn't feel a difference until it came to drastic bumps. Any drastic bumps and you can tell but it's not bad by any means. I'll put it this way: if the camaro came with this feel in the suspension, most people probably wouldn't even mind. In every other situation, it feels just like stock. The girlfriend didn't even notice it until a drastic bump came up. I think the cars look great lowered
Old 03-08-2012, 07:02 PM   #6
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
1.0"-1.25" drop is about the right height to go with before needing to go with a set of coil overs.The ride will be slightly stiffer with a drop spring but not drastic,drop springs use a higher spring rate to help with the reduced amount of suspension travel.We have had great luck with the Pedders drop springs they are designed to be used with the OE struts and the OE bump stops with no cutting.
Bruce@raymondsperformance is offline   Reply With Quote
Old 03-08-2012, 07:07 PM   #7
GunnyG
Da WHALE
GunnyG's Avatar
+1. Didn't mean to leave out Pedders. Another great system. OP, there's many to choose from. Actually, I haven't heard a bad thing about any of them. Good luck with your selection.
Old 03-08-2012, 07:39 PM   #8
mikeSS
mikeSS's Avatar
Drives: 2015 c7
ya you will be fine. i love the way my car feels now. better road feel. i hated how much it felt like a caddy when i first got it. springs and sways for sure helped a lot.
Old 03-08-2012, 09:10 PM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Depends on the springs but the BMR 1 inch and Pfadt 1.25 both ride very well.
Old 03-08-2012, 09:52 PM   #10
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
I completely agree but I have Pfadt. Rides the same if not better than stock except those big hits.
bajamoon is offline   Reply With Quote
Old 03-12-2012, 12:52 PM   #11
SLO-POKE
SLO-POKE's Avatar
Thanks Now is the decision on who to go with. I have 20X11" wheels 315 on the back 20X10" 275 on the front do you think ill have a problem with rubbing?
2010 SS/RS
Old 03-12-2012, 03:16 PM   #12
The front will be no problem,the back with the 315 on 11's are going to be awful close.I have seen this set up on a couple of camaro's but both of them had some rubbing when hitting bumps or a dipp in the road.
Old 03-12-2012, 10:14 PM   #13
SLO-POKE
SLO-POKE's Avatar
Do you know how low they were?
2010 SS/RS
Old 03-12-2012, 10:20 PM   #14
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
I have 1" Eibach's and have 315's on my show wheels on 11" Modulare wheels, if you have Nitto Invo's shouldn't be an issue had no rubbing issues, but have Pirelli's on them now and they do rub when bottoming out on a big bump in the road...
So Cal Camaro is offline   Reply With Quote
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. Apex Motorsports Suspension / Chassis / Brakes 341 02-02-2014 12:52 PM
2010-11 Camaro V8 Eibach Pro-Kit Lowering Springs MARINE1991 Local Marketplace 3 08-09-2011 10:08 PM
Half Price Sport Lowering Springs at MTI Racing MTI Racing Kevin Suspension / Chassis / Brakes 0 07-27-2011 11:44 AM
2010/2011 Stainless Works Headers w/Eibach Lowering Springs Special till end of May Xplosive Performance V8 Bolt-Ons & Tunes 12 07-02-2011 07:36 AM
Stainless Works Headers w/BMR Sub Frame Connectors or Lowering Springs under $1375 Xplosive Performance V8 Bolt-Ons & Tunes 2 12-30-2010 09:28 AM
