MPD1
Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission.
Old 03-08-2012, 07:35 PM   #1
RedRocketSS
BSHU
RedRocketSS's Avatar
Drives: 2011 Red Jewel SS
DynoJet = Lower numbers?
Just wondering if DynoJet numbers are low compared to other dynos?
I just got my SS dynoed and was pretty amazed at how low they were. I was definitely expecting higher numbers than 337/360. Only mods are CAI with scoop, ported TB, and axelback exhaust, Yes i know these arent gunna add a whole lot of power to begin with but i figured itd be higher..
CAI and Ported TB,Loud Pedal Motorsports Tune, Pfadt Lowering Springs, and more.
RedRocketSS is offline   Reply With Quote
Old 03-09-2012, 02:15 PM   #2
RedRocketSS
BSHU
Lol anyone?
Old 03-09-2012, 02:36 PM   #3
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red, 1LT/RS SGM
A6 or M6? If M6 they are low if A6...about right
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, ARH LT s, Procharger D1SC, Squash dual 400LPH/ID1000s, ALKY 4 gal meth, AM AFR/Bst/oilpres/oiltemp gauges,SWretro3" exh, VMaxx TB, RX monsterCC. Pedders Justice road crs pkg: All HD bushes, supercar coil overs, supercar ZL1 sways, camber plates setup by JusticePete! :Gforce 9" 35spline S-Trac, 300M axles, 3.5"alum DS, MCLeod RXT clutch, 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, next CTS-v calipers/ZL1rotors/carbotech pads
BullF-16 is offline   Reply With Quote
Old 03-09-2012, 02:42 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Automatic, High Temps, humidity, High altitude and 91 octane all play a roll in Low Power numbers.
At Sea Level in 60 degree Dry air they make 330-340 RWHP All Stock.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 03-09-2012, 05:29 PM   #5
bmorecam
That doesn't look that low now LOL. You have some V8 guys that dyno in the 290's stock on a dynojet. A dyno is not a tool to measure your overall exact horsepower. Some will come close, and some too high or too low. Don't trust dyno numbers in knowing your overall hp/tq, dyno is a tuning tool to measure your modifications.
Old 03-09-2012, 08:08 PM   #6
RedRocketSS
BSHU
yeah its A6, thanks guys. i try not to pay too much attention to the numbers but its hard when higher numbers=usually faster lol.
Old 03-09-2012, 08:18 PM   #7
BullF-16
BullF-16's Avatar
You're pretty much spot on for an A6. they make 25 less than an M6. My initial dyno with catback and CAI was 358 rwhp on a dynocom....man that was a long time ago....7 months! I also only had 600 miles at the time which affects it a little.
How many miles on your motor? If less that a few grand then it will loosen up a bit. Dont get wrapped up in the numbers though as you mentioned. Use the dyno as a tool and try to always use the same one after each mod
Old 03-09-2012, 10:20 PM   #8
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
Have you gotten it tuned? That would probably optimize your mods and unleash some extra HP/TQ. It really helps the auto tranny, too.
Solo Mach XL with J-Pipes · Cold Air Inductions Intake w/JRE Scoop · Jannetty SCT Tune· Roto-Fab Washer Bottle · Defenderworx Bowties · Vmax Ported TB · LPE 3.70 Gears · Dynatech SuperMAXX Headers · Elite Engineering Tunnel Brace · CFD Pistol Grip TapShifter · GM Strut Tower Brace
E.T. is offline   Reply With Quote
Old 03-10-2012, 01:16 AM   #9
RedRocketSS
BSHU
roughly 10k miles and im sorry i should have said those numbers are with it tuned.
Old 03-10-2012, 07:51 AM   #10
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
You're good. You should be worried if you only made 290 rwhp. There have been L99 A6s producing numbers this low. I talked to a guy who said his L99 A6 only made 290 rwhp and he wanted to take his car back to the dealer.
He ended up getting his car tuned by a local tuner, and his numbers jumped to the 330s range.
Old 03-10-2012, 07:53 AM   #11
Slowhawk
Drives: 1999 Trans Am
numbers look to be close. ussually the torque and hp is alot closer.
Slowhawk is offline   Reply With Quote
Old 03-10-2012, 02:01 PM   #12
RedRocketSS
BSHU
wow thats insane...id wanna take it back too!
i thought this as well. but sounds like my numbers are right there and the car runs really well now so im not too worried!
Old 03-10-2012, 04:02 PM   #13
bmorecam
Just because a guy make 290 on the dyno does not mean his car is really making 290hp LOL. You just have to understand how dynos work and what it was meant for. If you guys come out of a dyno with 360hp stock would you say that you need to take it back to the dealer? Some dynos will produce low numbers and some high, and some just about right. There's just no way to perfectly calculate your exact hp/tq on a dyno. It can come close but it will never be perfect on the money.
Old 03-10-2012, 05:06 PM   #14
SGOS252382
SGOS252382's Avatar
Yes, that is true. You do need to look at the dyno being used and what kind of correction factor being used.
But there are cases where cars are only making 290s rwhp on Dyno Jets (SAE corrected numbers). These same dynos are producing 320 rwhp (bone stock) with other L99 A6s running on them.
I also chatted with a local guy and his car also dynoed in the 290s (Dyno Jet SAE corrected). His car is now modded (intake, full exhaust with long tubes, and tune) and is making in the 360s rwhp/370 lb ft. (which is right where he should be for his mods).
For some reason, don't know if it's still the low octane tune issue, but some L99s dyno real low.
Lower Control Arm - GM Redesign Status? tjd24 Suspension / Brakes / Chassis 8 11-07-2011 06:16 PM
TSP Cam + RPM Tune = Impressive numbers lrc250 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 08-12-2011 01:46 PM
Stock Dyno Numbers toast 5th Gen Camaro SS LS LT General Discussions 2 01-05-2010 01:57 AM
5th gen performance numbers are in from the top Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2008 05:38 PM
