Old 03-10-2012, 11:22 AM   #1
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
2nd gear grind (tr6060) and Redline D4 ATF
I, like many here, have always had the dreaded 2nd gear grind/notchiness and occasional 3rd grind/notchiness. Especially at the drag strip, usually 2-3 runs out of 7 I would be denied 2nd gear or grind hard. Not to mention that reverse always seemed hard to get into. And of course, 50 degree temps and under it was worse.
Now, I was very skeptical that any type of fluid change was going to fix this. My warranty was shot within weeks of me taking possession of the car from dealership because of my engine mods. No prob, I pay to play, not going to make this a dealer issue in MY case. So I had read that some guys had good luck with the Redline products, I bought D4 ATF, still skeptical, but hey, what else is there to try? Rebuild? Yes eventually, that is my intentions to handle more HP down the road.
I drained and refilled with D4 ATF and was able to get 4 qts into the tranny. Immediately after starting the car at just under 50 degree air temp I was able to put it into ANY gear without notchiness, I think to myself "yeah right, don't get excited yet...." LOL! And trust me, I run an MGW shifter so it is much more positive shift feeling. I noticed that it went right into reverse without effort like usual....OK... I went through about 7 good hard launches and ripped through the gears (1st through 4th) like never before!!! I still am in disbelief and I am still hoping that this has bought me some time until I can actually rebuild the tranny for harder use later.
Is this a cure all? Probably not in some cases, but I would definitely recommend that you try this D4 ATF before you do anything drastic, it may help alleviate some of the symptoms we are experiencing with the notchiness and grinding. Redline D4 ATF is designed for manual tranny cars and meets or exceeds GM requirements. And, it helps with synchro mesh by adding more friction, some other brands are in fact too slippery, which I believe causes the synchros to spin to fast and have probs engaging. This thing shifts like butter now!!! I would have never thought the MGW shifter would be quieter when shifting. No notchiness and grind issues to report at this time.
I am running a Textralia oz700 Z grip HD clutch, Separate clutch reservoir and keep the fluid clean.
Again, I am not claiming that this will fix everything but its worth a shot!
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-10-2012, 12:31 PM   #2
pnyklr
Drives: A Gift From My Wife
Thanks for the write up. That is the exact fluid I am going to be using.
-Funk
2012 Convert 2SS/RS SW/IO LS3 - Build #1081
07/21/2011 - (3800) Order produced and vehicle is being prepared for shipping.
08/09/2011 - (4200) Shipped (vehicle is shipped to the dealer or interim point of delivery).
08/16/2011 - (5000) Vehicle has been delivered to dealer.
08/19/2011 - In my possession.
pnyklr is offline   Reply With Quote
Old 03-11-2012, 11:01 AM   #3
TornadoSS
WICKDSS
TornadoSS's Avatar
-Funk
Thanks! I hope you get the same results that I got!
Old 03-11-2012, 01:04 PM   #4
pnyklr
I don't have the 2nd gear grind once the tranny is up to temp. I am mostly trying to reduce the notchiness I get in 2nd but mostly in 3rd.
-Funk
Old 03-11-2012, 01:37 PM   #5
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
I put royal purple syncromax in mine and it made a big difference. Changing the fluid definitely helps
IDEALG is offline   Reply With Quote
Old 03-12-2012, 09:57 PM   #6
Eidolon
Drives: 2009 Pontiac G8 GXP M6
I'll throw in another recommendation for the Redline D4 ATF. I actually put it in after finding a recommendation on this forum. I've also got the TR-6060 transmission, and the Redline fluid works very well, especially when warm. No regrets here.
2009 Liquid Red O/R M6 G8 GXP
#1468, 1/67 as optioned
Eidolon is offline   Reply With Quote
Old 03-13-2012, 12:53 PM   #7
c_LoW29
Drives: 2011 2SS/RS, 2010 Mustang GT
Sad thing is, none of this should be necessary GM should be addressing this issue.
c_LoW29 is offline   Reply With Quote
Old 03-13-2012, 01:17 PM   #8
Eidolon
Depends on how much of it is an honest issue and how much is just the side effect of producing a manual transmission that can handle 600 lb-ft or more of torque. The updates to the syncros may have been made due to complaints and not due to need.
Old 03-14-2012, 08:41 AM   #9
plastrd
Indecisive
Drives: 2010 Camaro SS/RS
Red Line MT-90 did wonders for cold weather shifting in my old Mazda 3 so I have good expectations for Red Line products in the Camaro. I just got a gallon of D4 ATF and quart of 75W90 for the diff that I plan to change out this week. My 2nd doesn't grind but it does seem to be the problem child out of all the gears being the hardest to shift into. Hoping the D4 smooths that out a little bit.
The car is just about to roll over 40,000 miles and this is the first change so I'm interested to see how much sludge comes out of the differential. By the accounts of people who changed at 1000-3000 miles I'm almost afraid to watch!
plastrd is offline   Reply With Quote
Old 03-14-2012, 08:50 AM   #10
Waterboy2b98
Waterboy2B98
Waterboy2b98's Avatar
Drives: 11 2SS M6.
I will try it because I am getting no help from the dealership. Talked to Chevy once on the phone and they are acting like its not a big issue.
Waterboy2b98 is offline   Reply With Quote
Old 03-14-2012, 02:15 PM   #11
Nessal
Drives: Exige, Miata, Ghia
Hmmm, I was going to replace with GM oil but will probably look into Redline.
Nessal is offline   Reply With Quote
Old 03-14-2012, 02:22 PM   #12
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I so need to do this. Thanks for the heads up
chevy 3 is offline   Reply With Quote
Old 03-14-2012, 02:22 PM   #13
TornadoSS
WICKDSS
TornadoSS's Avatar
It doesn't hurt to try! Its not cheap oil by any means, I paid 10.49 a qt. at a local shop.
Old 03-14-2012, 09:24 PM   #14
sschevybear11
sschevybear11's Avatar
Drives: 2011 Black 1SS
I royal purpled mine and it does shift noticeably better under normal conditions I still get a 1-2 grind if I pull 2nd hard and fast. If I shift pretty quick its OK.
2011 Black 1SS M6 12.75@110.91 bone stock
Now: Coated Dynatech LT's/!Cats/Hurst Shifter/Roto-fab/SLP SS badges/JRE 415HP Tune, Scoop & Washer Relocation Bottle,Hurst Stunner 20X9 Wheels, Moroso Catch Can, ASP pulley, Magnaflow X-pipe, GTO remote clutch reservoir
1989 Silver 5.0 Mustang LX Coupe
1999 Pewter Tahoe LT
2011 Blue Camry SE
sschevybear11 is offline   Reply With Quote
Rear End Gears 101 danhr V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 82 08-04-2017 11:38 AM
