Old 03-08-2012, 08:53 PM   #1
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
Front Control Arms refuse to come out of spindle!
I have hit this these things with a brass sledge hammer, wood block and even a head but butt and it wont freakin budge!!!!!
Any one else do the front control arm bushing upgrades? How did you remove the arm? I got both radius rods off pretty easily but the control arms just hang off the spindles laughing at me.... I'm no small or weak man but they are
RaiderSS is offline   Reply With Quote
Old 03-08-2012, 10:40 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Use a regular hammer and put something under the spindle. That way you get some counter force when you hit it. Took me one good solid hit to get them out.
SUX2BU is offline   Reply With Quote
Old 03-09-2012, 09:32 AM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Hey Eddie those things can be a pain to get out of the spindle. The last car I did I threaded the nut back on the ball joint and hit the nut with a brass hammer and they popped out. Just make sure you put the nut on so the threads don't get messed up.
T.C. Davis
tc@bmrsuspension.com
813-986-9302
Old 03-09-2012, 11:01 AM   #4
JusticePete
5th Gen Master Builder
JusticePete's Avatar
Drives: Camaro Justice
Did you get it out?
Old 03-09-2012, 12:53 PM   #5
Synner
Drives: 2011 2SS/RS M6
I beat the crap out of mine a few days ago and it still wouldn't release. Soaked it for 3 days, heated it, pounded on it. Nothing. I even bent a c-clamp that came with a ball joint removal kit.
Finally gave up and started doing the sways instead.
Old 03-09-2012, 01:33 PM   #6
JusticePete
Steel Ball Joint Stud + Aluminum Knuckle =
With the car on jack stands it is really hard to get a good swing and solid strike. On a lift with plenty of room to work they are still struggle. For those that just won't move we use the blunt tip in an air hammer.
It will guber up the tip of the stud and scar the knuckle, but it will come out. When the arm is out, you can clean up the what is left of the stud tip on a bench grinder. This works for both the radius and LCA.
If you are removing the front lower control arm to replace the inner bush, maybe it is a good thing the arms were stuck. The front lower inner control arm bush from the factory is damn good. It is a barrel style ferule that rides on a very thin layer of dense rubber. During our R&D we cut one apart.
Unless you are building a full on race car, the bush should not be replaced. I keep the pieces on my desk to remind me that Chevrolet is getting very good and we are going to have to be on top of our game to stay ahead of them
Old 03-09-2012, 01:59 PM   #7
Synner
I was just trying to do the radius bushes I got from your x-mas special. I knew it was time to quit when I wanted to use the hammer on more than just the stud. So a bunch of beers got finished but not the radius rods.
What i got from your post was I need to find a way to buy more tools without the wife knowing.
Old 03-09-2012, 07:45 PM   #8
JusticePete
or order on line and have them delivered to your neighbor so you can borrow them.
Old 03-12-2012, 10:20 AM   #9
RaiderSS
RaiderSS's Avatar
I finay got the Control Arms out by leaving the nut on the tip to increase hammer contact, put a juck under the spindle for counter force and they finally came out after angleing the sterring for the most clearence. Problem is leaving the nut on i beat up the thread on the passenger side arm.
Im taking them to my machine shop on my lunch break today. Hopefully they can repair the thread after pressing out the old bushings.... Everything else in the BMR front pro bushing kit I finished this weekend, radius arms, steering rack insulator and the prothane motor mounts.
I also picked up the famed camaro5 strut monut insulators (aka toilet flush gaskets) that I will install when the car is back on the ground...
Some info for ZL1 owners R6P Camaro ZL1 Forum - ZL1 Specific Topics 92 12-04-2016 09:00 PM
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 8 01-09-2015 04:11 PM
NEW Official Details on Camaro ZL1 -- 580hp / 556 lb-ft torque!! DarthNacho08 Camaro ZL1 Forum - ZL1 Specific Topics 420 09-27-2011 04:17 PM
BMR Launches New Product - 2010+ Camaro Rear Lower Control Arms (TCA028) BMR guy Suspension / Brakes / Chassis 33 08-31-2011 05:51 PM
GM Reveals 2011 Chevrolet Silverado HD FenwickHockey65 General Automotive + Other Cars Discussion 55 03-04-2010 01:56 PM
